-   Canon VIXIA Series AVCHD and HDV Camcorders (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/)
-   -   Looking for a family camcorder..HG HF or HV? (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/470805-looking-family-camcorder-hg-hf-hv.html)
Habib Faraj January 11th, 2010 10:40 AM
I am shopping for an hd camcorder. I need it for the family. I may do some video editing (cutting, adding transitions, titles). I have some difficulty deciding between canon camcorders.
HG is fairly priced, but the battery life is not that nice, and the image quality is less than the hv series. The Hf has a very good battery life, but it is very expensive (both the camcorder and the sd memory cards). HV seems to be the best way to go. Is it the best choice for family? Or there is a better option? Can I do without optical viewfinder when filming in sunny weather?
Ken Wozniak January 11th, 2010 01:36 PM
Welcome to the forums, Habib!
In my opinion, all three would provide quality pictures for home video use. I think the best thing to do is to use the three side-by-side and decide which one works best and easiest for you.
The flip-out LCD screens are much better today than they were in the past. Most current LCD screens will provide a usable image in sunlight, but in my book, nothing beats a good old viewfinder for bright environments.
Don't be pushed one way or another by measures of battery life or storage capacity of the media. Variables like battery life and storage are easily fixed by buying a higher capacity battery or storage card. With tape, you're stuck at whatever the HDV tape will allow. I personally still prefer tape, though.
What you need to look at (after deciding format) is the things you can't change after buying the camera. Things like how the camera feels in your hand and ease of access to frequently used features cannot be changed, so make sure you pick out a camera that works in your hand.
You may already know this, but editing of AVCHD will require some investment in hardware and software if you do not want to be completely frustrated during the editing process. Check out the forums on editing software on this site to discover what you'll need.
Good luck, and happy shooting!
Habib Faraj January 12th, 2010 08:46 AM
Thank you very much for your input, Ken.
May I know why you prefer tape-bases camcorders? Is it the quality or is it because editing is easier and better?
Ken Wozniak January 12th, 2010 11:42 AM
Mainly because it's the workflow I currently use and have used for years.
What would I do with the digital files once I pull them off the camera? I don't put any trust in hard drives for archiving purposes. Flash memory is too expensive to use one time. DVD-R media does not have the capacity needed for archiving HDV. BR recordable media is about the cost of miniDV tape, but read errors in the future concern me.
Sometimes, certain players do not work well with certain brands of writable optical disc. I have MiniDV tapes 10 years old that are still readable, but some DVD-Rs made a few years back that can't be read on a stand-alone DVD player.
I do plan on getting some type of solid-state recorder for my current camera, but that will be used in addition to the current tape mechanism. The tape will basically be the backup media.
In my opinion, tape is a better archiving method at this time. The life of a tape for me goes something like this:
1. Record event.
2. Rewind.
3. Capture event to PC.
4. Rewind.
5. Store tape.
After that, the tape rarely sees the light of day. Adding the CF recorder to this will greatly reduce the time required for step 3, and eliminate step 4, putting less stress on the tape. The tape will just head straight to archive.
Some day, a better permanent storage method will come along. Until then, I'll stick with tape. Unless I buy a new cam that doesn't support it...
Dave Blackhurst January 12th, 2010 11:27 PM
For a "consumer" cam, tape is "mostly dead" - tapeless is it now... and SD is still hangin on, barely, for no apparent reason IMO...
Yes, you've got to figure out archiving, but having a stack of tapes around has its own issues. Big hard drives are cheap, and as long as you observe proper backups, it's not a problem. You WILL need pretty current computer hardware to edit AVCHD material - don't underestimate this - a quad core is comfortable, maybe some of the fastest dual core processors, but don't count on it.
Most times you can pick up "last years model" a bit cheaper, and prices are coming down on cameras using "last years" best guts, while the new top of the line cams get the latest and greatest (at the highest prices). The differences probably won't be noticed by most people.
Set a budget, see what's available for that price, then get hands on and see how each camera "fits" - will you like using it enough that it gets used?
Alan Somers January 14th, 2010 12:34 PM
Have tape-based camcorder manufacturers solved the issue of motor noise in low-ambient noise conditions? The motor on the DV camcorder I will be replacing with a flash-based unit this year can be heard quite clearly in videos taken inside my house, not so much outdoors.
Dave Blackhurst January 14th, 2010 01:38 PM
Tapeless has no motor or mech noise... so yes, mfrs "solved" the problem!
Alan Somers January 14th, 2010 05:19 PM
I was aware of the lack of mechanical noise on flash-based camcorders and I guess hard drives would be quiet enough for the mic not to pick up noise. That's a big reason I'm opting for flash-based in my next camcorder instead of tape. I will just assume by your answer that the mechanical noise issues persist on tape-based machines.
Dave Blackhurst January 14th, 2010 11:56 PM
As a practical matter, tape based small cameras have very little room between their mechanical parts and the mics - my brief experience with the HV20 was it was worse than the comparable Sony (more general chassis noise too).
It's pretty much about to be a non-issue, as Sony has discontinued the last of the tape based line (HC9), and I think the HV40 is probably close to the end of it's run...
Predrag Vasic January 16th, 2010 12:59 AM
End-of-life for Tape
Well, this year's CES was the first in five years that Canon failed to announce a new tape-based HD model (HV-50, presumably). This is a clear indication that the last year's HV-40 is the last of the dying breed.
Meanwhile, in their professional camp, they still only have HDV, and no AVCHD. Go figure...
Habib Faraj January 16th, 2010 06:24 AM
Neither did they announces any Harddisk-based model. They only announced Flash-memory models. Does this mean that the futures is for the flash models? Or it's not the right time for new harddisk models?
Alan Somers January 16th, 2010 09:39 AM
Flash memory is now available in such high capacities, is getting so cheap, takes so much less power, takes so much less space, and weighs so much less than a hard drive that Canon may not see hard drive camcorders as an ongoing market. The addition of the second SD card slot would tend to back up that supposition.
Chris Hurd January 16th, 2010 11:28 AM
That's correct. Canon is finished with tape.
That's coming up next -- see Canon Reveals Their Next Pro Video Cam at DVInfo.net
As far as Canon is concerned, hard drive camcorders are done as well. It's all Flash memory now.
Sherif Choudhry January 16th, 2010 02:17 PM
HV30 motor noise
I don't know if the HV40 has got rid of the motor noise but on my HV30 it picks up a tiny amount of motor whine. This is ok if you are at disney and the audio levels are high, you wont hear it on playback, but if you video your children at home say putting together a lego set quietly, you can hear it. It is very annoying, and though I can remove the noise using my hum remover in soundtrack pro, its still annoying.
That is one reason i would move to flashcards. No motor whine.
Dave Blackhurst January 16th, 2010 03:36 PM
Tape is OVER in the consumer space, and flash is more logical than HDD now that you can get it cheap enough to put decent capacity in, for all the reasonas mentioned above.
Joe Ogiba January 25th, 2010 07:22 PM
SDXC slots on the new 2010 HD camcorders
"SDXC memory compatibility (over 64GB SD cards)
SDXC is the next generation is the line of SD memory card technology. The SH1 can record to more than 64GB of content to SDXC memory cards. This dramatically improves your ability to record and transfer Full HD 1080 videos to a computer. You can also play SH1 Full HD 1080 videos stored on SDXC cards on your high definition TV."
Amazon.com: Sanyo VPC-SH1 High Definition Camcorder and 10 MP Camera (Black): Camera & Photo
SANYO :: News :: SANYO Announces Industry-Leading*1 ?35-mm Wide-Angle Lens? & ?30x Advanced Zoom?*2 Full HD*3 Dual Camera
Panasonic SDXC camcorders
"While not all of Canon's new HD camcorders offer internal memory, all are now SDXC compatible (SDXC cards are said to be capable of holding 2TB)."
Canon introduces nine new HD camcorders
Dave Burckhard January 26th, 2010 04:07 PM
Manufacturers will tell you that tape based cameras are being replaced with hard drives, flash memory and other storage media because they're superior technology. In actuality, the biggest reason manufacturers are turning away from tape is because it's cheaper to build cameras that don't incorporate a drive mechanism. Some might argue that tape can't handle the higher bit rate needed for higher resolution images. In fact, certain video tape can handle five times as much as what is needed for HDV (24 Mbps). Even miniDV can theoretically handle twice or more that bit rate. However, it's a matter of economics which marketing has twisted and spun to cast a pall over tape as a viable medium.
Some might argue that tape mechanisms introduce noise into the audio part of a video. If we are truly concerned about the quality of our video and if we understand that the audio part is 50% of decent video, we aren't using the internal camera mics anyway. The issue should be moot.
When you consider workflow, many find a tape based workflow allows fast editing, easy and cheap archiving. Until 32GB Class 4 or 6 SD cards are $4 a piece, it's still far cheaper, faster and easier to archive by placing label on a tape and toss it into a box than any other method.
Tape based video has many positive attributes. Sure, you can decide to move away from it but do it for real and beneficial reasons rather than perceived or hype-driven reasons.
Dave
