-   AVCHD Format Discussion (https://www.dvinfo.net/forum/avchd-format-discussion/)
-   -   AVCHD Editing with CineForm (https://www.dvinfo.net/forum/avchd-format-discussion/91201-avchd-editing-cineform.html)
Derek Weiss April 21st, 2007 08:27 PM
I have been using Nero to convert AVCHD to Cineform with some success.
1. Drop clip on Nero time line.
2. Click export.
3. Choose AVI export template.
4. At "Video Compressor" choose Cineform HD Codec V2.5
5. Configure as you please.
6. Export.
Works most of the time. Funny thing I'm learning about Nero, is for some reason, some AVCHD files it will not encode. Others work fine, but some are cursed. I get "run time" errors on some files. It's annoying, and can stop you cold in your tracks. But for me, for now, it works better than the Elecard.
David Teubner June 21st, 2007 04:07 PM
Originally Posted by Rick Baumhauer (Post 662510)
At that point, I copied the mcavcvd.ax file that is installed by the Elecard AVC plugin (you can find it in Program Files\Common Files\Elecard) into windows\system32, and registered it by hand with regsvr32. At that point, everything started working, and GraphEdit showed the Main Concept/Elecard decoder for all of my AVCHD files.
Rick
Thank's very much for that advice Rick. It fixed the problem that I'd been tearing my hair out over for about 2 days.
