Problem with Canon 5D Mk. II video?
It seems there is a serious problem with the video 5D mark II.
On the Russian site, we found abridged level's range of video, compared with the same photo. Analysis was made on Vincent Laforet' material: - Video: Canon Digital Learning Center - EOS 5D Mark II: Full-Resolution Video Clips - Photo: Canon Digital Learning Center - EOS 5D Mark II: Sample Photographs Let us replace the 100% black to red, 100% white to blue: - Original photo (excellent result): http://s52.radikal.ru/i135/0809/11/c8301fef0328.jpg - Original photo with the levels cuttings down to 16-235: http://s60.radikal.ru/i170/0809/1a/9ea602ca9bef.jpg - Screenshot of the video (very similar to a photo with the levels 16-235): http://s39.radikal.ru/i085/0809/98/cbf133ce4767.jpg The material is taken from Russian Forum: Форум VIDEOMAX: Canon EOS 5D Mark II - поддержка 1080p30,38.6 mbps The problem even more serious. Made an assumption that the processing of video before recording to the media is as follows: - Takes the original picture (histogram): http://s46.radikal.ru/i112/0809/96/35469b3d67c2.jpg - Cut levels down 16-235: http://s61.radikal.ru/i172/0809/8e/aee1573f4285.jpg - Stretched levels to 0-255 breaks the histogram: http://s59.radikal.ru/i163/0809/64/dbf3c1bd6507.jpg So this algorithm appears in After Affects. In fact, the processor 5D mark II breaks the histogram by a nonlinear function: http://i060.radikal.ru/0809/25/7c31826d55f6.jpg Source: Форум VIDEOMAX: Canon EOS 5D Mark II - поддержка 1080p30,38.6 mbps Anybody can repeat the analysis and confirm these results? |
I think I may be lost Ivan... are you trying to say the video has been processed in some way?
Yes. It was processed by 5D mаrk II, during writing video on media. |
Ivan,
I can't read Russian, so I'm wondering if they explained how they obtained the video "screenshots". Screen capture or frame export in Quicktime Pro? Not sure we can't rule out another factor here. |
The result was repeated in: - MPEG Streamclip (grab saved as tga) and Adobe Photoshop CS3 (histogram): Форум VIDEOMAX: Canon EOS 5D Mark II - поддержка 1080p30,38.6 mbps - RGB-analysis in FastStone: Форум VIDEOMAX: Canon EOS 5D Mark II - поддержка 1080p30,38.6 mbps - analysis of .mov-file in Adobe Photoshop CS3: Форум VIDEOMAX: Canon EOS 5D Mark II - поддержка 1080p30,38.6 mbps |
Gamma Curve
Of course its non-linear. The RAW data is 12-bit or perhaps 14-bit in terms of the Mark II. The codec saves 8-bit. The mapping between the 12-bit / 14-bit to 8-bit is done via gamma curve.
For film or the cine-modes in most prosumer cameras, there is a non-linear curve in order to extract highlight information. Gamma Curve profiles can be loaded onto the 5D if I'm not mistaken. You dont want a linear curve, you want an S-shaped curve for compressing highlights and extract more highlight information... |
what Ivan wants to say :
Comparing a picture taken from still and video, it seems the processor is goes pretty easy on compression. by just cutting values where it should rescale them. and the calculations are pretty simplistic too. I do not think it is a problem if you do not compare stills to video. If use this device like a camera, consider only the video output. if you use it as a still camera, for sure you will set up differently. |
Thanks, Giroud. You help me very much. <<< the processor is goes pretty easy on compression >>> E.g. camcorder Sony Z1 uses 14-Bit HD DXP (Digital eXtrended Processor) and writes 8-Bit video on media. Histogram is smooth without breaks. 5D mark II converts 14-bit signal into 8-bit video with breaks in histogram. We are losing in gradations. |
copy the link from the web page, then open a new window to google.com. paste the link in the SEARCH box, then press ok. google will give you an option to translate the page for you. ken |
The problem with D5mkII - it recording 8-bits with breaks in histogram. Others - without such the breaks. Look at Adobe Photoshop CS3 histograms: - 5D mark II: http://www.videomax.ru/forum/uploads/16534/61.jpg - Nikon D90: http://www.videomax.ru/forum/uploads/16534/68.jpg D90 histogram is smooth. 5D histogram with breaks - thin gradations is lost. It's seems as 5D processor's bug. |
6 Attachment(s)
Actually, it's not the camera that's doing this - it's AE. The camera clearly maps everything to 16-235, which puts it into the NTSC legal levels. AE looks like it's stretching it back to the full 0-255. You can get dramatically different results by switching your working color space - ProPhoto RGB looks to be the correct working color space:
It was checked in various ways. Exported from Quicktime Pro, and directly imported in Photoshop CS3. |
I wasn't familiar with ProPhoto RGB but found a good article on it here:
Understanding ProPhoto RGB It's basically got a much wider color gamut than the Adobe or sRGB color spaces, which makes it a good choice to preserve as much color information as possible when converting the RAW data from the sensor into 8-bit RGB for video. |
BTW: ProfotoRGB works well only 16bit mode. In 8bit mode may cause problems like solarization etc.
1 Attachment(s)
interesting thing though - I just thought I'd compare this to a DVCProHD clip from a project I'm working on shot on an HPX500. I get exactly the same results as the 5D. I'm thinking this is simply a result of 8-bit conversion from NTSC-safe YCrCB to RGB - and the d90 is probably not converting to 16-235 so it doesn't display the same errors. None of them show any gaps in LAB. |
3 Attachment(s)
except mjpeg) |
is 76 a .mov with mjpeg? or an avi like the nikon footage? I know there are some issues with quicktime clipping superwhite values on export from FCP, I'm wondering if this is related.
h**p://finalpass.net/videos/MJPEG_test/MJPEG-720p-2MBps.mov |
1 Attachment(s)
As we see the problem at the moment:
- 5D Mark II writes signal in QuickTime H.264 MOV-file in its full quality. - Apple QuickTime Player can adequately display these MOV-files. - But most NLE,s (Edius, Vegas, Premiere, After Affects, ...) perceive these MOV-files in a distorted form (see attached image): --- Shadows and Highlights is lost (red zone); --- The subtle gradations is lost (gaps in the histogram). It is pretty much a known problem 'quicktime gamma shift' (search Google). For example: DV - Columns - Brighter Whites; Richer Colors, Part 1 Either we are waiting for improvements in the NLE. Or need a utility that correctly converts MOV-files in a format suitable for NLE. The decision has not yet been found. |
| All times are GMT -6. The time now is 10:27 PM. |
