-   Avid Editing Family (https://www.dvinfo.net/forum/avid-editing-family/)
-   -   Singular Software PluralEyes (https://www.dvinfo.net/forum/avid-editing-family/490343-singular-software-pluraleyes.html)
Jeff Murray January 18th, 2011 04:00 PM
Is anyone using this software with DSLR clips (ie no timecode) and if so have you found a way to make multicam mode work with the synced timelines?
From what I can see it is only possible with a group of clips that have overlapping start and/or finish times. Sequences in chronological order with multiple non contiguous start and finish times could not be grouped via the in and or out points.
I have edited a sequence with cuts in V1 and V2 (and dropping the play clip on the higher timeline) - but the features of multicam ie: point and click for cam selection look neat and fast. Also later being able to change cams with the up and down arrows and/or choose another audio track may come in handy if the clips can be grouped.
I did read a suggestion about changing the Auxilliary timecode on each clip and using that for group sync - but that is way to manual and time consuming.
With regards
Jeff
David Parks February 3rd, 2011 10:23 AM
Jeff,
Changing the aux TC on each clip is the only way i can see it working for multicam. While more time consuming, it is still less pain than manually syncing the audio on each clip. It is all relative in the end.:)
