-   Canon EOS Crop Sensor for HD (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/)
-   -   Recently Purchased a 7D (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/484365-recently-purchased-7d.html)
Anthony Bernard September 6th, 2010 07:57 PM
I recently purchased a 7D that should arrive Thursday. I have a documentary shoot coming up this weekend and was curious if there are anythings I should watch out for. I bought a wireless lav with it too so if anyone has any suggestions for recording audio in particular as well as video function issues I may run into it would be greatly appreciated.
Cheers
Tony
Perrone Ford September 6th, 2010 09:56 PM
I would strongly suggest you use a different camera. Frankly, there is no way you can be up and running effectively on a 7D in the amount of time you've got unless you are VERY familiar with using an HDSLR to shoot films with.
What glass do you have?
What mics do you have and how do you plan to record with them?
How are you going to focus the camera?
Will the recording time limit affect your shoot? If so, how will you mitigate it?
Do you have a stabilizer for the camera or will you be on a tripod for the whole production?
How do you handle redundant data dumping gin the field?
How are you going to edit the footage?
So many things to work out.
Anthony Bernard September 6th, 2010 10:35 PM
I will have a canon 50mm 1.8 and a 28-135 3.5. The zoom lens is the kit lens. I know that since it isnt a fixed iris zooming in and out while rolling wont be an option, but since I was on such a short time limit and budget it was my best bet at the moment for a variety of focal lengths.
Tripod wise I have a manfrotto 05SX w/501HDV head. I will be building a steadicam rig for any non-tripod shots.
Focusing will probably be manual if thats what you mean. I do not have a focus pull setup yet and I figure this segment of the doc shouldnt require a lot of intricate focus pulling. Again like you said I wish I had more time to work with the camera. I have worked with the 5 and 7D before, but in a relatively limited capacity. I will be spending every second with it for the few days I have before the shoot.
I have an audio technica lav kit that connects via an 1/8" connection so I am hoping it will work fine with the camera. If recording on camera isnt the best then we have 3 macbook pros that I will have on location for dumping video and other issues so I can just record with garage band or soundbooth or something and mark it for sync later.
Editing wise I have Final Cut Studio as well as Premiere CS4. I dont believe the time limit (according to Canon 12 minutes) will affect anything. We maybe doing a couple interviews, but I am trying to get access to an ex-1 as well just so that the 7D will not be the only camera on location.
Also I did order a second battery just to be safe. How long do you usually get out of one battery?
I really appreciate the help
Perrone Ford September 6th, 2010 10:55 PM
The camera has automatic gain control. Which makes it wholly unsuitable for recording anything but "guide track" audio. There is no way I'd put it into any production. I'd suggest you pursue your alternate solution as quickly as possible.
Ok, sounds like you're all set there.
I have the T2i, and have worked with the 5D. I have not worked with the 7D enough to give a good answer, but maybe one of the owners will chime in.
I won't sugar coat this. You're on a VERY steep learning curve here. Everything from dealing with dynamic range, to potential overheating issues, trying to focus accurately on the little LCD on the back (perhaps while on the go), and all other manner of challenges. To top that off, you've got glass that is absolutely awful for trying to focus manually.
Like you said, spend every waking moment you can with the camera and understand all the basics, including picture styles, and the quirks. Go through EVERY setting and turn off any automagic settings that might bite you later. I've been where you are. We received a 5D three days before filming a short last year and the DP/Operator had never had ANY SLR before that. I was supposed to be gaffer, but ended up DPing a lot of the picture out of necessity.
I wish you the best.
Ted Ramasola September 6th, 2010 11:12 PM
I would echo Perrone's apprehension given that you have little prep time and that you are recording sound.
When I first used my 7D for a paid job it was first a 2nd cam not doing audio. Later when it became A cam I had already mastered its quirks - I STILL won't use it for audio other than what perrone said, as guide track.
That said, audio recorded in-camera is of limited use in a doc. I even had a attenuated cable made by our tech department but still the agc wrecks havoc on your sound.
You would need a portable audio recording device like a tascam, in my case a zoom where you can hook up your lavs.
Next is the battery. To get you by a day of shooting, you'd be safe with 4 batteries, a little tight with 3, hardly getting by with 2.
You definitely need something to 'enhance' your LCD viewing- I made mine using a magnifying glass.
Without one, you'd be getting a lot of off focus and soft shots.
Good luck.
p.s. seeing its your 1st few posts, welcome to the forum.
Anthony Bernard September 6th, 2010 11:13 PM
Ok so when the equipment gets here I will plan on testing the lav with recording to the laptop. Im not even going to bother with trying the camera audio input since it has auto gain.
I am VERY nervous about focus being an issue. Do you think it would work if I actually measured and marked focal distances on the lenses and then pulled focus day of just to be a little more accurate? (As long as they arent the type of focus rings that just spin round and round forever)
I may also look into overnighting a hood/viewfinder setup for the lcd to make seeing it a little bit easier. If I can pull together extra funds that is.
Anthony Bernard September 6th, 2010 11:17 PM
Thanks for the heads up on the DIY Loupe link. That might be a big help. And yea I will definitely be recording audio to a different device. I am now worried about the battery may have to ship another one or two...thanks a million for the heads up on that too though.
p.s. thanks glad to be here!
Ted Ramasola September 6th, 2010 11:31 PM
About the focus, in a docu scenario, I would strongly suggest using constantly the magnify button as your "focus assist" to confirm you have your target in focus. Good thing that you can move box that indicates the area to magnify.
Doing so with practice will give you better chances of getting things in focus.
Anthony Bernard September 6th, 2010 11:40 PM
Awesome. Thats how I will do it then.
Liam Hall September 7th, 2010 02:55 AM
Good advice from Ted and Perrone. I'll add, buy some ND for your lenses.
Keep it simple and you'll be fine. Good luck:)
Manus Sweeney September 7th, 2010 03:07 AM
If you have easy access to power during the day you should be able to manage with 2 batteries by recharging when empty.
Jon Braeley September 7th, 2010 05:57 AM
What is the subject and the purpose of the documentary?
Do not be put off by the obsessing over technical stuff. If you have a compelling story or something to say you can shoot it on an iPhone and people will watch. So go ahead and shoot - don't let anyone break your confidence!
If you are shooting over one weekend it must be a short film right? It would help if you gave more information. Beware of a DIY steadicam - use the tripod as much as possible. You don't have time to practice hand-held. I would have spent my money on a good shotgun fixed to the cam if you do not have recording equipment. You can get useable sound this way.
Other than that go for it.
Olof Ekbergh September 7th, 2010 06:16 AM
The EX1 is a great idea, especially during the interviews. It can do the audio fine. I would suggest using a clapper on a slate with a large digital stop watch, for syncing. Just shoot it with both cams every time you start a new shot. You could set the EX1 on covering medium shot and then use the 7D for multiple angles and frames. Try to not move too much though, you will regret it in editing.
I find using the 5x and 10x focusing works very well. I use it on my 5DmkII and 7D all the time. Follow focus helps a lot. The Cavision setup is reasonable priced and quite good. And I believe B&H have them in stock.
I would definitely have at least 4 batteries on hand. I have AC in my vehicles so I can charge batteries there, but a lot of times you just forget and no power will stop you dead.
I think you will do fine. I always find that the way to really learn all new equipment is to prepare as well as you can, by testing and practicing, but you really learn when shooting for real.
One thing I would definitely do is hook the 7D to a good evaluation monitor and really learn how to get exposure and focus right. A large HDMI monitor will do, but ideally use a pro evaluation monitor you trust. The histogram is very good for setting exposure. Also get used to setting the white point manually (custom). This is very important if you shoot with 2 cams.
Spend some time with the PP settings. If you want to match the EX1 and the 7D, I would use Doug Jensons (Vortex Media) settings on the EX1 and turn the sharpness and contrast all the way down in the 7D use neutral as style (whatever it is called) and turn the saturation down 1 or two notches.
Let us know how it goes, nothing like trial by fire. If you use the EX1 for the interviews as A-cam it will be much easier. And take some of the pressure off.
Enjoy, the 7D is a great tool!
Ted Ramasola September 7th, 2010 06:21 AM
Olof,
just a heads up, I don't think the OP mentioned he has an EX1, just the 7D, you must have been lukin at Perrone's sig. ;-)
Ted
Olof Ekbergh September 7th, 2010 10:57 AM
I read this from post #3 by Anthony Bernard. It is easy to miss. I had a hard time finding it the second time, and I was starting to wonder where I got it from.
Jon Fairhurst September 7th, 2010 11:38 AM
The ease or difficulty of using a DvSLR depends on the subject and your style.
If you want a "straight" documentary where you cover events linearly and all in focus, a single DvSLR is not the right tool. On the other hand, if you are more creative with your story telling, are willing to use out of focus shots as an effect, and are willing to have the video give an impression of a person, place or thing, a DvSLR is perfect.
Richard D. George September 7th, 2010 12:48 PM
Jon:
Agreed, but not in the time-frame originally stated, and with the apparent experience (with DSLR's) level.
This is crazy on several fronts.
Anthony Bernard September 7th, 2010 01:16 PM
This is going to be a graffiti documentary. I plan on shooting it in a style similar to Doug Prays "Scratch" He used a lot of out of focus and non-traditional doc style shots. I am hoping the 7D will be a good option for this. I am also in the process of building a glidecam for some stable moving shots possibly. Since I was given such a short notice on this I plan on doing my best. I'll let you guys know how it comes out.
Jon Fairhurst September 7th, 2010 03:14 PM
A DvSLR is a great choice for a graffiti doc. It's more about style than linear documentation. And graffiti is timeless. It's not like filming a wedding where "you may now kiss the bride" only happens once.
Some ideas:
* A super-wide lens or fisheye will provide attitude. The 5D is the better choice, but the 7D can work.
* A slider, dolly, or jib will give you camera motion. They take much less skill than a Steadicam. Even an old wheelchair can help provide smooth camera motion. Don't just pan with a tripod. You can get that look by panning and scanning a photo.
* If you can get an Intervalometer, you can do timelapses of people tagging by shooting photos, rather than video. The image quality can't be beat.
* Make it about the people, not just the art.
Best of luck!
Anthony Bernard September 8th, 2010 01:39 PM
just found out today that the shoot has been pushed back to the 14-19. luckily i will have a little more time to plan things out and get used to the camera.
Jonanthan Carr September 11th, 2010 12:04 PM
A few tips on shooting a documentary with the 7D
I didn't read the all the posts so sorry if I'm mentioning the same stuff but here are some of my suggestions.
For lenses fixed aperture Zooms is a must since your gonna need to be wide open most of the time. Something like a Canon EF-S 17-55mm f/2.8 IS USM Zoom Lens or Canon Zoom Wide Angle-Telephoto EF 24-70mm f/2.8L Zoom would be good. Of course any prime Lens will be faster, sharper, easier to pull focus, and have less breathing.
For ISO I wouldn't go past 800 with daylight balanced light. Heavy tungsten light, I don't like going past 640.
For sound, thats not my department but I used the ZOOM H4n as the onboard mic. Much cleaner, as has 3 imputs, 2 XLRs, 1 1/8th inch. Not bad for 300 bucks.
Watch out for fast camera moves, stripes or anything that can cause moire etc...
Cheers
Jon
Anthony Bernard September 17th, 2010 10:30 PM
Doc shoot is tomorrow. I think I have developed a pretty good "look" for shooting it. I have been experimenting with picture profiles and I have settled with a super flat look like the one on the link posted earlier. I have tested it with Magic Bullet and have gotten some beautiful results.
As far as focus the zoom function will help immensely with interviews since I can pull my focus and zoom to check it and then record. I have also been using this to practice focusing manually and I have become pretty confident with it over the past week or so.
Also I built a hand held rig for it. Links bellow. It infinitely improves the steadiness of the handheld shots. (Rig cost about $50 bucks and parts were purchased mostly from Lowes and Walmart.)
http://sphotos.ak.fbcdn.net/hphotos-..._6829558_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-..._7078196_n.jpg
Michael Dalton September 18th, 2010 10:22 PM
t.
Don't let this sway anyone, it's a tool, and if your bright you'll figure out what will and wont work!. The only difference is you have to use restraint, don't just go hand held. I jumped from an HVX200 to using 7d's in my series, and they have worked great. I use a tripod 90% of the time, and my shows actually look better. The auto gain is NOT a no go, it just means at times you MAY run into audio clipping issues and if you working loud areas the results are less then desirable audio. Some recoverable and some not. Only .01% of my audio has been bad. It does add time for the audio guy to adjust the effects of the auto gain. My sound guy is top knotch, and say the quality is certainly passable. Just put a good mic on there. I use RODE NTG2. Stay away from crap video mics. USE A WIND sock if it is outdoors... actually always use one!
For hand held stuff I use the stedicam merlin.
