-   Canon GL Series DV Camcorders (https://www.dvinfo.net/forum/canon-gl-series-dv-camcorders/)
-   -   Microphone: stereo or mono and suggestions? (https://www.dvinfo.net/forum/canon-gl-series-dv-camcorders/7806-microphone-stereo-mono-suggestions.html)
Fredrik Forsell March 17th, 2003 01:55 PM
Hello!
I have recently bought a XM2 (GL2) and now I want to have a better, more directional microphone then the one included. I have read about Sennheiser MKE 300, Audiotechnica AT835b, AT835ST, AT815ST and the Sennheiser ME66. The audiotechnica 835st and 815st are the only microphones that I have listed that are stereo, right? the at835b are mono, but in my pricerange: after a quick browse on the Internet I got the impression that audiotechnicas two stereomicrophones are 700$ or more, right? Well that's just too much for me.
I'm just now starting to get interested about making short movies with friends and don't have that much cash to spend on a microphone. So what should I choose? Is it necessary to have a stereomicrophone if that is the only microphone you are going to use when you shoot, or can I settle for the at 835b or sennheiser MKE300? Is there any stereoshotgunmicrophone (lol, long name!) out there for, lets say, less then 400$?
Please give me some suggestions of what I should buy. I'm thinking of shooting various events and short films with only one microphone. Which one?!
If I choose a mic with xlr connection, can I buy an "converter cable" that make the xlr fit to the 3.5mm jacket or do I have to buy an adapter like the canon ma-300? I heard somewhere that the impedans on the GL2 work well with a ME66 (600ohms) and a convertercable. And since I'm not a pro, do I need an adapter or is a cable good enough?.
I would really appreciate some suggestions!
Fredrik Forsell March 19th, 2003 12:10 PM
To make the question simpler:
What shotgun microphone do you recommend if that is the only microphone you will use? I will shoot mostly short movies where dialog is the most important sound to record. Do you think I should go for a stereo microphone or is a mono microphone enough? And which mic do you use/recomend? I would rather see that it fits my 3,5mm plug. If it is a xlr microphone you recomend, is there a cableadapter to get it to go inte the 3.5mm jack or do I have to buy an adapter for a lot of cash, and does a convertercable, between xlr and 3.5mm even exist?
Robert Knecht Schmidt March 19th, 2003 12:29 PM
The concepts of "stereo" and "shotgun" are somewhat incompatible. Shotgun--a misnomer if ever there was one--seeks to narrow the acceptible incoming signal source by attenuating sound outside of a cardoid-shaped pickup pattern by means of cancellation, whereas stereo seeks to widen the audio landscape.
If you want to pick up dialogue from a performer without a lavalier microphone, a shotgun microphone is your choice. I'd go with the Sennheiser ME66.
Stereo microphones don't see much practical use outside of consumer camcorders, but they may be good for picking up ambient sound where the stereo separation happens to be important.
The adapters you need will be relatively inexpensive and available at Radio Shack. (Do you have Radio Shack in Sweden?)
Many videographers new to audio topics think of shotgun microphones as akin to zoom lenses, i.e., as having an ability to hone in on a source sound. That's not really how they work. Shotgun mics are more directionally selective, but no more capable of amplification of distant subjects ipsi per se than a microphone of any other pickup pattern. Remember, there is no substitute for getting a microphone as close to a sound source as possible.
Tom Hardwick March 19th, 2003 01:45 PM
Great reply Robert.
With some exceptions Fredrik, professional microphones are monophonic. Shotgun and wireless microphones in particular are almost always monophonic, and a shotgun mic is monophonic almost by definition. It wouldn't make a lot of sense to have a stereo shotgun because the point of a shotgun is to capture sound from one small area, There are a couple of two channel wireless units but the same comments apply to wireless as to shotgun mikes. You are trying to capture from some distant point, so monophonic makes sense.
For professional work I think it's a good idea to get out of the mindset of there being "stereo" and "mono." What you're working with are separate audio racks that will eventually be mixed down (and probably combined) into two final tracks, one for each of a pair of stereo speakers.
There's nothing magic about stereo. (Well, some surround-sound stereo is magic, but you're not likely to deal with that in a DV system). It's just two separate sound tracks, one of which is fed into a speaker on the listener's left and the other into a speaker on the listener's right.
Professional stereo music recordings almost always start out as a collection of separate (mono) tracks that get mixed down to a stereo pair. When you hear a bass on one side, drums on the other, a guitar and a lead singer in the middle and a backup group a little to the left, in all likelihood everybody was
recorded in mono, independently and at different times, with different parts of each performance selected out of the best of different takes. The final combined performance never existed in reality; it's an illusion, including the stereo separation.
Motion picture sound tracks are just as concocted if not more so. When you're watching Fred Astair tap dancing, you're listening to taps created by a percussionist in post production. Typically only dialog is recorded on the set, and everything else is added in post. A release dubbed into another language discards even the original dialogue, combining new voices with the original music and effects track [M&E] created in post.
tom.
Nathan Gifford March 19th, 2003 02:04 PM
Normally, you can put the audio on both tracks in post using your NLE. While it is not a problem using an adapter, by not using one eliminates one less potential problem. To read more check out the Low Cost Shotgun Microphone Comparison by LAFCPUG.
Lav mics are good when you want to get audio mostly from the talent. Wireless mics lend themselves well to this activity. One of my favorites is the Sennheiser EW112P.
Robert Knecht Schmidt March 19th, 2003 02:47 PM
One thing I forgot to mention: you will probably need some sort of preamplifier in between your microphone and your camera.
For this purpose I would buy a small, cheap mixer. You can find things like these at Radio Shack (if Radio Shack exists in your country), or do a search on DVinfo.net to see what inexpensive mixers other members have recommended. (Charles Papert recently found a good cheap mixer and posted about that here.)
So for example, your audio setup might go like this:
Senn ME66 shotgun microphone -> Senn K6 module -> XLR cable -> XLR to 1/4" plug adapter -> economy mixer -> output cable -> 3.5 mm plug adapter -> video camera -> good, isolative headphones for audio monitoring
When you set up your rig and power everything on, make sure you start with the fader all the way down on the mixer, then slowly pull the fader up while making sounds into the microphone (snapping, clapping, singing). Powering on with the fader set to maximum risks the possibility of damaging something in your audio equipment chain, not to mention your ears.
Fredrik Forsell March 19th, 2003 04:02 PM
thank you all, this was way more then I had hoped for!
a couple of more questions if that is all right.
Let's say I buy an MKE 300 or ME66, (and by the way, Robert, thanks for the complete "kit" suggestion, really great...) do I really need a preamp even as an amateur? I want to be able to have good speech sound of course, with as little distortion as possible, but I only want a preamp if I can hear the differens when using it or not, so to speak.
And how is it with cable length? If I connect a longer cable to the MKE300 ( I don't know how long it is, I only assume it's short..) will the sound be significantly poorer? If I would use, letīs say a 3m long cable, then would I almost certain need a preamp?
But ok, so a mono shotgunmic and a preamp.... No there is no Radio Shack in Sweden. It is actually hard to get accesories at all. You can get Hoya filter, Sennheiser mic, bags and such easily, but a preamp ...I have to do some research before I will find where to buy that..and I don't know a single place that sells Tiffen filters...I'm not sure that no one does, but you don't find them very easily, to say the least..
Is there anything in particular that I need to think about if I want to mount the mic on a ....."pole" (please excuse my english...)..on a stick so I get point it closer to the people in the scene (perhaps it is called "microphone boom"?).
I have to say that I'm actually thinking of the MKE300, cause then it is no need for an xlr adapter..and it is sort of "complete" out of the box, with windscreen and all; but not if the mic is poor of course..Do you see anything bad with this: The MKE300, a preamp, a longer cable to be able to put the mic on a boom, would that work or will the sound be significantly poorer then with the set-up that Robert suggested above with the ME66 and 3.5 adapter?
Well basically: is the MKE 300 (easily to get in Sweden; Audiotechnica is for example impossible I think...) with the preamp and so forth clearly ok, or is the sound more closely "home movie", e.g not very much better then an onboard mic? Can I even compare it to the ME66 or should I rather compare it with a 50$ mic?
Fredrik Forsell March 19th, 2003 04:07 PM
..and Robert (or someone else): can you recomend an economy mixer please? That would save me a lot of research hours...
By the way: how do you connect a mixer? On the accessory shoe or away from the camcorder?
Don Palomaki March 19th, 2003 07:14 PM
The MKE300 is a high end consumer mic, not a professional product, designed for consumer camcorders. It has significant low frequency fall off. That said, it is decent for its price point. It is nowhere near a ME66, or the AT815/815.
Stereo mics, such as the AT825 do have a place. First as an upgrade from the standad LXL1 mic. Also, single point stereo mics are good for projects where individual mics for each performer are not practical, such as choral groups, large bands and where there is no opportunity to set up. You can do stereo recording with two mics, but mic placement has a major effect on stereo image and whether or not you get distrcting phase cancellation effects.
Robert Knecht Schmidt March 19th, 2003 07:59 PM
Here's the Papert mixer post I mentioned.
The mixer just sits off to the side of the camera. If your camera needs to be moving, for example, on a dolly or steadicam, you might be able to secure it to the camera rig or operator by means of velcro, rubber bands, backpack, etc.
Tom Hardwick March 20th, 2003 01:53 AM
It's worth noting that there's an MKE 300D version of the Sennheiser mic Fredrik. The D stands for digital and it's been produced because of the large number of digital cams that cause unacceptable hum when used with the 300. Sennheiser will do the modification to the 300 to make it a D version, but it costs quite a lot to do.
Sennheiser in Sweden now know about this problem and should be able to modify it should you not be able to get a D version, but as Don says, the 300 is a long way from the ME66.
tom.
Fredrik Forsell March 20th, 2003 04:03 AM
Ok, the ME66 seems to be a good choice. But isn't there a better shotgunmic (mono) then the MKE300 that would fit directly into my GL2?? I would really prefer that rather then an xlr mic, cause that mean I don't have to have converters from xlr - 3,5mm, buy windshield etc. etc. to get it ready.
Robert thanks for the link. I think I will look for a smaller preamp then the mx602a though, so I can move around in public with the camera without carrying to much with me. Behringer also had a preamp called tube ultragain MIC100. I don't think I need a mixer, just a preamp, since I will do mostly "home movies", so something less big then the mx602a would be preferrable.
Don Palomaki March 20th, 2003 05:21 AM
The MKE300 is probably about as good as it gets for a modest cost shotgun that mounts directly on a camcorder's shoe mount.
Fredrik Forsell March 20th, 2003 12:08 PM
ok, but I meant in the 3,5mm plug; is there any better shotgun mics then the MKE300 that is as complete as that mic (windshield, mount etc..) but better, that for example don't have that low frequency fall off that Don mentioned, that fits into my mic input on the camera, eg. a mic better then the MKE300 but NOT xlr connected? Does anyone know?
Robert Knecht Schmidt March 20th, 2003 01:39 PM
Fredrik, balanced cables are your friends, especially when you have long cable runs, as they reduce noise from interference. You will not find a good microphone that does not have port for a balanced cable, and the necessary adapter is cheap.
Fredrik Forsell March 21st, 2003 05:28 PM
just wanted to say thank you all!
Lance Delo March 22nd, 2003 07:56 PM
Coming from a pro sound background...
Any decent mixer will have "preamp"'s. That's the primary purpose of the channel strips on a mixer - to provide per-input (per-mic-line) preamps (complete with padding/gain adjustment, eq, routing options, solo options, etc etc.)
If you are worried at all about sound, do not use consumer or prosumer grade gear with two-conductor connections.
They are an invitation to electro-magnetic interference of nearly every type.
To be fair, in many cases and situations [con/pro]-sumer gear will be more than adequate.
But in a "bad" environment, the [con/pro]-sumer gear will be picking up and recording noise long before that same noise will even register above the overall noise floor with pro gear.
If good sound is your goal, then XLR/TRS/balanced lines are the ONLY way to go. Accept no substitute.
If you want flexibility and good sound, then you should probably go with a smallish off-board mixer, good mics, XLR/TRS lines, and sufficient adapters ("gender-benders") to get it all wired up.
By the way, any time one has two or more pieces of gear (such as perhaps a wall wart power supply and then a mixer or amplifier or recorder or whatever) plugged into two or more different AC (wall) sockets or circuits, one is exposing oneself to potential ground loops (the dreaded AC hum.) There are ways to deal with that, although it is often the most common source of noise (that and triac/scr light dimmers) and can be devilish to track down and isolate.
Two more points: A couple good small mixers are the Mackie 1202/1402 (depending on how many mic lines one wants) or the Behringer battery powered mini-mixer designed explicitly for video sound and which includes phantom power in spite of being battery-driven.
Finally, mic-level signal loss is generally not a problem with XLR/TRS/balanced lines. In my former pro sound rig, we would routinely run 50 foot or longer mic lines into the 100 foot snake (a total of 150 feet or more) without significant degradation of the signal.
- Lance
Michael Connor May 9th, 2004 02:09 PM
If i buy the mka 300 do i need a pre amp and mixer unit?
My plan is to make a little wire (small male stereo jack to 2 small female mono jacks), so i will record the mono from the sten on one track, and record an external radio mic on the other track live. This way i have 2 completely different sound sources.
any criticism of this?
Tom Hardwick May 10th, 2004 01:10 AM
It should work well as the mic input is simply waiting for two seperate signals. You won't have any control over the 'loudness' of the relative signals, so the hot 300 might hold down the other mic. Also if in auto level control the limiter acting on one mic will automatically squash the signal from the other, even of it's signal was far from overlaad.
tom.
Michael Connor May 10th, 2004 07:17 AM
Thanks. no control over loudness? I take it your not just on about the volume control here, which i thought would be ideal on the canon. Does the mk300 use power from the camera battery, and therefor produce a louder signal than a radio mic or wired mic might? Also how does this affect the batterys performance. Is is a big difference?
I just feel it seems mad that you should pay over a thousand pounds for a camera, then have to spend money on a mike, and loose the stereo function. Which means more work in post trying to produce a stereo sound.
Tom Hardwick May 10th, 2004 07:48 AM
The MKE300 (and the D version, which you'll probably need to buy to stop hum spoiling your audio) is self powered by a single silver oxide cell contained within the body of the mic. There's a little on/off switch with a flashing LED to say the batt's ok. No power is taken from the camcorder.
Let's say you wire this up with a much less sensitive mic on the other channel. The sensitive 300 will produce a big signal which will trigger the camcorder's limiters to 'squash down' the audio to stop it clipping - a horrible noise in digital audio. This will 'squash down' the other channel as well, making that sound track (maybe recorded in another room) go quieter.
tom.
Michael Connor May 10th, 2004 08:13 AM
cheers with you now. So if i use the manual audio level function and adjust the left and right volumes accordingly i should be able to overcome this problem.
Sean Taylor December 29th, 2005 01:34 PM
Though this thread is over a year and half old, I found it extremely helpful. Thank you, everyone, for your input!
Tom Hardwick December 30th, 2005 02:01 AM
That's why the archives and the search facility are so useful. I find I can type something into the search box - 'multi-coating' say, and spend a happy hour reading much good advice and learning a lot about the subject.
Graham Bernard December 30th, 2005 02:37 AM
Tom - yer got that right Pal! - AND my levels of understanding have changed. Stuff that went completely OVER my head 2 years back, now means something to me. AND I've found that I will only research something that I need at one particular time.
Chris and all the Guys and Gals at DVinfo . .THANK YOU and a big hug too!
Graham "Grazie" Bernard
