-   Canon GL Series DV Camcorders (https://www.dvinfo.net/forum/canon-gl-series-dv-camcorders/)
-   -   "Grainy" video? (https://www.dvinfo.net/forum/canon-gl-series-dv-camcorders/43235-grainy-video.html)
Adam Bray April 19th, 2005 11:37 AM
"Grainy" video?
Why is the video on my GL2 "grainy". It not so obvious in daylight when you are zoomed out, but in lowlight it's bad and gets worse as you zoom. Like it on a TV when you tune to a channel that nothing is on, it's "fuzzy" or "grainy"
What's causing this? Do I need to adjust some settings?
Ken Tanaka April 19th, 2005 11:59 AM
You've either let the camera boost the gain (as in using P or green box automatic exposure modes) or you've boosted it manually.
Seun Osewa January 13th, 2007 03:34 PM
My camera introduces some grain even under harsh sunlight when the gain is 0db.
Benjamin Hill January 13th, 2007 05:40 PM
Adam,
Ken is right, it is a gain issue. Grain is what you get when the camera doesn't have enough light to record a decent image; it is the camera's way of trying to make something out of next-to-nothing.
Sometimes you can't really get around low light, like for documenting something or taping a wedding; but if you can get some light it will always make the image look clearer and less noisy. The GL2 is more susceptible to this than the DVX or PD170, possible because of smaller CCDs. It is a very gain-y camera to start with.
Michael Pulcinella January 16th, 2007 09:15 AM
Grain is good?
It's seems funny to me that in one forum people will be complaining about grain in digital images and in another they will be trying to figure out how to make digital look more like film. Isn't grain one of the characteristics of the "film look"? I like the little bit of grain that I can get from my GL2. It softens the images slightly which is good when you want to flatter an interview buject.
Andy Wason January 16th, 2007 09:59 AM
Seun, check your sharpness setting.
Merlin Vandenbossche January 17th, 2007 02:01 PM
I also find the grain on the image (even on the 0dB gain setting) to be disturbing sometimes. And the problem indeed only occurs in low-lighted areas.
Does anyone know of any post-production means to decrease te grain effectively?
Benjamin Hill January 17th, 2007 03:46 PM
It is no coincidence that grain is happening in low-light situations. The video camera needs light. When it doesn't get it, it delivers a noisy, grainy image because it didn't have enough information (i.e. light) to give you a complete picture. If you don't like grainy DV, the easiest solution is to get more light on what you are shooting, anyway you can.
There are post-production filters and tricks for minimizing noise, but bear in mind you can't restore information that was never there to begin with.
Don Palomaki January 18th, 2007 05:36 AM
The grain effect is causd in part by the dark curent of individual pixels. Dark current is the baseline output of a pixel when no light hits it. This is normally well into black, but if you add gain (or have exceptionally sensitive eyes) it becomes more apparent. Also, because it is in the fixed pattern of the pixels, it is not "averaged out" to zero over several frames as is usually the case with movie film grain or random electronic noise, so you can see it, as you can see the grain in an individual frame of film.
Merlin Vandenbossche January 18th, 2007 10:43 AM
I have heard about dark current before and my courses photography say that it can be easily filtered out by taking a photo with the lens hood on and with the same camera settings, then use photoshop to filter it out. I'll be sure to ask the writer of the course to explain how you do this within photoshop so I can understand better. But I have no idea whatsoever that a remedy like this is available for video...
Don Palomaki January 18th, 2007 05:57 PM
I've not tried it. Might be implemented as a mask of some sort, and would probably require rendering. Maybe someone will give it a try.
Benjamin Hill January 18th, 2007 07:30 PM
Thanks for providing the explanation, it makes perfect sense.
Caleb Hansen February 3rd, 2007 11:02 AM
Grainy? I recommend NOT using Custom Preset
I have found footage to become grainy when using the Custom Preset. For that reason, I choose not to use the Custom Preset at all. I try to get a correct white balance, or use auto indoor or outdoor, then color correct to the desired look in post.
Graham Bernard February 4th, 2007 02:02 AM
Is that for ANY of the settings within CP? Is that for -ve Sharpness too?
Anyways, back to GRAIN.
We only have a 1/4 CCCD format camera. That is small, not the smallest, but small. If I'm correct, for example, the SONY PD170 has a 1/3 chip. Meaning it is bigger. Bigger chips equates with a lower light requirement, before getting GRAIN. Sooooo... the way I have understood, accepted this for OUR Camera - the XM2 - is that it is designed to deal with light levels just BRIGHTER than that which we would consider necessary. Meaning, we, humans, can drop a couple of levels - for example dimly light restaurants, home lounge environments, etc etc . . you see where I'm going with this?
The XM2 is designed with brighter environments in mind than we would "normally" need to deal with. Meaning us humans CAN operate in lower light environments.
Now, here's the kicker - and a lot of people will NOT like this - having a tad/touch of GRAIN within areas that are just below that which the XM2 can deal with, actually can ADD to the experience. See? Now if I need too strikeout with NO Grain, then lights will have to do it. But give GRAIN a chance. It aint a bad solution - IF THE CONTENT WARRANTS it!!
Bottom line here, Guys, if yah don't want grain:
* Get a better low light performer than the XM2
OR
* Add lighting
Oh, BTW, any of you guys tried out the HD options in low light?
Arthur Drogowski February 4th, 2007 08:15 PM
Grain in video solution?
I use Neat video filter in Virtualdub to filter out the grain, there's a demo at
www.neatvideo.com , it is limited to 640x480 I think, but enough to evaluate
the product.
I also use Main Concepts DV codec to re-encode the video.
I also noticed that the output vids are slightly smaller, possibly due to lack
of grain producing better compression.
HOWEVER, for each hour of video, my 1.5Ghz notebook, takes 34 hours to filter :O , but the quality is impressive.
Art
Prech Marton February 6th, 2007 03:59 PM
* Add lighting
Graham, what lighting should i buy for my xm2 to wedding evening situation?
My friend have a canon vl3, this is a 3W lamp, but i think it doesnt help as much as i like. The next Canon lamp is too 'big' for me.
Isn't a cheap 5-10W lamp that use the camera battery?
thx,
Marton
Graham Bernard February 6th, 2007 06:37 PM
Good question Prech.
I have the PAG C6 Kit. this is 20 watts which is fine up to 2 meters. I haven't used the VL10 = 10watts which uses a Canon battery - NOT the camera battery! But a separate Canon camera battery. Check this out though.
However, last year I successfully bidded for a 50watt PAG Light off of ebay. Got it for a 1/3 the actual price! I'm very happy with this. More light than I need for my demands. It has day light and frosted filters PLUS the barndoors:
Yes, oh dear, I too bought the VL3. Unless I'm actually about 2' > 3' away, waste of time and money. BUT if you can put up with a bit of grain?
Mike Donley February 6th, 2007 07:47 PM
Not the VL10
Prech,
I had the Canon VL10 video light and did not like it at all. It was bulky, for the wattage, stood upright more than horizontal, making it look like a dorky apendage. Also, it simply pointed straight ahead. There was no way to bounce light off a ceiling, or to point it up and over a little people's heads rather than directly into their eyes.
I do like the Sunpack CZ200 video light. Directional from slightly downward to about 45 degrees up. Has auto (7 to 20 watts) and manual (20 Watts), tight throw or wide throw. It is inexpensive compared to professonal lights. With two 4000 mah batteries I can do a four-hour wedding reception easily (turning it on only when shooting). The light will turn itself off just before the battery dies, which protects the light from damage. The CZ200 may no longer be in production. Sometimes you can find them on eBay or a photo store. I found a my second one at a Photo store after B&H stopped carrying them.
A professional light you might investigate is Ferenzi (spelling??). A think one is called a mini fill. From everything I've seen and heard, they are worth the money. Just too pricey for the wedding market I work in.
Mark Holland February 7th, 2007 09:00 AM
Originally Posted by Prech Marton
* Add lighting
...what lighting should i buy for my xm2 to wedding evening situation?...
thx,
Marton
You might look at the NRG line of video lights. I have 2 of the MiteLites, and a Varilux. All 3 require an external battery, but they work well for me!
Mark
Bryan Ortiz July 10th, 2007 02:00 AM
Grain is the Problem
I was reading through this thread and have been experiencing the same problems with grain due to low light...tricky tricky that low light...several people mentioned some post work that can reduce the grain and I also explored Netvideo, which looks great but I don't have windows. My question is does anyone know any post tricks in Final Cut to reduce grain or perhaps a third party software for mac that can reduce grain...thank you for your time...
