-   Canon EOS Crop Sensor for HD (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/)
-   -   focussing with the 550d (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/480860-focussing-550d.html)
Rob deJong June 24th, 2010 05:21 AM
Hello,
It's been a while since I made a topic from this, but now maybe some have more experience with the dslr's.
I have problems focussing manually with the 550d. I cannot work with the ZACUTO, because I always have the camera below my head. I am using
LCD Angle-changing Viewfinder A1K For Canon 5D Mark II - eBay (item 280431821070 end time Jun-28-10 19:36:19 PDT)
but as with the lcd itself the mirrors provide a too small picture to be sure of focus. For using focus assist, in general, I do not have enough time.
A while ago, people on this forum were suggesting video glasses, but these are expensive. I will buy if I know what to buy and only after hearing about your experiences with it. Has somedy tried video glasses already in combination with a dslr?
Rob
James Donnelly June 24th, 2010 10:40 AM
The video glasses I have seen (£100-£150 on ebay or at computer fairs) are not very good quality. Just about OK for movies on the go, but forget it for focussing. Most of the cheap ones have 320 lines.
For external monitoring, you are limited by the SD output of the camera while recording. As far as I can tell, the only thing that would work well for you would be something based on a mirror and loupe, but I've never seen one.
Rusty Rogers June 24th, 2010 11:13 AM
I could not imagine the mirror gizmo working for focus. The Z-Finder (or equivalent) is the only real way to go.
If you always shoot below your head, perhaps you should simply lower your head.
Khoi Pham June 24th, 2010 11:14 AM
If all you do is shoot below your head then you should get the Pan. GH1, it has articulated lcd.
Rob deJong June 24th, 2010 01:30 PM
Nobody seen a Z-finder with an angle?
Rusty Rogers June 24th, 2010 01:48 PM
Remember, the #2 purpose of a loupe is to add a third point of contact for a steadier shot!
Chris Barcellos June 24th, 2010 04:31 PM
Separate monitor, really the only way to go. Even a cheap small HD monitor fed with an HDMI cable, will allow you to set focus at your begining and ending points. I have a 7inch marshall that works pretty well, and I mount that on my rails this amount that allows an adjustement to the angle of view.
Rob deJong June 26th, 2010 08:13 AM
Which 7 inch Marshall is that precisely?
