-   Canon GL Series DV Camcorders (https://www.dvinfo.net/forum/canon-gl-series-dv-camcorders/)
-   -   Does the GL-2 have smearing (https://www.dvinfo.net/forum/canon-gl-series-dv-camcorders/62208-does-gl-2-have-smearing.html)
David Worley March 6th, 2006 12:53 AM
I have a cheaper Sony and it has smearing when the lens sees point light sources. Does the GL-2 get smearing. I need to buy a nicer camera without the smearing.
David
David Worley March 6th, 2006 02:12 PM
Hi folks I really would like to get a response from some of you that have the GL-2 about smearing.
Michael Plunkett March 6th, 2006 02:39 PM
Welcome David Worley. I'm not a regular around here but it did notice that it doesn't work like Instant Messaging.
Smear is common.
I did this search for you while at work,
M. Green wrote last month or so: "...smear happens because CCDs need to transfer each frame off of the sensor vertically. When pixels on the CCD are overloaded by a bright subject, the overload travels with the line/frame transfer."
I have a GL-2 and don't notice any vertical smearing. But I bet it occurs.
I happen to love my GL-2. I'd buy it again.
Kevin Shaw March 6th, 2006 03:15 PM
I have a GL2 and have noticed problems with vertical smearing from bright light sources. By comparison, my Sony FX1 has much less smearing except in extreme circumstances.
David Worley March 6th, 2006 04:47 PM
OK thanks folks you gave me the info that I needed. I heard that the CMOS chip used on the new Sony HD camera HC1 and the A1 do not have any vertical smearing at all. Is this true?
Don Palomaki March 6th, 2006 05:02 PM
GL2 vertical smearling is less than typical consumer camcorders, but it will happen with very intense point sources of light in the frame, especially if it is an otherwise low light scene. An example would be ball fields lights at a night game,.
Patrick Pike March 6th, 2006 07:06 PM
I have an A1U that I tested this issue with, and there is some smearing. Not nearly as bad as CCD camera, in fact more like a "star" efffect, but still there.
Luckliy Im not filming the sun full time.
