-   Alternative Imaging Methods (https://www.dvinfo.net/forum/alternative-imaging-methods/)
-   -   Reversed image upside down? (https://www.dvinfo.net/forum/alternative-imaging-methods/42544-reversed-image-upside-down.html)
James Hurd March 11th, 2005 07:50 PM
Yep, wireless will certainly be a great option.
The equipment that will be released in 06 will be top notch stuff at an Indie price point. That's all I can say! I've got to get back to the micro35!!
Thanks Joel!
james
www.micro35.com
Brian Valente March 21st, 2005 10:15 AM
I put in a request to the guys over at DV Rack to include a "flip 180" button on their product. They said it sounds simple, so if you own or are interested in DV Rack, put in the request as well, and maybe we can get them to include this in the next release of their software.
www.seriousmagic.com
Brad Phillips March 22nd, 2005 10:33 PM
I may have found a way to flip the XL2 view without switching the whole assembly to the other side.
I had to replace my LCD screen the other day, when I got inside I noticed you could just flip the entire LCD and circuit board 180. It should work, my only concern would be if the wires are long enough. I will be trying it when I get my unit from james.
Andrew C. Stewart March 23rd, 2005 05:48 PM
Let us know Brad...
I'm curious how best to configure the XL2 with James adapter.
Jon Laing March 24th, 2005 02:06 PM
Hey guys,
Im brand new to this forum, have only moderate experience with dv as of now (in excess of two years), and a limited knowlege of physics but the solution to the flipped image problem seems pretty simple to me.
Now im not too keen on how the adapter works, all i kno is that there is a lens mount, a ground glass, and a macro adapter, i may even be wrong there. Now, if one were to put an independant single convex lens inbetween the ground glass and the macro adapter (at the apropriate focal distance of course), wouldn't that flip the image back around to be right side up?
Daniel Skubal March 24th, 2005 02:29 PM
That's what is being said on dvxuser.com, it should work, but I don't know if that will have an affect on the ground glass as far as placement and distance from the glass and the camera lens. In theory though, it should work.
Aaron Shaw March 24th, 2005 04:33 PM
Jon,
That would absolutely work! It makes me wonder why no one has made an adapter that does this yet. The P&S guys could cut out a lot of expense by going this route (no prisms).
I suppose it's probably due to need for calculations and most likely custom glass.
I've thought of doing this myself before but nearly every stock lens has too long a focal length for this to be practical.
Radek Svoboda April 6th, 2005 03:27 PM
What is the fix?
Daniel Skubal April 6th, 2005 03:59 PM
It's not right/left flipping, only up/down, and it can easily be fixed in post. I believe the pro version is going to have a prism system in it so it eliminates that problem
James Hurd April 6th, 2005 04:04 PM
There are ways to 'rotate' the image on the camera and on the monitor during production.
Brian Valente April 6th, 2005 05:53 PM
I may have mentioned this before but I am pitching the guys over at DVRack to include a 180 degree switch on their field monitor. that would completely solve the problem and of course DV Rack is a great product anyways.
It IS a 180 degree rotation problem, right?
Steven Fokkinga April 7th, 2005 02:39 AM
Yes it is a 180 degree rotation, which is the same as flipping a piece of paper horizontally and then vertically, try it with a piece of paper.
Steven
Radek Svoboda April 7th, 2005 06:03 AM
So you basically need monitor that will flip everything 180 deg. Is there such monitor? How about during editing? Can NLE's just flip image 180 degrees?
Brian Valente April 7th, 2005 08:17 AM
Of course NLEs can do it - the challenge is monitoring during production. I recall the earlier part of the thread was simply to take a field monitor and flip it upside down. And then there's the put-the-magnet-next-to-your-camera-and-
trick-the-flip-out-viewfinder-to-turn-upside-down but that gives me the willies!
Brian Valente April 13th, 2005 11:11 AM
Hey all - I'm just curious how many people are considering purchasing an camera-mount LCD monitor that can "do the flip" to solve this problem. I've done some research and a 5" lcd that can do this ranges from $260-400.
I am thinking this is the best approach (esp. since the micro35 being $500, I am still WELL under the price of the mini35), but wanted to hear other thoughts
