What looks like excessive artifacting on a Plasma is in fact the pulse width modulation that it uses to generate all it's greyscale levels (really the plasma pixel is binary - on or off, so it needs to be modulated to produce different visible levels) interfering with movement in the image and the human visual system.
And you're right, 1080i60 should convert to 720p60 by splitting each field into a 540p60 frame, then upscaling to 720p. Given all modern displays are inherently progressive, 720p is displayed on a 1080p screen by simple upscaling. Graeme |
*As feared even with Verbatim DL disks it doesn't take long for the same disk in the same player to start having playback problems. Its like after burning, the reflectivity steadily degrades for a while reducing compatibility with time. DL BR will need so time to convince me its a safe delivery format. |
I was of course referring to multi-layer replicated commercial disks (movies) and not burnt disks. I thought Sony had already been using dual layer BD-R on XDCam? Maybe not.
| All times are GMT -6. The time now is 03:57 AM. |
