-   Blu-Ray Authoring (https://www.dvinfo.net/forum/blu-ray-authoring/)
-   -   blu-ray burners for editing... (https://www.dvinfo.net/forum/blu-ray-authoring/94138-blu-ray-burners-editing.html)
Mark Leonard May 15th, 2007 03:43 PM
ok is it safe to buy the latest blu-ray burner and start burning projects for customers to watch on their home blu-ray players?
Carlos Rodriguez May 15th, 2007 07:14 PM
I haven't heard of any issues. I know Philips has one cheaper than the Sony, as well as Lite-on, which is the least expensive of the bunch. The lite-on is faster I believe, because it uses SATA as an interface.
Gints Klimanis May 15th, 2007 07:58 PM
If you're wary of dropping $600-1000 on a BlueRay burner and then seeing a new one come out for $400 with twice the writing speed, consider using DVD DL :
authoring blu-ray / hd-dvd on a regular dvdr/rw burner:
http://www.emedialive.com/Articles/R...rticleID=12157
Mark Leonard May 16th, 2007 06:47 AM
money is no problem, just want to make sure that if I buy one I'll be able to author movie that can play on regular blu ray players.
Don Blish May 21st, 2007 05:32 PM
I've had a Sony BWU-100a since last August. It took till more recently for the software to clarify. The software bundled with most drives is limited. There are just a couple of sub-$10,000 packages that will author discs with menus and will play on available players. I use Roxio DVDit Pro HD ($500) and it makes "BDMV" projects that look to players just like commercial releases, albeit with an empty digital rights management folder. The projects will play on Panasonic, Pioneer, PS3 and Sony players (the latter with 3/12/07 v1.55 firmware). There is also a procedure for putting short projects (20-30 min) onto cheap red-laser DVDs that play in the aforementioned if you keep the bit rate to 20Mbits or so.
