White Balance
I read a lot of things about how to set the White Balance on the 60D or 550D.
When we shoot only video in different situation I woul like to know how you suggest to set it. I use all in manual and for the White Balance normally i take a picture to something white, I go in the menu and I confirm that I want this pic for white and I shoot. Is the best way?Do you use it or you have a paper 18% gray that you put in front of camera to take a pic? Please I need to understand the best way Second question, wich preset you use to have the best color and contrast with the 60D and 550D? Thanks a lot |
Re: White Balance
I struggle with white balance. Filming events I use a tungsten preset and deal with it in post, or set it manually. You can only change it in increments of 100, so most of the time you cannot get an accurate white balance as it will be in between. The problem with this is that it doesn't have any control over green/red, so under fluorescent lights you are in trouble. When you use the gray card, it does take into account the red/green shift, but it makes your image neutral. Indoors a neutral white balance can seem to cool. I bought a white balance card with a warm bias, but with the pace of events, never get around to using it.
If you have time, one of the members in the forum uses the product below on a slate. Datacolor SpyderCube review I'm hoping this is just a temporary issue. From what I've read, the next round of dslr's might have some basic form of a type of raw format that can be better manipulated in post. After effects getting the slider features of lightroom. I don't know if I don't have enough color correction skill, or if its the codec that just makes it look unnatural. |
Re: White Balance
For the picture setting, it seems that most users recommend using a custom preset.
It seems like the popular thing to do is put the sharpness as low as it can go, and notch the contrast and saturation a few ticks below 0. I like to keep my contrast at -3 and my saturation at -1. |
Re: White Balance
Thanks a lot...and for white balance how do you set it?
Re: White Balance
Also struggling here with the white balance indoors, if i custom to a plain white paper, our room looks a cream colour and it is coffee colour?? if i use auto white balance it goes to brown if i set the k balance to 2900 it looks perfect.... if i say am filming the first dance in lowish light say 50 shutter 50mm 1.8, iso no more than 1600, is it best to use the k white balance and set it to what looks good??? also im struggling to match the hv40 with my 60d, i might have to use the 60d only for the first dance or get another 60d and sell one hv40 and keep one that way i will get the colours right??? steve
Re: White Balance
I always white balance by eye with the lcd and kelvin balance. Forget about using a card!! And if it makes you feel better so does the famous hdslr videographer Shane Hurlbut. haha I had to throw that in there, recently watched a series of videos put out by B & H hosted by Shane Hurlbut.....ASC B&H HDSLR Hub: Learn With A Pro
Re: White Balance
Re: White Balance
Thanks to all, but nobody for the moment tell me the right way for the WB particulary on the 550D without ML so without the Kelvin.
I need to understand how to set the best WB Thanks |
Re: White Balance
Gianni.
There is no one way to set white balance. Every occasion is different, its simply a matter of playing with the camera and finding a setting that suits yourself, its so subjective, what you find pleasing, others may not. I will white balance whenever the lighting changes outdoors, indoors is not usually a problem. Personally I dont think there is an ideal white balance on the Canon DSLRs. The best I can do, and remember its just my personal preference, is white balance in kelvin with ML on the 550D |
Re: White Balance
Be careful if you are using plain old paper to white balance, nearly all paper has a bluish tint to it. This will make a big difference to your colour balance. Use a true white balance card, from your local photographic shop, or, as you are doing use kelvin adjustment. This is quite handy, and gives a better balance than any card I have ever used. |
Re: White Balance
Gianni Paolella, on the 550d you need magic lantern to have any control of white balance. At least as far as I can remember, I've had magic lantern on my 550d since I bought it.
Re: White Balance
Colin thanks, but im struggling with the hv 40, the 60d i can kelvin and looks good, but the hv only has custom and other settings like daylight and ect,,, but if i kelvin the 60d, i cant judge the hv40 by the screen as it comes out different on my computor so im trying all kinds of settings on the hv40. in cinemode in daylight wb it looks ok with the 60d in auto wb???decent match but when lights low?? i am going to get the card you mentioned and do a custom before saturday my 2nd wedding but first with 60d, wish i should have got 3 60ds now and just kelvin all 3 to the same setting????
Re: White Balance
Thanks! |
Re: White Balance
If you assign your set button to white balance in manual picture mode, you can use the live view and press the set button which brings up the white balance menu, then use the d-pad to scroll over to kelvin and use the top wheel to adjust the temperature. You will be able to see real time affects of the white balance this way.
Re: White Balance
| All times are GMT -6. The time now is 03:44 AM. |
