-   Canon EOS Crop Sensor for HD (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/)
-   -   Few (dumb) ML questions... (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/489819-few-dumb-ml-questions.html)
John Vincent January 6th, 2011 02:28 PM
- Is ML still in pre-Beta?
I've seen lots of new versions on the past 2-3 months, but not sure if it's to the point of using for someone who's not technically very proficient with computers.
- If not in Beta, should I wait? I nothing urgent at the second (although I am shooting a low budget feature in the spring)...
- Do you need to re-boot the camera on every new use, or is ML to the point where when the cam's turned on, it's there, ready to go?
- Obviously the manual audio features/zebra stripes have every day practical use. But I haven't read anything on whether or not the larger bit rate options affect the final image. Anyone with experience on this issue?
- Although bricking the cam is obviously always a potential, has it actually ever happened to any one?
Thanks for any help!
Arne Johnson January 6th, 2011 03:17 PM
I have some similar questions, having a little trouble untangling whether/when it's ready for primetime. On the wiki, it does say it's pre-Alpha, so there's that.
Jackson Hager January 6th, 2011 04:31 PM
Yes, it's pre-alpha even, according to the site.
I see no reason to. It only makes small, reversible changes, so no reason not to try it out.
Do you need to re-boot the camera on every new use?
No.
Fewer blocks in the shadows, but I don't use Qscale often. For most situations it doesn't make too much of a difference for me. Maybe if you do a lot of post work, it would help.
The directions are really good. It's a bit tricky on a mac, but for PC it is literally "download these things" "click these buttons" "drag files onto card". If you can run a camera, you can install ML.
John Vincent January 7th, 2011 03:07 AM
Thank you Mr Hager... guess I'll give it a go.
Osmany Tellez January 7th, 2011 08:41 AM
Follow up
I have a follow up question ...
I use the cam for Video and also for photo...can I just switch between ML and canon easily? or once I put ML on it will have to use computer to take it off?
David Quakenbush January 11th, 2011 09:16 AM
You can shoot stills with ML active. It also adds many useful features for still photography (trap focus, DOF information, etc). ML does not interfere with any of the features/functions already in the camera as it comes from Canon so it isn't something you have to "put on/take off" constantly. Go read the wiki.
Luke Gates January 11th, 2011 10:45 AM
ML is great for video and stills alike. If you do want to take it off it's as simple as formatting your sd card.
