Video Skipping Ocasionally in Shutter Priority Mode at DVinfo.net
Canon EOS Full Frame for HD
Old April 16th, 2010, 07:48 AM   #1
Hi Guys,
We were shooting some aerial video of a sunset over a lake yesterday and I was shooting in Shutter priority mode. The video will ocasionally jump or skip, auto too. I have a lot of time on this 5D Mark ll and I have never had it do anything like this. It has the new software and I am shooting in 24p. It has never done this in manual mode, nor did it do it with the old software when recording in auto exposure mode at 30p. I have two ScanDisk Extreme lll 8 gig 30 MB/s cards.
Any ideas?
Wayne Mann
Wayne Mann is offline   Reply With Quote
Old April 16th, 2010, 01:20 PM   #2
What lens were you using? I just got jumping in some shots from the back of a car; the image stabilization was trying to correct the movement of the background and the jump was when it hit it's limits and reset. That's with the 24-105mm f/4 L which doesn't have a second IS mode for panning.
My latest short documentary: "Four Pauls: Bring the Hat Back!"
Evan Donn is offline   Reply With Quote
Old April 16th, 2010, 02:21 PM   #3
I had this EXACT same thing happen right after upgrading to the new firmware. I detailed my account somewhere in this forum, but now I can't find it.
Basically, I thought Shutter Priority might be a great mode for run-n-gun, just lock to 1/50th and roll. However, I had multiple instances of frozen frames during movement. This was ABSOLUTELY not due to IS (didn't have an IS lens on at the time), and wasn't related to 24p's slower framerate. I had repeated frames that could easily be seen as identical when reviewing frame-by-frame. I'm still not sure what caused it, but I went back to manual and haven't seen it again (although I haven't shot much on the new firmware yet, tonight is my first major run on the new firmware). I could actually repeat it after some effort, usually during quick pans.
Anyway, you aren't crazy, I've seen it with my own eyes, and I'm nearly certain I was also in shutter priority when it happened. Although if you post about this, you're libel to get a lot lot of people telling you you're doing something wrong. I don't think so, there's no instance EVER where frames should repeat with the 5D2.
BayTaper.com | One man's multimedia journey through the San Francisco live jazz and creative music scene.
Bill Binder is offline   Reply With Quote
Old April 16th, 2010, 04:38 PM   #4
Hi guys,
Thanks for the replys. I was using the 16-35 L 2 at 24 mm.
Wayne Mann
Last edited by Wayne Mann; April 16th, 2010 at 08:00 PM. Reason: Wanted to remove the video clip
Old April 30th, 2010, 11:08 PM   #5
5d repeating frames
Man, am I glad to have found you guys. Got mine two weeks ago and it repeats frames (sometimes as many as 4) in 24p in Shutter & Aperture Priority modes and in Manual. Seen it panning. Seen it locked down on a tripod. All I've been doing for two weeks is scouring the internet for help and testing different set-ups in the hope I could make it stop. I shoot a lot of band gigs and it's ruining 1 of every 5-10 shots. Lowest ISO I've seen it happen in is 800, so we're not talking candlelight here. Haven't seen the problem in bright light situations. Never happens in 30p. Gimme 5 minutes in 24p and it'll happen.
I finally sucked it up and emailed Canon tech support. They want me to send it in for diagnosis, but I think I'll wait to see if more folks like us start surfacing. 24-105 IS f/4 L lens. Sandisk 60mb/s cards. Bummer.
Arte Richard is offline   Reply With Quote
Old May 2nd, 2010, 08:32 PM   #6
Hi Arte,
Mine has never done this in manual mode. I have now shot a bunch of aerial video with the camera in 24p mode. I just don't do shutter priority anymore.
Wayne Mann
Old May 3rd, 2010, 12:48 AM   #7
Hi, didn't this crop up in late 2008? If I remember it's when the lens changes aperture, you can hear the lens auto adjust and that when the jump occurs. In the days before full manual, the lens twist used to take care of this or is this something new.
James Miller is offline   Reply With Quote
Old May 3rd, 2010, 07:19 PM   #8
I personally think it's more than that, but I'm a little surprised by the lack of anyone else chiming in, so maybe I'm clueless.
Most often this is blamed on auto aperture (or aperture changing due to non-constant aperture lenses) or a slow memory card. My theory is it can't be the card unless you're also getting the buffer signal on the screen. In my cases, I was never getting any buffer signal (not even one bar) when it happened, so I kind of personally doubt it's the speed of the card like many imply, but I do use slow cards so who knows. I personally think it has more to do with taxing the processing to the point that it must repeat frames to catch up with real time. By "processing," I mean anything the brains of the camera might be dealing with while recording in real time, that might include calculating auto iso (or not), correcting vingetting (or not), applying noise reduction (or not), highlight tone priority (or not), etc. Also, things like feeding it something hard to encode to the codec, etc.
My theory is that if you get enough of that stuff going on, and combine it with something like a nasty pan from bright to dark or something (i.e. lots of movement and changes frame to frame for the codec to chew on), and with enough experimenting, anyone could replicate it every once in a while in 24p on a 5D2 in M mode.
But I could be wrong, or maybe I just have a bad unit, or ? Again, it didn't happen often for me, and it's never happened since running M with all the "extras" turned off. But am I curious if others could recreate it or not. There's more than one or two of us out here though, so it doesn't feel like a completely one-off thing.
Old May 3rd, 2010, 09:26 PM   #9
As I recall, when 5D first came out, this complaint came up early on. Indeed, people concluded it had to do with aperature changes. For instance, when people were zooming, the aperature would change, and this would occur. I think this sounds like the same thing.... with fixed shutter speen, camera tries adjusting aperature, and hangs while doing it. I shoot with Nikon non auto lenses, and I don't have this issue. And I sometimes shoot auto ISO, and still not a problem. So you might try setting aperature and shutter speed manually in manual settings, and then set to auto ISO.
Chris J. Barcellos
Old May 5th, 2010, 11:52 PM   #10
I know in my case it's NOT caused by aperture changes.
I just got back from Las Vegas where I took a shot of the Golden Nugget's shark tank. The camera was resting on the lifeguard's chair and was not moving. The camera was set to 1/50th second shutter speed, 24fps, MANUAL mode, on a 17-40 L lens (with no IS). As I watched the camera's LCD, I clearly saw it skip. When I played the clip back, the skip was recorded to the card (a freshly formatted 16GB Transcend UDMA 300). This has happened to me many times, in both 30fps and 24fps modes. It also occurred in 30fps mode with the earlier firmware. It doesn't seem to matter what ISO the camera has been set to. I've seen it happen at ISO 100, all the way up to ISO 6400.
Julian Frost is offline   Reply With Quote
Old May 6th, 2010, 12:30 AM   #11
Other things to check Speed of card. When was last time card was formatted. Try a reformat and see if anything changes. If it continues, talk to Canon support by email, and see what they say.
Chris J. Barcellos
Old May 6th, 2010, 10:51 AM   #12
Like I said, this always gets blamed on aperture change, auto iso, slow card, etc., but I maintain this is more than that. Not saying a lot of people on the web are having the more common issues, but there's many people like us out there that are very competent and know there's something more to this.
In most of my cases I was in shutter priority (just after the firmware got released), BUT... I always had the exposure lock set. I thought that might be a good (new b/c of firmware) approach for run-n-gun: set 1/50 in Shutter Priority and then touch the exposure lock button to update (but lock) the exposure at will. It works great by the way, except that I had a few instances of stutter (true repeated frames in the file). I even think it happened in M mode once, but I forget now. However, once I turned off all the crap, I haven't had it happen in M since. That said, I still think that this might be reproducible by all 5D2s under the right conditions.
Also, like I said before, I never saw the buffer, not even one bar. And most of the reports of this I have seen say the same (no buffer). Combine that with the guy above with UDMA, and I really don't think this is a card speed thing. I think it is a PROCESSING THING. The more of it you are doing real-time, the more likely you are to see this, even in M.
But again, maybe I'm offbase on this, but the more of these experiences I see documented, the more I think there's something to this.
Old May 6th, 2010, 07:05 PM   #13
I sent an email to Canon support, which basically outlined what I said in my post above: That the problem has been there since day one (first thru latest iteration of the firmware), doesn't matter what lens, ISO, shutter speed, aperture, frame rate, or mode the camera is in, neither does it matter what CF card is in the camera. The buffering bars have never appeared, yet it still repeats 3 frames, intermittently. The only constant, is the camera itself.
I told them to look on the DVI 5D mk II forums to see that it's not an isolated issue.
I'll let you know what they say, if anything.
Old May 6th, 2010, 09:18 PM   #14
Dead on, Julian. Did some more tests tonight and finally saw it happen in 30p mode. I've tried every possible set up I can think of from full auto to full manual (including preset WB) and everything in between. I've seen posts from guys who sent their camera in and got it back with a response from Canon that there is nothing wrong with their camera. If that happens to me, we are all screwed because I seem to have bought the king of frame-skipping shot ruiners. Fact of the matter is this: regardless of which mode the camera is in, it should NEVER EVER happen no matter what.
Tim, Mike and Erik at Canon tech support told me they have never heard of this before. Actually, their initial response to my question of whether or not they had ever heard of it was:
"We are not aware of this to be a model wide issue with the EOS 5D Mark II."
Note the choice of the words "model wide". Sounded like an answer a PR guy might give, so I forced the issue and asked for a yes or no answer and they replied with a "no". If your tech support person tells you he's never heard of it, tell em Tim, Erik and Mike have.
Thanks again for all the help, guys. I was feeling pretty broke and lonely for awhile there. Now, I'm just broke. Which reminds me, when I asked tech support if I get reimbursed for shipping if the problem ends up being with the camera, I got another "no".
Old May 7th, 2010, 09:04 PM   #15
From Canon...
Although they don't deny it happens, they also don't acknowledge that anyone else is having the same issue, or that it's a wide-spread problem. Here's their response, in its entirety:
Thank you for writing to us. We value you as a Canon customer and
appreciate the opportunity to assist you. I am sorry to hear about the
difficulty you are experiencing with the video on your EOS 5D Mark II.
If you have tried numerous memory cards (and speeds), different shutter
speeds, subjects, and still experiencing the same issue, I would suggest
to send the camera in for service.
For factory service, please forward your digital camera to one of the
Factory Service Centers shown below. When shipping your camera, please
be sure to remove the memory card and batteries. You are not required
to send any accessories or manuals when shipping the camera. Be sure to
include your name, street address (no P.O. boxes, please), telephone
number, and a letter describing the issue with the product. If it has
been less than one year since the camera was purchased, we ask that you
also include proof of warranty in the form of a copy of your sales
receipt.
As we do not provide RMA numbers for service, we suggest using a
trackable and insurable service (i.e. UPS, Federal Express, Priority
Mail) to ship your camera. Please package the camera very securely in a
sturdy shipping box to prevent damage during shipment.
Please send your camera to one of the following Factory Service Centers:
Canon Factory Service Center
100 Ridge Road
Jamesburg, NJ 08831
or
15955 Alton Parkway
Irvine, CA 92618
Upon arrival at the Factory Service Center, your camera will be logged
in to our repair database and assigned a repair number. Next, the
camera will be visually inspected and you will be advised of the
findings. If the required repairs are covered by the warranty, the
repairs will begin immediately, and you will not be contacted. When the
repairs are complete, the camera will be shipped back to you via Federal
Express. The length of time for the repair will be dependent upon the
nature of the repair and availability of parts, if needed. Usually,
warranted repairs are completed within approximately seven to ten
business days of the camera's arrival at the Factory Service Center.
All decisions regarding warranty coverage are made by the Factory
Service Center at the time of repair. If the repair entails something
that is not covered in warranty, a written estimate will be sent to you
at the address that you have provided. The repairs to your camera will
not begin until you approve this estimate and make payment arrangements.
If, after receiving the estimate, you do not wish to have the camera
repaired, please inform the Factory Service Center of your decision as
soon as possible. If you decline the estimate, the camera will be
shipped back to you unrepaired.
Once you have confirmed with your shipper that the camera has been
delivered, you are more than welcome to contact us for repair updates.
Please include your name, address, and telephone number, as well as the
serial number of the camera, in all repair status inquiries.
Please note that our U.S. Factory Service Centers are unable to accept
packages from or return equipment to addresses outside the United
States.
I hope this information is helpful to you. Please let us know if we can
be of any further assistance with your EOS 5D Mark II.
Thank you for choosing Canon.
Sincerely,
Liz
Technical Support Representative
Special Note: Certain issues are very difficult to resolve via email. If
your question remains unanswered after you have received this email, you
may call our special toll-free number for email customers with
unresolved issues and speak to a technician by dialing 1-866-261-9362,
Monday - Friday 8:00 a.m. - 12:00 midnight ET, and Saturday 10:00 a.m. -
8:00 p.m. ET (excluding holidays).
If you prefer to continue to communicate via email, reply to this
message and we will respond as quickly as possible.
