C100: Any interesting custom Picture Profiles out there? at DVinfo.net
Old January 31st, 2013, 03:10 PM   #1
I'd be very interested in a midway profile between EOS standard and Wide Dynamic Range if anyone had one?
Dan Burnap is offline   Reply With Quote
Old January 31st, 2013, 05:09 PM   #2
Re: C100: Any interesting custom Picture Profiles out there?
We generated a lot of CP files for the old XH series... share your presets and let's do it again for Cinema EOS!
Old February 1st, 2013, 06:30 AM   #3
I ported the AbelCine C300 Picture Profiles to the C100 which can be found here. Admin note: Files attached below.
File Type: cpf CPICT402.CPF (156 Bytes, 2224 views)
File Type: cpf CPICT403.CPF (156 Bytes, 1341 views)
File Type: cpf CPICT404.CPF (156 Bytes, 1280 views)
File Type: cpf CPICT405.CPF (156 Bytes, 1278 views)
File Type: cpf CPICT406.CPF (156 Bytes, 1242 views)
File Type: cpf CPICT407.CPF (156 Bytes, 1312 views)
File Type: cpf CPICT408.CPF (156 Bytes, 1270 views)
File Type: cpf CPICT409.CPF (156 Bytes, 1437 views)
Old February 1st, 2013, 06:30 AM   #4
I also have setup the C300/Arri Alex matching from this Art Adams article as a profile you can download here. Admin note: Files attached below.
Just an FYI, I set the gamma to Cinema2 because Adams, in a separate article, mentioned that he felt it held the highlights better. Sharpening is also set to the minimum.
Your mileage may vary, of course. These are all originally intended for the C300, and reports differ on how close the two match out of the box. I would say most differences would be slight.
But feel free to contribute to the "Buy Gary Huff a X-Rite MSDCCSG Digital ColorChecker Fund" if you find these helpful! :-D
File Type: cpf CPICT501.CPF (156 Bytes, 1232 views)
File Type: cpf CPICT502.CPF (156 Bytes, 1140 views)
Old February 2nd, 2013, 11:42 AM   #5
you could have a look at these...
TRUvid2 = CPICT301.CPF
TRUcine = CPICT302.CPF
TRUlog = CPICT302.CPF
Admin note: link replaced with actual file downloads
File Type: cpf CPICT301.CPF (158 Bytes, 1253 views)
File Type: cpf CPICT302.CPF (158 Bytes, 1195 views)
File Type: cpf CPICT303.CPF (158 Bytes, 1118 views)
Pippin Rush is offline   Reply With Quote
Old February 2nd, 2013, 12:46 PM   #6
What I meant to say is, please share your settings right here on the forum -- the setting values and the files themselves. We can host the files directly, no need for off-site download links, zip files or anything other than the actual .CPF files that go straight to the camera (plus the details about the settings themselves, preferably!) -- thanks in advance!
Old February 3rd, 2013, 08:57 AM   #7
The TRU picture profiles are great, but they need to be ported to the C100, as here.
Note: I would gladly attach the CPF files themselves, but I currently do not have privileges to do so, so I appreciate the adjustment of the post. Thanks!
Old February 4th, 2013, 04:36 PM   #8
Hey Gary, how did you port the files to the C100, just a manual input? Thanks for sharing.
Andrew Alden Miller is offline   Reply With Quote
Old February 5th, 2013, 05:42 AM   #9
Yes. Thanks to Texas Media Systems, I was able to load them into a C300, then just documented the values.
There are differing reports as to how close the C100/C300 match up, with some reporting some tweaking needed and others reporting they match exactly, so your mileage may vary.
Old March 9th, 2013, 03:36 PM   #10
Here is a link to Alan Roberts analysis and recommended settings for the C300:
http://cpn.canon-europe.com/files/ne...n_EOS_C300.pdf
Not surprisingly, he likes the C300. The C300 and C100 are so similar that I have adjusted a custom profile to reflect his recommendations. He has a set for video (Rec709) and "film" uses. I applied his video settings, added a bit more gain to the color matrix (+10), and boosted the low key saturation a little (+8) to provide a slightly more saturated look. His sharpness settings are near the default. Since the C100 uses AVCHD which may create more sharpening artifacts, I turned sharpening all the way down to -10. This still gives me plenty of resolution and it avoids artifacts that I see in the high-detail scenes I like to shoot. The result is a look that is fairly faithful to reality and not in need of as much post work as some of the other profiles.
I have seen some beautiful footage shot by others with the EOS Standard, but the high-detail scenes I like to shoot have a lot of muddy artifacts on small branches, pine needles, and grasses when I have used this profile.
Anyone else have some new thoughts on custom profiles?
Cheers,
Pat
Pat Reddy is offline   Reply With Quote
Old March 11th, 2013, 08:38 AM   #11
Pat - any chance you could you share your scene file? It sounds close to what I'm after.
Dave
Dave Mercer is offline   Reply With Quote
Old March 30th, 2013, 03:07 PM   #12
Hi Gary Huff
Brilliant job!
Cud u please port Paul Joy’s C300 Picture Profile to the C100
Canon EOS C300 Custom Picture Profile | Paul Joy – Freelance Filmmaker
that wud be awesome =D
Thanks a Million
Diego Perrona is offline   Reply With Quote
Old April 7th, 2013, 08:26 PM   #13
These ones don't work on the C100, Gary will you please port them =)
Old April 7th, 2013, 08:33 PM   #14
Originally Posted by Diego Perrona View Post
Hi Gary Huff
Brilliant job!
Thanks a Million
I've already have this Picture Profile for the C100 by the way.. cheers
Old April 9th, 2013, 07:39 AM   #15
I did, but apparently there was a mixup with the attached files. The real ones are here.
Gary Huff is offline   Reply
