Does the Vectorscope Have Adjustable Gain?
I've been trying to find out if the built-in vectorscope on the 300/5 has adjustable gain? And if so from what level to what level and how is the adjustment made?
If this vectorscope has some adjustability, it is a very valuable addition to the camera, as a good portable vectorscope costs a few grand. Thanks much! |
Vectorscope
Peter,
The vectorscope can be set to either Normal or Spot mode and to 1X or 5X magnification. Michael |
Michael,
Thank you very much for the info. While it sounds good, it kind of sucks by quite a bit. DSC Labs charts specifically require x2 gain to properly calibrate a camera. If the XF's had x2 gain, that would save the need for an external vectorscope. It would be a feature worth paying a grand or so premium for. P.S. Although, I wonder if 1X gain is the same as x2 gain? Perhaps it doesn't mean * 1 because any number * 1 is that number. Or is 1X gain no gain at all? |
Quite right -- there's no way to know what the "x" is until it's properly compared. So we're looking for someone with an XF and a decent standalone VS/WFM like a Leader.
Chris,
If this is (or can be made to be via a firmware upgrade) a viable on-location vectorscope and waveform monitor w/ the appropriate gain for shooting DSC Labs calibration charts, then that goes a considerable way to justifying the price of the XF's. |
Re: Does the Vectorscope Have Adjustable Gain?
Does this mean it's not possible to adjust the XF300/305 using the built in vectorscope and a DSC Labs calibration chart? It only fails because of the 5x gain and there's no 2x gain? Everything else is there. Targets in the vectorsope, color matrix settings ...
Please say this is not true! I've ordered a testchart. Now I read this. |
Hi Martin,
yes , thats right. Unfortunately most "simple" Vectorscopes (in TV Logics or Sony 9" / 7" LCDs) do neither have a x2 Gain... I have no idea why the dont throw in a simple 2x in it - DSC is quite well known for their testcharts... br ULI |
Thanks a lot Uli.
I'll wait for my test chart, look what the XF300 vectorscope says and then ask Canon support for tipps and tricks on how to reach the targets with 1x or 5x gain. Are there test chart available where the targets are reached with 1x gain? |
No.
There is a good explanation on the DSC website saying its not possible to print the necessary colour saturation + contrast. Thats why DSC goes "the trick" to print just the "half" saturation and compensate this via 2x gain in the vectorsopce (faking a 100% saturation). of course you could use 1x gain and find out where the DSC targets should be, but for this the resolution of the XF vectorscope is probably too bad. I am trying to find out if software vectorscopes (like BlackmagicDesign) have an adjustable gain, information is difficult to get. uli |
Thanks again, that's very helpful. I'll post more when I have the chart in a few weeks.
The vectorscope of Final Cut Pro X also doesn't offer 2x gain but a scale of 100% and 133%. The $16000 C300 also has 1x an 5x. I really don't get it. |
Assuming you're on a Mac, have you tried Divergent Media's Scopebox?
ScopeBox As of version 2.1 they added a zoom control to the vectorscope that allows you to get 2x zoom. According to their documentation, they added this feature specifically for use with DSC charts. I've used it with the component inputs on an AJA Kona LHe card and it seems to work well. Though I'd be curious to know what other people's experiences are with it. Juan |
Thanks, Scopebox looks like an interesting and affordable option. I downloaded the trial and will test it as soon as I have my chart.
Hi Martin,
did you find out more? UIi |
2 Attachment(s)
Uli, thanks for your interest. Yes I did and sorry, the long delay was caused because the first DSC Labs chart which I ordered from a company in Germany never arrived.
This time I ordered the smallest and cheapest DSC Labs chart - the postcard sized Camette Pocket -directly from the DSC Lab website. This chart also has spectral accurate white on the back for proper white balancing. It arrived today and here are my quick findings: In the first attachment you can see the vector scope of the XF300 set to Alan Roberts BBC_VIDEO Custom Profile. The traces head in the right direction but without 2x vectorscope gain there’s no chance to reliable judge or tweak anything. The vector scope of the trial version of ScopeBox, shown in the second attachment reveals the truth. I see now that a 2x vectorscope gain setting in the XF series would be extremely helpful and I would love to tweak the color matrix live on the camera. It would be accurate enough for me. As it is now I would need some HDMI capture device to use ScopeBox live. I already contacted Canon customer support about this. Should be really, really easy to add a 2x multiplier in the firmware. A question to the pros: After proper white balancing and setting the correct exposure are the matrix settings in the camera menu the correct and only way to align the traces to their boxes? |
Yes, thats exactly what I encountered a while ago - most VS do not offer the necessary 2x GAIN.
I wonder if some software VS like the Blackmagic Designs Ultrascopes do offer 2x Gain... ? Let us know what Canon says. br ULI |
Excerpt: "The Vectorscope Display uses a vector view to show the colors in a video signal. You can see color bar video levels by using the color boxes in the graticule. All you need to do is select 75% or 100% color bars, depending on the standard of color bar test signals used in your facility!" |
In meinem steten Bemühen die Bildqualität meiner Videos zu verbessern bin ich auf die von Profis gern verwendeten DSC Labs Charts zur Farbkalibrierung von Videokameras gestossen. Diese erfordern eine 2-fache Verstärkung des Vectorscopes und es hat mich sehr verwundert in meiner XF300 nur 1x und 5x zu finden. Da es sehr praktisch wäre die Colormatrix an Hand des Charts live an der Kamera justieren zu können und da die XF300 eine professionelle Kamera ist würde ich mir die Nachlieferung von 2x Vectorscope per Firmware wünschen. Mehr Details finden Sie in diesem Forumsthread: http://www.dvinfo.net/forum/canon-xf...ml#post1728000 ANSWER: Sehr geehrter Herr ..., vielen Dank für Ihre Anfrage. Bei der Entwicklung der XF300 haben sich unsere Ingenieure dazu entschlossen eine zweifache Vectorscopedarstellung nicht zu implementieren. Dadurch, dass dies Darstellungsmöglichkeit nicht für Ihre Kamera vorgesehen ist liegt auch ein entsprechendes Firmwareupdate nicht zur Verfügung, sodass wir Ihnen diese entsprechend nicht übermitteln können. Wir bedauern sehr Ihnen an dieser Stelle keine andere Information übersenden zu können. Mit freundlichen Grüßen Canon Services & Support |
(Don't you just adore Google Translate? . . Meaning:"Glauben Sie nicht nur beten Google Translate?")
Well, that was a very fulsome and creative mind-expanding experience from Canon. Thanks for sharing Martin. Still a great camera. Grazie |
Ruh-oh....old thread revival. I just ordered a Pocket Camette only to now realize my vectorscope needs a 2x function. My Hamlet Microflex only has 1x and 4x. Is it possible to simply visually estimate and draw an imaginary line in my mind to where 2x the distance should bring the vector tip? The 4x function on my scope just seems to stretch and enlarge the vectors, I don't seem to remember it rearranging how they expand. I don't need heavenly perfection, simply looking to bring a lame stock JVC ProHD camera into line.......the damn thing won't even white balance properly, it's all over the vectormap!
I am having a hard time understanding how the only real color alignment charts on the market are incompatible with 99% of the cheap easily accessible scopes out there. Paul |
Another thread bump/update, simply because a google search brought this post to page 1 top of page.
A workaround I found somewhat useful, was to put the vector colors on 1x halfway to the boxes, then increase camera saturation until the most saturated color hit a box. Sort of like another version of faking 100% saturation. This method basically extends the color along it's path, so you can at minimum be on the appropriate and correct line, and balance your colors properly. Not perfect, but for most of us, works well enough for the accuracy of the equipment we are trying to align/adjust. Paul |
| All times are GMT -6. The time now is 01:29 AM. |
