-   AVCHD Format Discussion (https://www.dvinfo.net/forum/avchd-format-discussion/)
-   -   Please help me decide. (https://www.dvinfo.net/forum/avchd-format-discussion/126808-please-help-me-decide.html)
Ken Hodson July 30th, 2008 03:28 PM
I think for best results you should consider buying Cineform's NEO, and use that to convert the AVCHD into a much faster and less destructable codec. Second of all you need to set your P4 to use dual channel RAM. You are using 3GB now which means you are not in dual channel, unless you have two 512MB and two 1GB sticks(I hope). I am guessing you have three 1 GB sticks? You need two sticks that match, and another two sticks. If you are going to edit with these types of codecs, you need memory bandwidth. Get that P4 into dual channel mode asap!
Roger Bloemers July 30th, 2008 05:16 PM
I have a duo core and edit AVCHD
And I do it with no converting to Vegas 8b. It works just fine. It is just as fast as the HDV I use with my Sony HC1. The AVCHD I use is from my Canon HG10. I have not had any issues with editing AVCHD. Roger :o0
Kaushik Parmar July 30th, 2008 06:59 PM
Originally Posted by Jade Maestre (Post 914060)
I only plan to make SD dvd's. and I heard that HD converted to SD will have a better quality.
Jade Maestre,
How long you will be making DVDs? But now everybody is swiching to Blue-ray.
Kaushik
Steve Mullen July 30th, 2008 07:07 PM
Originally Posted by Jack Zhang (Post 913967)
There's always Cineform to loosen your processor load. Editing intermediate is easier than editing the raw AVCHD files.
YES, BUT -- cineform is wonderful with Premiere because the cineform software replaces Premiere's slow rendering engine. But, if he shoots 1920x1080 he must buy the $1,000 cineform Prospect HD.
With Vegas -- which he has -- you only get a cineform codec. You still have the Vegas rendering engine -- which is not very fast. And, is not really real-time unless you wait for a RAM preview to be generated.
For far less money he can buy EDIUS which has a great intermediate codec, a very fast advanced true real-time rendering engine, and is a far more professional editor than Vegas.
Vegas is only "better" than Pinnacle and Cyberlink. Premiere makes NO sense because you've got to spend the extra $1,000.
Jade Maestre July 30th, 2008 08:32 PM
Steve, which EDIUS package are you referring? The EDIUS NEO, EDIUS PRO, or the EDIUS BROADCAST.
Steve Mullen July 31st, 2008 01:23 AM
EDIUS PRO is all you need. No extras. Just check that your system meets their requirements for HD video. By the way, you can also edit TOD files without conversion. And, it comes with a DVD encoder.
