How much power do you really need?
Hey, new guy here. I'm getting ready to embark into the HD camcorder world, and need to know if I need a new laptop as well.
My question is: how much power do you really need for basic edits of AVCHD? By "basic edits", I mean simple transitions, adding a title and an audio track. That's about as fancy as I get. I'm probably going to use Sony Vegas Platinum, unless somebody has a better suggestion. I'm using Vegas Studio now for my Sony HC96, and it works great. I've searched the forums, and most of the answers are "a lot" of power is needed. Does this mean fast processor, RAM, graphics card, front side bus, etc??? Any help is appreciated. |
The problem is that AVCHD is a hugely processor-intensive compression scheme. Once you get the clips transcoded to something your editor can understand, editing is just like any other clip. Getting there is the problem.
Suggestion: look at the system requirements for the particular edit software you want to use. Adobe lists specs for Premiere Pro and Apple for Final Cut; I don't know but assume Sony does the same for Vegas, with which several people here have said they have great success in AVCHD. Then you'll know for sure what horsepower, video card, etc, is supported and will avoid expensive surprises.... Battle Vaughan /miamiherald.com video team |
The Sony page recommends a 2.8 GHz CPU, and 512 MB RAM. I have a 2.0 GHz dual core with 2 GB RAM and I don't have enough horsepower (but I'm close). A 2.8 GHz CPU (dual core required, quad core preferrable) would do fine for simple work like you describe.
Thanks guys.
Chris - The laptop I'm looking at has: Intel Core 2 Duo T8100 (2.1 Ghz/800Mhz FSB, 3M Cache) 4 gig RAM 256MB NVIDIA GeForce 8600M GT Given that, it sounds like I need to bump up the processor speed. Man, this stuff just gets more expensive by the day. :) |
FWIW my personal computer is a quad Q9550 2.83 ghz, 4 gigs ddr3 ram, Premiere Pro CS4, and it handles avchd ok but I have the feeling it's struggling. The office Macs are quad Intels with 8 gigs and, for the small amount of avchd we get from a couple of Vixias in the equipment pool, they work fine. Believe me, more is better, the specs the software makers put out are the bare minimum the program will function with, in my experience.../Battle Vaughan
Just to confirm Battle's comment, I ultimately got a QX9650 which is only slightly faster than his machine and is a 3.0 GHz quadcore. It handles AVCHD well, but I would say that some AVCHD tasks like rendering still take a lot of time.
Another useful way of speeding up some AVCHD work is to look for an nVidia graphics card starting in their 8800 series and above. These support the "Cuda" technology which can accelerate certain AVCHD software. So far, two programs I am aware of use Cuda, and each gets another 50% speed-up in some AVCHD processing. The two programs I use are Cyberlink PowerDirector 7 Ultimate and TMPGE Express 4.0. A number of people on this and other forums are using Q6600 quadcores for doing AVCHD work and this would appear to be about the minimum platform I would ever consider. On the bright side, a really fast quadcore in the 3.0 GHz speed range was a $2500 purchase 10 months ago and is now about half that cost 10 months later. The newer (October 2008) Nehalem chips from Intel such as the i7-920 through i7-965 are considerably faster, and are driving the cost of the previous Penryn chips down dramatically. Larry |
Thanks for all of the info and advice. Is HDV any less taxing on a system? If not, then I might have to stick with my SD Sony HC96 for awhile. Bummer. :(
HDV is definitely less demanding of computer resources. Yet I still recommend the fastest dual core processor in a laptop you can make yourself afford.
Something worth considering, if you already have some AVCHD-capable software is to download some test clips and play around with them on your machine. See how bad it really is. I *can* edit this stuff on my old machine here, but I have been planning a computer upgrade for a while, and this is just the last reason on the end of a list of other reasons I want a faster computer.
[EDIT: noticed you said you would be getting Vegas MS Platinum, which means you don't have it yet. Just download the trial version of it, download some test clips, and go to town.] If you're doing a minimal amount of editing, and you find your current computer to be *acceptable* then you're set. You *will* get a faster computer at some point, and won't it be nice *then* if you have a bunch of HD footage that you have shot over the years? |
I got hold of some AVCHD clips and tried them in my T7200 2 GHz laptop. I compared it to m2t clips from my XH A1.
Playing from within Pinnacle Studio Ultimate V12 AVCHD: 100% cpu, motion jerky - I wouldn't like to edit like this m2v: 33% cpu, motion smooth Apply a Brighten effect to both 48 second clips: AVCHD: 17 minutes at an average 65% cpu load. m2v: 12 minutes at and average 55% cpu load. I'm about to buy a companion camera to my XH A1. I'm not planning to upgrade my laptop - even though I should - so it looks like I'll be going for an HV30 instead of the HF100. Ian Festival Video and Audio Previews - Festival Previews Ltd |
I use a q6600 and it edits and renders fine. My only problem is when I try to use another monitor to display full screen what I'm editing it gets choppy (the preview)and is unacceptable. Not sure if this is due to my video card or my processor. So far I view at a quarter size preview in vegas and I have no prob.
I use the 6600 quad core but I also use Vegas pro 8.1 which supports 64bit operating systems. I am happy with the level of performance I get with AVCHD..
my sr11 does 16mbps avchd. I have not tried a flavor of avchd that is a higher bitrate. |
Why not just buy the $130 NeoScene from Cineform if you're using Vegas or any other professional type NLE and encode your AVCHD files into the Cineform .AVI's and edit those? Quality is virtually identical, the video is converted to 10-bit 4:2:2 for better processing, and it edits about the same as HDV on the timeline.
Jon |
The end of December I received an extremely good deal at the Sony Style store in Boston for a brand new 16.4” 1920x1080 laptop with a Core2Duo processor, 4 gigs of RAM, a 512MB video card and a Blu-Ray burner. Playing with downloaded AVCHD clips from the HMC-150, I’m noticing that Nero 9 (full version) is very smooth. I have a free trial of CS4 but I’m not able to experiment since I have to purchase it, in order for it to be able to edit AVCHD files. At least the trial version is able to edit files from my A-HD+ camcorder but surprisingly Nero 9 is smoother. |
I can vouch for that. I'm editing all my AVCHD files in CS3 easily - don't have the need to buy CS4 now. I've got Premiere Elements 7 as well which does edit AVCHD, and in the export comparisons I've made, I can't see the difference between the Cineform converted files and the original AVCHD files. |
my tower was only 900-1000 bucks so it's not expensive compared to some other high end computers. Vegas 8.1 is pretty pricey at 400-500 bucks but I don't have to convert the 16mbps AVCHD to anything..
Just to clarify, the major virtues of Nero 9 compared to Sony Vegas when editing and authoring AVCHD are:
Nero is much less expensive, frequently showing up for less than $50. Nero has "smart rendering" which allows it to produce AVCHD disks much faster than Vegas, often 10 times faster, if the clips being assembled are only being trimmed and spliced together. Nero requires a less powerful CPU. Nero can make AVCHD disks on low cost red laser DVD blanks with a low cost ($30) burner which play in both BluRay plaers as well as the Sony PS3. On the other hand, Vegas is a much more competent editor with a lot more features. Larry |
Thanks, Kraig |
Kraig,
It's hard to judge time of converstion because, frankly, every system is so different. I have an i7 based system at 3.0Ghz... Converting a HMC150 2 minute clip took less than 2 minutes, probably less than 1 minute.. So I'd say - in general - it should be faster than real time. Using cineform on AVCHD files I think is *absolutely* the way to go. You need to get those files out of that highly compressed state. I convert everything I shoot into Cineform including HDV as well. Performance on the timeline is dramatically improved using Cineform over AVCHD however their is a small performance hit editing in Cineform over HDV in my experience. Jon |
Jon - thanks for the info. Sounds like Cineform is the way to go...especially for AVCHD. But I'm curious why you convert your HDV into Cineform if there isn't a performance gain?
Anyone here have any experience using AVCHD UpShift from Vasst? How does it compare to Cineform or Neo Scene as for as preformance and quality? I myself am thinking of taking the plunge to AVCHD and am researching as much as possible; My computer config below:
Computer Config by ADK of Kentucky. # ADK Intel - Core i7 920 2.66GHz Quad Core with HT 8meg cache Workstation # Motherboard - Corei7, 12GB/DDR3 1600, 2x PCI, 2 x PCIE x16, 3 PCIE, TI firewire, 6 Sat # Case - ADK - Tower: EATX 7 3.5" bay, 5 x 5.25 Bays up to 13 HDD's with hot swap bay # Memory - Corsair - 2Gig DDR3 1600 1.65v DOMINATOR 8-8-8-24 # Memory2 - Corsair - 2Gig DDR3 1600 1.65v DOMINATOR 8-8-8-24 # Memory3 - Corsair - 2Gig DDR3 1600 1.65v DOMINATOR 8-8-8-24 # Hard Drive1 - SEAGATE - 500G 32Meg Sata II Perpendicular ST3500320AS # Hard Drive2 - SEAGATE - 1000 GB Seagate Raid 0 Array (2x 32 cache 500GB) # Hard Drive3 - SEAGATE - 1000 GB Seagate Raid 0 Array (2x 32 cache 500GB) # Video1 - PNY GeForce GTX285 1024MB: The NVIDIAŽ GeForceŽ GTX 285 graphics card # Video2 - Matrox RTX2 Board Only: Includes the Matrox RT.X2 editing card, audio/video # CD/CD-RW/DVD - LG GSA-H55NK: 22X SecurDisk DVDRW 16x DVD and 48x CD. Dual Layer # Operating System - Microsoft Vista64 Business OEM with COA and disk # Adobe CS4 Production Premium: includes After Effects, Premiere Pro, Photoshop, Audition, # Encore DVD,& Illustrator # 3 - Dell 24" Flat-Screen Monitors How would you rate my computer as far as ease of use of the AVCHD .mts files editing natively in Premiere Pro CS4? Thanks guys. P.S. I am also looking for sample AVCHD .mts files that I can download and use for experimentation; would like something longer in duration, say 15-25-30min., etc. Please let me know if you can aid me is this regard. |
| All times are GMT -6. The time now is 11:24 AM. |
