Bower 14mm f/2.8 Ultra Wide Angle Manual Focus SLY14MMF28C - B&H |
Wow great tip Nigel, looks like a sweet lens. Sharp as sharp gets and minimal CA. Of course it's not rectilinear but would be awesome on a crop sensor (no vignetting and less evident distortion). Glad I sold my Tokina 11-16.
The 14mm Samyang looks like a good value lens - not sure how you'd go about getting ND or any other filter on it though...
I've got two matteboxes - both vignette with a 14mm lens on a 5D. So, if you know of one that will work let me know:)
I bought one of the 14mm f 2.8 Bower several weeks ago and have found it to be a worthwhile investment. For stills it's fantastic, I use PT Lens to correct the moustache distortion.
For video I've found a lot of uses for it but it is limited by no place for a ND filter. I had hoped to tape one over the rear element, but it's convex and sticks out slightly past the mount. A matte box may work. I have several but have had no time to try them and see. I'll try one when things slow down a bit. Still it's a good value if your looking for a wide angle. cheers Morton |
This is the mattebox I got: Century DV Matte Box 4x4 System -- peer |
Note that the 16-35 II is definately an improvement over the I, but also has an 82mm filter thread.
Also, not sure this counts as it's more of a medium-wide, but no one has mentioned the 35mm F1.4L yet, it's also a fantastic lens. |
| All times are GMT -6. The time now is 09:06 AM. |
