Syncing XF305 with second camera?
When doing multiple camera shoots, can the XF305 be synced with a XF300 or would it require a second XF305 or camera with a jack plate?
Re: Syncing XF305 with second camera?
Requires another camera equipped with Time Code Input and / or GenLock. The XF305 and XF105 qualify, but the XF300 and XF100 do not.
Wouldn't you be able to use the XF300 as the host by using it's video output (analog composite) to sync the XF305 to?
These camera's still use normal sync and not tri-level right? |
| All times are GMT -6. The time now is 11:00 PM. |
