-   Canon GL Series DV Camcorders (https://www.dvinfo.net/forum/canon-gl-series-dv-camcorders/)
-   -   Filming Night Sky with GL2 (https://www.dvinfo.net/forum/canon-gl-series-dv-camcorders/58069-filming-night-sky-gl2.html)
Steve Sirinides January 11th, 2006 03:32 PM
I was wondering what settings would be best for filming the moon, clouds, and stars. The moon is almost full, and it looks wonderful with the fast-moving (fairly bright) clouds floating beneath it and a few stars, but I was wondering what would be the best way to capture that on the GL2. I've messed with some of the manual settings, but I can't get it just the way I'd like. Shame there is no camera like the human eye...
I'd like to keep the gain down to reduce noise and the aperture open enough to pick up the clouds and details on the moon. But every time I either get the moon shining way too bright or the clouds getting way too dark. Any suggestions? Maybe a lens or filter?
Robin Davies-Rollinson January 11th, 2006 04:45 PM
I've shot the moon a few times with the XM2 (GL2) and other cameras and it's always a problem to try to get the moon and any clouds near it to be exposed properly - simply because the contrast ratio between the moon and the rest of the sky is just to high.
You could try shooting at dusk however - when there's still some vestigial light in the sky. That could give a very pleasing effect.
My advice is to stick to manual controls as well - set the colour balance to daylight and use the exposure setting to place the exposure where you want it. It could be handy to have a little monitor (even a TV) with you to assess your settings on a bigger screen than the camera's little LCD.
Robin
Steve Sirinides January 12th, 2006 12:29 AM
Thanks Robing, I'll try that out tonight.
Nathaniel McInnes January 14th, 2006 04:49 AM
i find its best to just take photo of the moon and then in say Photoshop add artifical clouds
Jay Silver January 14th, 2006 06:02 AM
I did it once in two passes, one for the moon and one for the clouds. Comped it together in After Effects. Worked pretty well!
-j
Graham Bernard January 14th, 2006 07:52 AM
We got clouds in Sony Vegas. Oh yes .. along with some shots I do have of the moon, you've just given me an idea! Thank you ... G
Dale Guthormsen January 16th, 2006 11:05 PM
night film
Steve,
I spent a bit of time filming the sky with the moon. I used straight manual controls, I set the camera on the tripod, shut off the image stabilization, Adjusted the exposure so that the clouds were dark moving objects with the lens setting the moon 2/3 to the top and centered. I then compressed the hour of footage into about 40 seconds. I then used it for rolling credits at the end of a film. It turned out just dandy, a bit of grain but not to offensive. I definitely did not need to use after effects or layers, but then that depends on the effect you are shooting for.
Gus
