-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   Tape Length Problems - Help Please (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/119795-tape-length-problems-help-please.html)
Howard Wilczynski April 20th, 2008 01:34 AM
I've been using Panasonic AY-DVM63MQ (dry lubricated) tapes. They have been great and I've had no problems with them.
I just found out that the show I'm going to record May 1-3 is 80 minutes for the first act. I went looking for the AY-DVM83MQ tapes, only to find they are discontinued.
The AY-DVM83PQ tapes are available, but they are the wet lubricated type and I know I'm not supposed to switch between lubrication types.
If I was only using one camera, I would try to do a quick swap during a black out. But along with my A1, I have a DV20 for a full stage shot, that I would have to change too.
Is it a good idea to clean heads on both machines and just use the PQs for the whole show, then clean them again after so I can switch back to the MQs?
Or are there any other dry lubricated 83 minute tapes I could use?
I guess if the timing is right and I won't know until dress rehearsal, I could switch tapes early on the DV20 at a black out then on the A1 on the next black out. But I would rather not do that.
Any other ideas?
Howard
Bill Busby April 20th, 2008 03:16 AM
I don't know who told you the PQ's have the wet lube process, but they're mistaken. All of the Panny tape line uses a dry process.
Howard Wilczynski April 20th, 2008 11:10 AM
A person on this page says PQs are wet. He says he got the info from Panasonic.
http://www.dvxuser.com/V6/archive/in...p/t-18737.html
That is what caused my confusion.
After reading your post I did a more detailed search and did find what you say to be true.
Howard
Kees van Duijvenbode April 21st, 2008 01:11 AM
Why not shoot in LP mode? I guess you don't see an y difference.
Howard Wilczynski April 21st, 2008 07:08 AM
I don't shoot in SD, I was using HD mode which doesn't have an lp mode.
Though I guess I could do that. But since I haven't yet used my A1 in SD mode and I don't have time to really test it before I have to shoot the show, I will just get some PQ 83 minute tapes.
Thanks for the idea though.
Don Palomaki April 21st, 2008 07:25 AM
When you change to a different type of tape, run a head cleaning tape first. You should be OK. The 83 minute tape has a thinner base stick, so it is a bit more fragile.
BTW, the tape lubricant incompatibility issue dates to the mid 1990s, and was resolved back then. However, it still makes the Internet rounds as gospel wisdom. As I understand it, the issue is other mechanical properties of tape that effect how tape wear deposits are left on the mechanism, and a cleaning tape usually takes care of it.
Note that the PQ tapes are probably subject to a somewhat less stringent level of quality control, so occasional tape read errors are a bit more likely. Be prepared to deal with that possibility.
Bill Pryor April 21st, 2008 08:15 AM
If at all possible you're better off getting a second camera, if you can borrow or rent one. Even if it's a single chip camera--you could set it up for a cutaway shot, start it up when you're about 5 minutes from the end of your main camera tape, switch tapes, and go back to it. Then you'd only have a minute or so of footage from the second camera to deal with. Maybe an audience cutaway would be appropriate there, or a significantly different angle, then the difference in quality wouldn't show up much.
Howard Wilczynski April 21st, 2008 09:25 AM
Thanks all. I think I will go with the PQ tapes for this shoot and clean the heads before and after.
Howard
