February 2nd, 2021, 03:39 PM | #1 |
Does Inferno HDMI output port ever work?
Hi. Is anyone's Inferno or V output port working? My monitors say "Input Not Supported."
The playback video is 4kUHD29.97 and I have selected "down conversion," so output is 1080p. The output is connected to one of two monitors, one 1920x1080 and the other 1920x1200. Both say "Input Not Supported." I've tried 3 different (good) HDMI cables with no luck. The output should be 1080p and so no heavy demand on the cable right? |
February 2nd, 2021, 05:31 PM | #2 |
Re: Does Inferno HDMI output port ever work?
Mixing resolutions resolutions or hdcp can cause this. Try setting everything to the same resolution/frame rate, see if that does anything.
February 7th, 2021, 10:31 PM | #3 | |
February 24th, 2021, 10:20 PM | #4 | |
Heard back from Atomos. I gave them 3 models, new Acer and Asus 1080 monitors and a 6 month old Epson 4K projector, all which support all camcorders HDMI out at any resolution.
After 3 weeks of back and forth, including their requesting proof of purchase (though it was registered and they had my serial number) they gave me an RMA. Through the ringer. I then bought a Ninja V and found the exact same result. Instead of sending it it, I sent that to info them and the responded with this. Quote:
February 24th, 2021, 11:11 PM | #5 |
Like I said in my original post HDCP. HDMI is encrypted to prevent copying. The device must do what is called a handshake before a signal is sent. I found it's a crap shoot what device will work with the Atomos. There are different versions of HDMI/HDCP each device has a chip in it even the HDMI cable. The new versions tend to get stricter.
February 26th, 2021, 05:00 AM | #6 | |
February 26th, 2021, 12:31 PM | #7 | |
I've discovered the Atomos works fine with a camera, but introducing other devices can cause it to not send or receive a signal. I use it as backup recorder for Zoom conferences. If I plug the Ninja Flame into my laptop as second monitor, I can only record video the audio despite the meters indicating it's receiving audio. Then I pass through to a tv so can see it easier and it receives both audio and video. I tried to use my portable GeChick monitor and it will not work with the same setup or with a HDMI splitter. Laptop > Atomos > TV (yes) Laptop > Atomos > Portable monitor (no) Laptop -> Splitter > Atomos + Portable monitor (no) Last edited by Pete Cofrancesco; February 26th, 2021 at 02:57 PM. |
February 26th, 2021, 05:01 PM | #8 | |
* there's no point in recording the 70D's output on the Ninja as the autofocus box cannot be removed for a clean display. |
February 26th, 2021, 05:27 PM | #9 | |
March 3rd, 2021, 08:30 PM | #10 | |
