-   Canon VIXIA Series AVCHD and HDV Camcorders (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/)
-   -   HV20 PAL @ 25p footage (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/92882-hv20-pal-25p-footage.html)
John Kristoffersen May 4th, 2007 07:48 AM
Originally Posted by David Grieser (Post 672563)
I do all my work in Adobe Premiere Pro 2.0 but don't use their exporter, instead I frame-serve it with DebugMode FrameServer.
It creates an AVI file that is only a few KB of size which can be opened by all external encoders,
you could even just play it in a media player if Premiere can serve the frames fast enough.
Now I open the file in VirtualDub and choose XVID as the video compressor in its standard settings with the bitrate set to at least 5000kbit/s.
Additionally you have to add the filter "resize" to get 1920x1080, what also helps is adding the filter "sharper" and set it to "12",
that's because you generally lose sharpness with compressions like XVID.
Do you do any processing in Adobe Premiere Pro that can not be done in Virtualdub?
David Grieser May 4th, 2007 10:18 AM
Cutting, adding music, blending scenes, adding titles, changing speeds, correct color and/or add film looks... and many other things I can't think of right now.
Some of those things could be done in VirtualDub, but without any comfort of a timeline and instantly seeing the results.
Mathieu Kassovitz May 11th, 2007 02:47 PM
Links down.
David Grieser May 11th, 2007 03:07 PM
Yeah you guys made my traffic limit explode :D
Moved the files to a new server.
Here are the URLs:
http://www.cuttle.de/pgod/hv20/in_my_place.zip
http://www.cuttle.de/pgod/hv20/deartifacted.zip
http://www.cuttle.de/pgod/hv20/black.zip
http://www.cuttle.de/pgod/hv20/fields.zip
http://www.cuttle.de/pgod/hv20/heath.zip
Mathieu Kassovitz May 11th, 2007 03:32 PM
Merci.
PAL land here too. Much appreciated.
Reese Leysen July 9th, 2007 06:27 PM
Hey, great stuff, what was the soundtrack on the Fields one? (both songs)
Clayton Moore July 9th, 2007 08:28 PM
".......you guys made my traffic limit explode :D"
I hear that, I had to shut down some clips I posted for the same reason. Im about to migrate to a new domain host for a new site myself when I do Ill pass around the link.
Reese Leysen July 12th, 2007 04:43 AM
What's the quick last song on the Fields clip?
