Audio for Mk2
After (deservedly) being tarred and feathered over in the All Things Audio I return to my brethren here.....
I've got an interview this afternoon and one Wednesday. Todays is a quick before the show almost red carpet type of thing. One interviewer and two talent standing. I've decided to mount a wired RODE SVM mic on a mic stand low pointed at center up just out of frame. I turned off AGC and did a test and it sounded good to me. That said, I've also got a ZOOM H4n and two wired XLR lav mics. But I suppose ideally I'd have as many lav mics and I had talking heads but then I'd need a mixer cause the ZOOM only takes two balanced XLR inputs. Another Idea was to set the ZOOM on a stand near the interviewer and lav the two talent back to the ZOOM and not record with the RODE at all. Any Mk2 users that have figured out a good way to mic more than two people for audio with the MK2? |
Well the only thing I can think of with the H4N is to plug your LAVs in to the back and use your Rode plugged in to the external mic input underneath the H4N. It's a mini jack though. (unbalanced)
But at least you could give the Rode to the interviewer and mic up your talent nicely. |
It's a pity that you only have the Rode stereo Videomic, which I believe has only has a minjack output...best to change that for something that can provide an XLR into the H4N. There are lots of cheap but good hand mics or short shot guns around now, preferably with a suitable windshield.
I'd then give the lav to the interviewer and get then get the interviewer to use the hand mic to cover the two 'talent'. Tell the interviewer to only use the hand mic for the talent, as that reduces the 'phasing' that will occur when both mics are picking up the same audio. You still might have to duck the 'unused mic' when mixing the final edit to reduce any phasing as well. I always use Tramms 'Magic Lantern' and return the audio from my recorder back to the camera, as this often gives useable sound and if not at least it's the same as the recorder...which helps syncing. Magic Lantern can drop the camera's gain down to about -20db, which is the audio output from my Edirol recorder, but you might have to experiment if you only have a 'headphone' output from the H4N. |
I believe David meant you should use just one of the XLR lavs on the interviewer, and then the interviewer uses a single hand-held XLR mic to pick up both interview subjects. That way you don't need the rear mini-jack on the H4n at all. You only need to obtain a good hand-held interview mic.
There are plenty of that kind available, both in traditional low-sensitivity dynamic types, as well as battery or phantom powered medium sensitivity mics like the AT8010 omni. Having a battery or phantom powered mic with greater sensitivity would be helpful with the H4n, especially if you wanted to adapt it into the rear mini-jack for 4-track recording. The AT8010 is about $145 online. |
| All times are GMT -6. The time now is 07:58 AM. |
