Flicker On Capture
A friend gave me a few tapes that he wants me to edit for him. It's basically a tape about his business and on installation techniques, etc. When I put them into my GL 1 to capture using Final Cut Pro the footage flickered - I guess this is the right term. I put in a different tape and my Canon GL 1 worked find on the capture. BUT then I put the tape in a different Camera and the tape worked fine. I am sure it has to do with the settings that the footage was shot with vrs. the settings on my Final Cut Pro/GL1 setup. My friend didnt shoot the footage - some guy did it for him and the guy isnt around to really ask him the shooting settings. My friend has no clue. Any ideas?
Thanks |
If I understand you correctly if you put the tape in a different camera it did
work? Then if so, you have found the problem already. Compatability with the signal on the tape and the GL1. It is a known "problem" that sometimes one camera can have difficulty reading another camera's signal etc., due to slight tape alignment differences etc. There is only one way to capture DV, it either works or doesn't. There are NO (!!) capture settings when working with simple DV. Only after the capture can you choose (project) settings like frame rate and resolution (basically PAL, NTSC and progressive or interlaced). |
| All times are GMT -6. The time now is 11:37 AM. |
