What else do I need. Canon 5D Mk II at DVinfo.net
Canon EOS Full Frame for HD
Old August 6th, 2009, 07:21 AM   #1
Ok , I’m ready to pull the trigger and get this camera and need some extra bit’s and pieces.
This is what I’m thinking.
SinghRay Vari ND
Hoodloupe
Magic Lantern
JuiceLink or something similar
Follow Focus “maybe”
Media cards
Shoulder mount
Is there anything else I’m missing?
Old August 6th, 2009, 07:48 AM   #2
extra battery, better two
I love this place!
Old August 6th, 2009, 08:00 AM   #3
ummmm. lenses :)
Cinema Couture
www.cinemacouture.com
Bill Grant is offline   Reply With Quote
Old August 6th, 2009, 08:31 AM   #4
If we assume that Simon is getting the 5D Mk. II kit which includes the 24-105mm L IS lens, it just might be the only lens he'll need for awhile.
Old August 6th, 2009, 10:14 AM   #5
Simon:
A tip that will save you money. Forgo the Singh-Ray and get the Fader ND from Ebay. I had the Singh-Ray, got together with Nigel Barker from this forum for some comparison and we came to the conclusion that the Singh-Ray is not worth almost four times the money over the no name Fader ND.
I sold my Singh-Ray and ordered three Fader NDs for the same money.
Dan
Old August 6th, 2009, 10:19 AM   #6
Simon:
Matte Box (Maybe)
High quality tripod and head (you will be frustrated if all you can do is handheld, it gets old and the 5D MKII is a total tripod camera, it gets better results on a tripod IMHO, it is difficult to shoot really smooth hand held).
Extra battery
Carrying case or bag (I like the Think Tank Speed Demon)
Circular Polarizer
ND Grads
Good luck,
Dan
Old August 6th, 2009, 10:49 AM   #7
Get two batteries and buy the bg-e6 battery grip. I love it, and... It makes your camera look like a tank. UV filter for your lens, so don't scratch the lens is another thing I'd look into.
"Warriors... Come out to play..."
www.importexporthd.com
Douglas Joseph is offline   Reply With Quote
Old August 6th, 2009, 11:47 AM   #8
If editing on the PC, you'll want Cineform NeoScene.
If you want to do timelapse videos, you'll want the Aputure AP-TR3C timer.
Regarding the filters, you might want to go with 77mm and buy the needed step up sizes. That covers all but the small number of 82mm lenses on the market.
Jon Fairhurst
Old August 6th, 2009, 12:03 PM   #9
1. re: Juiced Link, or similar: I love my CX 231, and ou won't find anything else like Juiced Link with preamps that is camera mountable. However Juiced Link is just at the edge of its limits on this camera, and if you are going off camera, use of something like a Sign ENG 44 will give you plenty of preamp boost to work with. To get it to camera you can use mic out on mini plugs, or use a cheap non-powered XLR adapter to get balanced line to the camera. Remember, you need to run mic level to the camera.
2. Hoodloupe works great, and I actually built my own version, but you will find that shooting at other than eye level, you are going to need a monitor. I have a little LCD4Video 7" monitor that does a decent job. It is SD. You set it for 4:3, and you won't have any change occur when you start shooting. Others are using simple SD DVD players with AV input, in a similar manner. HDMI out has this crazy change over from HD to SD output when camera rolls. There is lag from start. And since it only give you an SD signal when rolling, I have actually used a 19 inch HD monitor, but fed it with composite SD, setting it to 4:3 for best result. If you stay HDMI, you will need a miniplug HDMI cable from camera to a likely standard HDMI cable for the Monitor.
3. John is right, you can get a cheap Chinese time lapse timer, on Ebay. I shout this with it: http://www.vimeo.com/5904387
4. Nobody has mentioned cheap batteries. They are not chipped, so when you start camera, you have to go through acceptance process to use them, and their level cannot be monitored. But at real price of about $ 15 delivered, they are great alternative. They don't as of this writing, work with Magic Lantern, though..
Chris J. Barcellos
Old August 6th, 2009, 12:17 PM   #10
Which batteries or brands have you used? We purchased a few that were 50% cheaper than the OEM LP-E6s but still considerably more than $15. They work great and from what I can tell, last just as long as our Canon branded ones.
Raymond Tsang is offline   Reply With Quote
Old August 6th, 2009, 12:20 PM   #11
bought mine on ebay... combo with charger, and then some alone... I will have to dig around for brand name. But they have a lot listed there....
Chris J. Barcellos
Old August 6th, 2009, 12:33 PM   #12
...you can get a cheap Chinese time lapse timer, on Ebay.
Just an FYI, it's okay to post Ebay links to the board (as long as they're vouched for by a DVi regular).
Old August 6th, 2009, 01:37 PM   #13
Portable Audio Recorder
Don't rely on the audio of the 5D specially if your using lens w/image stabilizer, the internal mic picks up all the motor noise. I use the Tascam DR100 with the Rode NTG 2, and Im happy with it's result.
Rickey Brillantes is offline   Reply With Quote
Old August 6th, 2009, 02:43 PM   #14
Sorry that post seemed a bit thin as I posted late last night.
The lens I'm going with is the 24-70mm f2.8 Canon if It's still in stock.
I have and EX1 so I have a suitable tripod.
Cheers
Old August 6th, 2009, 02:45 PM   #15
Yeah, the internal mic is only good as a track to sync to. Even manually focusing with a non-IS lens can sound like a gravel truck.
The recording circuit isn't bad though. As long as you use an external mic, an active preamp with a hot signal, and Magic Lantern firmware for overriding the automatic level control, the results can be surprisingly clean.
Jon Fairhurst
Jon Fairhurst is offline   Reply
