Step-by-step MPEG Streamclip at DVinfo.net
Canon EOS Crop Sensor for HD
Old January 15th, 2010, 01:16 AM   #1
I have a PC and need to convert my 7D 24p (and 30p) files to an avi to avoid stuttering in Premiere Pro when editing. I'm not doing it right somehow on mpeg streamclip. Can someone post a step by step on how to do this? I would really appreciate it. Thanks
Erwin Layaoen is offline   Reply With Quote
Old January 15th, 2010, 01:19 AM   #2
MPeg Streamclip is not an effective tool to create AVI files. And yes, I know it has options there for AVI.
Old January 15th, 2010, 01:22 AM   #3
or what do you recommend to what i should convert it to using mpeg streamclip for editing purposes on premiere pro and avoid stuttering?
Old January 15th, 2010, 01:36 AM   #4
I wish I had the answer for you. Others seem to find Cineform ideal, but it's not a free option. I am unaware of how Premiere handles quicktime (.mov) files. If it does handle them well, then there are some very good options to be had.
Old January 15th, 2010, 01:43 AM   #5
The answer to your question is here:
http://www.dvinfo.net/forum/canon-eo...-workflow.html
and here:
http://www.dvinfo.net/forum/canon-eo...ttering-4.html
Cheers!
Mauricio
o--------------------------o
Life is short.. Live it!
Mauricio
Mauricio DelaOrta is offline   Reply With Quote
Old January 15th, 2010, 11:31 AM   #6
As Mauricio pointed out.... this is a topic of wide interest and has been generating a lot of comments.
I recently purchased my own 7D, and was dismayed by the stuttering seen when simply playing the quicktime files (either from the flash card or from a hard drive)
I have been waiting for the 'official' word from a Canon tech I have been in touch with, however this is what I believe to be the situation as I understand it now:
The .mov files which come out of the 7D and 5DMKII are not intended to be viewed or edited without conversion. Apparently, while the files carry the '.mov' designation, they are not 'regular' quicktime files and do not play well with quicktime or other playback apps or NLE apps. This is something I have heard repeatedly, so it does seem to be the case... however I have been somewhat surprised that even simple playback will result in stuttering.
I'm on a mac, so I cannot speak to what transcode choices work best for PCs, but for macs it seems ProRes in compressor is the way to go. When I hear back from my contact at Canon, I may have more to share here.
www.zooprax.com
Derek Reich is offline   Reply With Quote
Old January 15th, 2010, 11:56 AM   #7
This really doesn't have anything to do with Canon.
the .mov on a Mac is simply a wrapper. In the case of the 7D files it wraps H.264 to make it a quicktime. But if your computer is fast enough and configured correctly you can play those files fine directly from the CF card.
The same is true for .avi on the PC, it is a wrapper that can also contain a myriad of codecs.
So chances are if you can't playback the files smoothly then your computer is either too slow, configured incorrectly or both.
I'm using a first generation Intel MacPro 266 MHz with a Radeon HD3870. H.264 is very "graphics" intensive, the faster your graphics card and the more VRAM the better.
Chuck Spaulding is offline   Reply With Quote
Old January 15th, 2010, 01:25 PM   #8
Hi, Chuck
I have heard this, too.... however on several mac platforms I have been unable to playback the files without transcoding them. (too much stutter) My personal computer is a MBP 2.6GHz, which I would have thought was plenty fast just to playback the quicktime files, but obviously something's not clicking. Also, a client's edit station reported the same issue, but I don't know what their configuration is there. They're editing daily for a major network and I assume it's plenty powerful and up to date.
When you mention 'configured incorrectly', what are you referring to?
www.zooprax.com
Old January 15th, 2010, 04:53 PM   #9
Why so? Is it a speed or quality issue?
Old January 15th, 2010, 06:24 PM   #10
It's actually pretty fast. At least in a PC it does the work of transcoding fairly well. On a Mac on the other hand, AVI is not very well supported.
If for any reason you don't like mpegstreamclip and are not planning on buying Cineform (which has it's own high quality codec) there are a couple of other options like tmpgencode.
However after trying a couple of them, I would still pick the software in the following order: 1. Cineform, 2. Mpegstreamclip. 3. something else (maybe mpgencode).
Cheers!
Mauricio
Mauricio
Old January 15th, 2010, 08:56 PM   #11
Because it cannot access all the myriad of codecs. Especially the high quality ones. They simply don't show up as options in Mpeg Streamclip. Rather distressing too, because I prefer to do my batch transcodes in that program.
So unless you want to transcode to uncompressed, there really isn't a good quality AVI option to be had.
Old January 15th, 2010, 11:50 PM   #12
So frustrating. Before I surrender and purchase cineform neoscene, I want to give Mpgeg streamclip another try with your help. I am using a PC. Here's the process I am doing. The purpose for the file would be for Vimeo/You tube/Web use.
In Mpeg streamclip
= open canon .mov HD 24p file from 7D
= File, Export to Quicktime, dialog box opens
Compression: AVID DNxHD Codec
Color levels: 709
Quality 100%
1920x1080 (16:9)
Interlaced Scaling checked
Field Dominance: Upper field First
Rotation: No
Zoom: 100
= Make Movie
After transcode process is done, I then grab file into CS3 Adobe Premiere Pro. Much better but still with very slight stutter which I can work with. I make my edits then proceed with render process:
In Premiere Pro
= File, Export, Movie
= Settings?
This is where I'm not sure what to select in General, Video, Keyframe and Rendering, and Audio settings as final movie file. Please help.
thanks
Old January 16th, 2010, 12:05 AM   #13
Oh dear goodness...
Ok, in Mpeg Streamclip,
Open 7D file
Choose Avid DNxHD.
Click Options button
Color levels RGB
Click the tiny sliver of a box at the bottom of the window (this is a bug). It will allow you to select the bit rate for DNxHD. Select 1080/24p DNxHD 175 10-bit. Or select 1080/24p 115 8-bit. Experiment with both.
Hover over the Uncompressed selection and the OK button will appear. This is another bug. Click OK.
Set quality to 100%
Uncheck Interlaced Scaling
Select 1920x1080 unscaled
Click "Make Movie"
Once you are done in Premiere with your edits, you need to render. I am not familiar with your version of premiere but in general, when going to Youtube or Vimeo, you will want:
1280x1080 video. You shot 24p so upload 24p
Audio is 48KHz 16bit, and bit rate should be 192Kbps
Video Bitrate should be about 5Mbps.
Video Codec should be mpeg4/h.264
In Mpeg streamclip
Color levels: 709
Quality 100%
1920x1080 (16:9)
Rotation: No
Zoom: 100
= Make Movie
In Premiere Pro
= Settings?
thanks
Old January 16th, 2010, 01:20 AM   #14
thanks perrone!
looks like the bug was a problem and was auto selecting the wrong settings. your instructions was very helpful. the stuttering significantly improved but still present and workable. not at 100% smooth, but around 90% which is way better than before.
the problem now is after rendering it's not widescreen (black space on sides). on rendering, i selected quicktime, mpeg4, D1/DV NTSC widescreen.
Update:
on render, selecting D1/DV NTSC (0.9) 8:5 makes it widescreen (black bands on top/bottom) and looks like the original. Square Pixels removes the black bands overall.
Old January 16th, 2010, 02:34 AM   #15
Curious...
Select 1080/24p DNxHD 36 and see if that stutters in Premiere... wondering if it's a quicktime issue, or a bitrate/cpu issue.
Perrone Ford is offline   Reply
