-   Canon XF Series 4K and HD Camcorders (https://www.dvinfo.net/forum/canon-xf-series-4k-hd-camcorders/)
-   -   Concert Audio (https://www.dvinfo.net/forum/canon-xf-series-4k-hd-camcorders/494918-concert-audio.html)
Brandon Puet April 21st, 2011 08:44 PM
Concert Audio
I'm going to be filming a concert soon and will be stationed about 20-30 feet away from the stage. I know that an XLR feed would be the best way to capture the acoustics, but unfortunately that won't be an option for this event.
I did some testing and it sounds like the XF-300's on-board stereo mic is better at capturing the highs while my NTG-1 is better at capturing the lows.
Just curious to hear what people's thought are as to which mic to use.
John Gardiner April 22nd, 2011 04:38 PM
Re: Concert Audio
Seems like the obvious choice of using both would be ideal. Then mix out the weak frequencies in either signal.
Kirk Candlish April 22nd, 2011 04:55 PM
Re: Concert Audio
What's the music and what's the space ?
Can you record the board sound to a separate recorder and a scratch track on the camera and then sync in post ?
Steve Maller April 22nd, 2011 06:14 PM
Re: Concert Audio
This is exactly what my Zoom H1 is great for. Just get a 1/4"-1/8" adapter. Then toss the audio onto your Final Cut Pro timeline next to the video and run PluralEyes on it. The more audio sources from which you can choose, the better off you are.
Nicholas de Kock April 24th, 2011 06:18 AM
Re: Concert Audio
On-board audio is never going to give you good results. For concerts you need some sort of mic at the front of the stage. A stereo mic placed in the middle combined with "Levelator" in post does a good job at bringing out voices.
Colin McDonald April 24th, 2011 07:18 AM
Re: Concert Audio
Depends so much on what you are recording. Orchestral/choral concerts have entirely different needs from rock/electric stuff and if the latter, house mix and recording mix are different again. One thing in common - on camera mic will not give you good results for either.
Stephen Sobel April 24th, 2011 07:25 AM
Re: Concert Audio
Does Levelator work with Vegas Pro? Or would I use it ande then bring the audio tracks back in to Vegas?
