-   Canon VIXIA Series AVCHD and HDV Camcorders (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/)
-   -   HV20 exposure manual control (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/93096-hv20-exposure-manual-control.html)
Ron German May 3rd, 2007 07:45 AM
I`ve read some threads on exposure manual control of HV20 and I didn`t understand if I can lock the exposure in a specific F stop with the shutter speed already set. As, for example, in 48 (with the camera in 24p).
Ron
Wes Vasher May 3rd, 2007 08:17 AM
You can, select TV mode and you can set your shutter speed, then use the joystick to set your exposure.
Denis Malyavin May 3rd, 2007 09:06 AM
I have a question, if I set the shutter to be 1/25 and then manualy change the expose (with the joystick) will it overwrite the shutter speed?
D.
Ian G. Thompson May 3rd, 2007 09:17 AM
Denis, Wes' explanation for Ron would also answer your question. You just set the cam in "shutter priority" (TV Mode) to the shutter speed you want and then use the joystick to adjust your exposure.
Here's the trick...once you set your exposure to where you want...leave the settings visible on-screen. This will lock your exposure into place and this way you will have both your shutter and exposure locked. If you toggle the exposure setting visibly off the screen then the cam will reset your exposure to where it thinks it should be.
Just set it and forget it.
Ian
Peter J Alessandria May 3rd, 2007 10:14 AM
Perhaps a little more detail would be helpful: you can set your apeture (f-stop) in Av mode or your shutter speed in Tv mode. That effectively locks that setting - apeture or shutter. But there is no "M" (full manual) mode per se on the HV20. What happens next in Av mode is if you use the joystick to toggle your EXP to manual, you can change the shutter speed (and if you run out of shutter, your ND's) but you'll never really know what your exact shutter speed is (except maybe after the fact by putting the tape in another camera that does display both apeture and shutter) and the camera just says you're adjusting exposure +/- in increments of "1". In Tv mode, it's the apeture that gets adjusted by going into EXP with the joystick (and maybe some gain once the apeture is wide open), again in +/- increments of "1" (which might end up being 1/3 stop increments but I haven't tested that). So... you kinda have full manual control over your exposure with the HV20 but not really b/c you don't know exactly where you are - at least based on the display in the viewfinder/LCD.
Chris Barcellos May 3rd, 2007 10:20 AM
Ian
Actually, in my experience, you are able to click out of the "joy stick" mode to clear the screen, and still have exposure locked. It will unlock again when you access the exposure setting with the joystick again.
Peter J Alessandria May 3rd, 2007 10:23 AM
That's correct.
Ian G. Thompson May 3rd, 2007 10:43 AM
You are absolutely correct...but...if you find yourself in a situation (while filming) where you want to make a subtle change to your exposure you can ...only if you leave the setting visible on-screen...but once you toggle it off and then back on again it does a drastic jump right back to zero which could (depending on how and what you are shooting) ruin a shot.
Edit: I'm not in front of my cam at the moment but I believe this is what happens.
Jason Brown May 3rd, 2007 02:14 PM
You can see what both your shutter speed and aperture is at any time by pressing the photo button half way. An excellent tip that was posted by Povl.
Patrick Bower May 3rd, 2007 02:35 PM
Could this thread become a sticky? It's a really useful reference.
Patrick
Fergus Anderson May 3rd, 2007 03:46 PM
I tried this but it didnt work - I dont have a SD card in though - I wonder if thats why?
Ian G. Thompson May 3rd, 2007 05:25 PM
Ok, I'm back at my HV20 and what I found is that you most certainly can turn the exposure control on and off without affecting your current setting (in other words it stays locked). And you can make subtle changes everytime you bring it back on the screen. What you don't want to do is accidently hit EXP (which is very easy to do with this joystick)..that will cause the problem i mentioned above.
Patrick Bower May 3rd, 2007 05:39 PM
You do need to have a SD card in the camcorder, and to enable Still Image Simultaneous Recording.
Elmer Lang May 3rd, 2007 06:51 PM
Sorry, I"ve been looking for the last half hour at how to enable Still Image Simultaneous Recording and I don't get it. How do you do it?
best,
elmer
Chris Barcellos May 3rd, 2007 07:20 PM
In video record mode, select menu. Scroll down to settings just above the menu. It should be saying Sill I. off. With the joy stick, puch right, it will give you to image size selection. Select what ever one you want, then push menu button.
You should be good to go. It really doesn't give you much as far a letting you know you snapped a pic...but it will be on your card.
Povl H. Pedersen May 4th, 2007 12:21 AM
On top of displaying f-stop and shutter, it does give you the picture, with burnt in info about exposure/shutter for later reference, and it also shows you the focal length and metering mode in EXIF data.
And the original time/date, which I do not understand why we can not capture. The camcorder can play back the tape, displaying time/date/shutter and f-stop. It would be nice to have this info included in the clips.
Unfortunately, the EXIF does not contain ISO / gain info.
Peter J Alessandria May 4th, 2007 10:05 AM
I'm not using the HV20 for stills either. Are you saying pressing the photo button while shooting video (assuming I have a card and still image recording selected) will display the shutter/ apeture on the camera's viewfinder while I'm recording? - or only after the fact by reviewing the still images EXIF data?
Edit: Never mind - got it. While recording.
Philip Scott May 4th, 2007 10:15 AM
ISO in EXIF
If it's like the Canon Point and SHoots such as the G7, then we should see the correct ISO in EXIF *IF* we use their ZoomBrowser I think- have not looked yet.
Ron German May 4th, 2007 01:49 PM
Thank you guys for these very useful info.
Best
Ron
Patrick Jennings May 5th, 2007 01:14 AM
this is a tutorial i made a few days ago on how to control the aperture and gain on the HV20. i had been up for about 20 hours so you can tell I'm a little muddled and tired. so if someone else want to make a better one that's more clear, please do so :)
this is the PAL version, so it's basically exactly the same but the NTSC version would have different shutter speeds.
you need a miniSD card in your camera for this to work.
http://www.dvinfo.net/media/canon/hv...urecontrol.mov
i prefer to use cine mode because you get the extra shutter speeds if you need them. you get 25, 29, 33 ,40 and 50 where as you only get 25 and 50 in TV mode.
Fergus Anderson May 5th, 2007 03:32 AM
Fantastic video!
Thanks ever so much for doing that - really helpful to see it demonstrated rather than in text.
So when in Cine mode extra shutter speeds?! Wow I will have to check that out.
Chris Barcellos May 5th, 2007 11:28 AM
Nice job on that tutorial. Helpful, to say the least. Makes the camera that much more controlable....
