-   Canon GL Series DV Camcorders (https://www.dvinfo.net/forum/canon-gl-series-dv-camcorders/)
-   -   Export into GL2 (https://www.dvinfo.net/forum/canon-gl-series-dv-camcorders/23842-export-into-gl2.html)
Carlos Leon March 31st, 2004 03:09 AM
Export into GL2
Hi Everyone,
I just got my new GL2 a few hours ago. I was wondering. If I edit a video on my computer and I want to export it to my GL2 how do I do this?
I look fowards to hours to reading this forum
Rob Lohman March 31st, 2004 03:16 AM
You normally do a Print-to-tape (PTT) from your Non-Linear Editor
(NLE) software like Premiere, Vegas, AVID, FCP etc. Which edit
software are you using?
Alan McCormick March 31st, 2004 09:05 AM
Carlos,
should be very easy, just let us know your editing software.
Carlos Leon March 31st, 2004 09:39 AM
I am using Premiere 6.5. I know how to do a print to tape cause I would do it with my old Hi8 but my question is..do I just set the camera to VCR mode and press record?
Alan McCormick March 31st, 2004 11:54 AM
I do not have Premiere (I have Pinnacle Liquid Edition) but the format should be similar.
1. Put a DV tape into Cam
2. Place Cam in Play/VCR Mode Check "your Cam manual but suspect it will be the same.
3. When you "Output to Tape" from within NLE the editor will cue your Cam and Timeline together and when you select "Print to Tape (Record to Tape in LE) the NLE will control the Cam for the whole procedure.
You DO NOT press record on your Cam (not in Edition anyway), perhaps a "Premierite" will confirm your procedure.
