-   Canon GL Series DV Camcorders (https://www.dvinfo.net/forum/canon-gl-series-dv-camcorders/)
-   -   GL2 or High Def? (https://www.dvinfo.net/forum/canon-gl-series-dv-camcorders/67179-gl2-high-def.html)
Amanda Warner May 11th, 2006 06:02 PM
GL2 or High Def?
*Sorry I didn't know which of the forums to post this in
Hi -
So I have been looking into buying a new camera. A friend of mine has a GL2 and seems to really like it, and I read some pretty good reviews about it, so I was pretty much sold on buying one.
And then I came across the HD cameras (specifically the Sony HDR-FX1). The Sony is a little out of my price range ($2,000-2,500) but I feel like I might be ahead of the curve in buying one.
So my question is which would you recommend? I need the camera to be rather rugged since I am planning on using it to film some travel doc. type stuff. I am a film student currently and so I need the quality to be good since I plan on using my new purchase for my film projects to avoid having to take out equiptment through the university.
Any recommendations would be a huge help! Thanks.
Amanda
EDIT: And if you have any other models that I am overlooking let me know :)
Angel Mario May 11th, 2006 06:32 PM
buying options
Hello:
Well, first of all, it all depends on what you need your camera for. if you are not gonna broadcast it, well, then id go for the one you mentioned. but if you are looking for good quality and film like video, then definetly you have to go for the panasonic dvx200 HD or the Xl2 by cannon. those are your best options, due to the reason that are the only ones at more or less that price range that truly give you 24p.
Prech Marton May 12th, 2006 03:25 AM
I'm also thinking about replace my xm2 to a new sony hc1 or hc3.
If i can sell my used xm2, maybe i can buy a new hdv.
Many people says, that those little hd camcorders make a beautiful picture.
I know low light performance is not so good. How would compare to xm2?
In wedding i need more light? (I have 2x500W)
Pros:
-clear hd pics when outdoor or have enough light
-3 sec 200fps recording (flickerfree superslow!)
-new cam, maybe not have problem in 2-3 year :)
Cons:
- Bottom loading tape
- little zoom button
- no av in
- little, light, not so stable
- not so professional looking
What do i forget?
Devin Anderton May 19th, 2006 02:15 PM
GL2 vs HD
Amanda,
GL2 versus HD camcorders is really all about standard definition vs high definition.
To COMPLETELY make the jump to HD you need to be TOTALLY ready.
This means:
-Have a super fast computer that can handle the extra work load.
-Have an editing program that is also beefy enough to handle HD.
-Know that HD-DVD's or BLUE-RAY DVD's are not standard yet. (You won't be able to show every single person your pure HD footage.)
-Know that shooting HD is different than shooting SD. (Lighting, focus, verything needs to be accurate.)
-And of course, HD is temporarily a very expensive option.
I would recommend choosing between SD and HD first. Then research and choose a camera within the specific HD or SD arena.
My opinion? If you can afford HD-- go HD. It's the future. I myself couldn't afford "the future" just yet, so I bought a GL2.
Hope it helps.
Chris Barcellos May 19th, 2006 02:57 PM
Originally Posted by Devin Anderton
Amanda,
I disagree. The Sony HDV cameras give you choice of HDV or SD DV now. Not only that, they give you the benefit of HDV for use in the future, but conversion in camera to SD DV now, so if your system isn't ready for HDV, when it is, you will have footage already to go.
It looks like a new GL at BH goes for $1995 and then you get a $250.00 rebate. As I recall, the professional level Sony A1 can be had for right at $2000.00 after rebate of $500.00 (I admit I haven't checked to see if rebate still in effect.) In my mind there is no comparison. Check out the video posted in some of the A-1 threads. I was particularly impressed with the Azores shots there.
Bob Zimmerman May 19th, 2006 03:52 PM
I would get the HDV too. You can shoot either HD or SD now.
Stu Holmes May 19th, 2006 03:58 PM
Just checked - Chris is right :B&H have the A1U for a net price of $1999 after the $500 rebate. (Rebate has been extended til September2006.)
Boyd Ostroff May 19th, 2006 04:31 PM
Hi Amanda,
Did you see the responses posted to your earlier thread on same topic?
http://www.dvinfo.net/conf/showthread.php?t=67351
We try to discourage people from starting similar threads in more than one forum because it fragments the discussion and makes things harder to follow. We're always happy to move threads to another forum however if you feel you aren't getting helpful responses though... just yell for a moderator :-)
Kevin Shaw May 19th, 2006 05:08 PM
I've been using a Canon GL1 and GL2 for several years and am now selling them to pay for my Sony HDV cameras. 'Nuff said.
Devin Anderton May 20th, 2006 08:54 PM
I disagree. The Sony HDV cameras give you choice of HDV or SD DV now. [. . .] so if your system isn't ready for HDV, when it is, you will have footage already to go.
While it is true that the sony HDV camera has the ability to convert HD to SD in camera, is that really what an individual would want to do? While it may seem like a good idea at the present, wouldn't the tendancy to make the full switch to HD be too enticing. I can only imagine having a HDTV and never ever watching HD programing on it. This is simply my opinion, yet I would think that if you were going with HD you would want to completely go with it. I wouldn't have the patience to wait. If I had a HD camera, I'd definitely be convincing my wife to let me buy a HD workstation.
I'm not disagreeing with you Chris, I'm honoring you if you have the patience to hold out and peice together a HD system.
Chris Barcellos May 20th, 2006 11:15 PM
Devin:
Point of this is that if you are going to put out about the same amount (within $250) for a camera today, why not go with one that will do both today. You shoot your material in HDV, down convert in camera when capture to your regular DV editing, but you have the material for the future when you are ready for HDV. Actually, my step up to HDV editing was rather cheap. I used same case, but put new power supply and mother board chip combo in (Dual Core 3800+ bought at Fry's for $279.) Added about $350 fro memory, and bought a heftier harddrive, and went with an upgrade from Premeire 6.0 to Premiere Pro 2.0. It edits decently with the system I built in native HDV, so there is no need for an intemediate program. I figure I did it all for about an additional $1,200.
Now I haven't seen the DV produced by the A1, but I am assuming it is near to my FX1, and as good as GL2, so my point is that down the road, Amanda will be glad she took this direction.
Prech Marton May 21st, 2006 02:31 AM
My GL2 video look much-much sharper on a regular tv than the downconverted DV video from Z1. Even when converted with the camera or later in post with edius. Thats my opinion.
David Tamés May 21st, 2006 03:03 AM
I'd say it is.
I've shot with the Sony HVR-A1U and HVR-Z1U in HDV as well as DV modes, and both produce very respectable DV, and if you're shooting SD 16:9 anamorphic, the real 16:9 chips contribute to excellent anamorphic SD footage. I like the flexibility of shooting either HDV or DV, depending on the project. I ended up purchasing the A1U because I wanted something very small I could take with me everywhere and I needed something that would produce footage that would match closely stuff I've already shot with the Z1U. I love the progressive scan video of the Panasonic's HVX200, but it's larger, heavier, and way more expensive than Sony's HDV offerings.
In the following flickr set you'll find frame stills from footage shot with the HVR-A1U in DV mode anamorphic (pushing the boundary of working in low-light with the camera) as well as a comparison showing how the 1-chip A1U stacks up to the 3-chip Z1U (same chips as FX1): http://flickr.com/photos/kino-eye/se...7594082411015/
HD = Future Proof. For anything with a shelf-life, consider shooting an HD format. HDV is not the same as full-resolution HD, but it offers an affordable flavor of HD.
Graham Bernard May 21st, 2006 04:21 AM
David, fab samples - thanks for that. Even MORE reason for me to jump ship . . .
Of course, we STILL have to see what Mr Canon has up his sleeve for this part of the NOW SonyHD dominated A1>>F1 market. A previous market segment that Canon had kinda "secured" with the GL-1/XM1 and GL-2/XM2. Or is Canon ONLY a great glass maker and prepared to just put up its gloves and resign itself with a 1/4 3ccd 4:3 chip SD offering?
Tick-tock . .tick-tock .. . tick-tock . . . Canon? - Get it sorted out?
Grazie
Kevin Shaw May 21st, 2006 09:07 AM
I don't know what conditions you tested under, but I've had a very different experience when comparing those two cameras. And if you have any interest in delivering widescreen video for customers with HDTVs, the GL2 clearly isn't up to the task compared to HDV cameras. The GL2 arguably has richer default colors than the Sony HDV cameras, but this can be adjusted for using camera settings or color enhancement in post. My wife thinks the Sony colors look better even without adjustment.
By the way, note that the current version of Edius has a bug which yields less than ideal SD output from HDV projects, but that can be mitigated by switching to an SD project setting. This bug may have been fixed in Edius Pro 4, but we're still waiting for final confirmation of that.
Meryem Ersoz May 21st, 2006 10:57 AM
someone mentioned this already, but before even considering one of the HDV cameras, be sure you have adequate editing power, including up-to-date hardware and software. if you don't already have this ready access, you are talking about several hundred to several thousands of dollars more in upgrades over SD, depending on your existing system. to support my FX-1, i bought a $2800 computer and am awaiting a software upgrade which, for me, is costing $200 but new, would cost more in the area of $999.
if you're already covered with an up-to-date editing system, i would get the Sony A1 over the FX-1 for travel. it's less conspicuous and has built-in XLR inputs. you will have to purchase an audio unit for the FX-1, so with mic and say, beachtek box, that's another coupla hundred. it's onboard audio is not great.
if you decide on the GL2, you can pick up an MA-300 pretty inexpensively compared to the beachtek units.
i think the GL2 is a terrific travel camera. it's not too conspicuous, you can get away with a much lighter tripod or monopod for stabilizing than the FX-1.
i still think with the available plug-ins for post-production, you can get great-looking video out of a GL2. or a PDX-10, for the money, which also has built-in XLR inputs.
one other bit of advice: buy used here, if you can. there are some great deals, and you can save a ton of money. i rarely buy used gear anymore, and i've saved thousands over time.
Prech Marton May 22nd, 2006 02:10 PM
Kevin, i dont know this Edius bug.
For HC1 low light question:
I have 2x500W halogen lamp for wedding evening.
This is just enough for XM2/GL2 to produce video with following settings:
shutter 1/50
F 1.6
Gain: 0db
So, the picture is very sharp and absolutly free of noise.
I'm afraid.
What can do the HC1 in this situation? Gain up to 9-12db? And the picture will be noise? :(
thx
Kevin Shaw May 22nd, 2006 02:54 PM
Prech: the HC1 is less sensitive in low light than the GL2, so you would have to use more light or some gain to get an equivalent exposure. But with two 500W halogen lamps you should be able to get a pretty good image with an HC1 in lit areas; anything in the shadows would start to show some noise. I've shot footage with the HC1 using as little as 3 watts of on-camera light, but the resulting image doesn't look very good.
The FX1 works better in low light than the HC1.
Kevin Shaw May 22nd, 2006 05:35 PM
The current version of Edius (3.x) and corresponding version of Procoder Express do not properly convert HDV to SD MPEG2; some aliasing is introduced on straight lines and text. The solution is to switch to a widescreen SD project setting and render to SD MPEG2 after doing that. You can still have HDV files on your timeline, but you have to change the project format before rendering to SD. If you need both HD and SD output, you'll have to check the placement of text and transitions when switching the project setting from HD to SD and back again.
There's some indication this problem may be fixed in the next version of Edius, but as I said before we don't know that for sure yet.
