How do you set the white balance for the 5DmkII ??
I just got my new 5D MkII !!! I am so thrilled to shoot stills with this bad boy!
Now I am going to shoot video with this awesome beast! My question is ..... How do you set the custom white balance for shooting video with the 5DmkII ?? |
I had the same exact question. The manual describes shooting a still of the scene and referencing the still? It apparently doesn't white balance in the same way that a professional video camera does, point it at a white object and press a button.
I have been using the presets and have used the manual balance where I dial in a specific Kelvin value and it is working well. I typically don't have time to shoot a still and reference WB off of that still. To any other 5D MKII more experienced users, is there a quicker video-mode way to manually WB than what the manual describes? Dan |
One way is to shoot a white card at the start of filming... you could have the subject
hold the card for a few seconds or just lay it down and take a shot... then in post you white balance the footage as the white card is the reference.... |
Shoot a white card in still mode.
Make sure it's not overexposed. Use the procedure in the manual to set custom white balance using the still as reference. Make sure to set the white balance to the custom setting. Dave Smith |
You can also use a diffuser, like the ExpoDisc. ExpoImaging - ExpoDisc
Shoot through the diffuser at the location of the subject, if practical. Use that as your WB reference. From tests I've seen on the Internet, you can also use the Melita brand diffuser - a white coffee filter! The results of the coffee filter tests were as good as most of the imaging products! |
What you want to do is stand where the subject is and point the lens at the main source of light. Pointing the lens at the scene will give you different results depending on the color in the scene. You would get a different white balance from a shot of someone in front of a red wall than the same person in front of a green wall. Dave Smith |
-- peer |
When you say 'point the lens at the main source of light' ... if you're outdoors you wouldn't point it at the sun, would you?!?!? |
For instance, if your actor is standing next to a big red wall, you could point it more toward the wall, if you don't want that side of the face to be red. Point it away from the wall to accentuate the red reflection. When I've used the ExpoDisc, we shot the reference, balanced, and then shot a still of the scene to see the result, and to check the RGB histogram. It's a nice way to double check things before "rolling". |
You can get the same results by taking the reading through one of those thin paper
coffee filters.... cheap and easy to carry.... |
It's like using an incident light meter. You want the front of the disc to be illuminated by the same light that is hitting the subject. Dave Smith |
| All times are GMT -6. The time now is 08:19 AM. |
