Think I'd be ok to switch tape brands after only 2 tapes?
I have read here from several of you about not switching brands of tapes.
My dilemma is this: I bought two Sony HD tapes and they worked great, but they are too expensive. I just bought two 5 packs of Panasonics DVM60's as they are far more affordable. Anyway, will my camera be ok if I switch and stick to the Panasonics? If that would be a bad move I can go with Sony's Premium tapes since they are cheaper (cost wise) as well. I assume all of Sony's tapes are "wet" tapes? I would appreciate some advice before I fire my camera up with the new tapes. Thanks! |
Yeah, just run a head cleaning tape before you switch brands, you'll be fine.
I'd stick with the Sony Premium tapes. I've been using these for years with different cameras and never had a problem.
Agreed, go with the premiums.
I use premiums and no problems so far :)
Same situation, I have been using Sony HD tapes (very expensive) and have now just bought a 6 pack of cheaper Sony Premium DV tapes.
They came with a free Minin DV head cleaner. Should I run this cleaner first before using these tapes or should I just stick in a Sony Premium DV tape and go ? Any input appreciated Lee |
I decided to go with the Sony Premiums since I had already used Sony's HD tapes.
I cleaned the heads and then put in the new Premiums and everything seems fine. No noticeable difference between Hd and premium tapes except the hit on my wallet of course. |
Cheers Lee |
| All times are GMT -6. The time now is 12:36 AM. |
