-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   Pal - NTSC conversion (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/142605-pal-ntsc-conversion.html)
Vincent Oliver January 28th, 2009 06:34 PM
Has anyone in the UK had their Canon XH A1 firmware/hardware converted to shoot in NTSC, if so does it work, how much was it and where did you get it done.
Chris Soucy January 30th, 2009 03:11 PM
Hi Vincent.................
1. Most probably.
2. Yes.
3. Don't know, ask Canon
4. Here:
Canon (UK) RCC
Projectors, Professional Camera, Lens, Digital Video, Webcameras, Scanner, Binoculars, Professional Lens, Flash, Analogue Compact Camera, Analogue SLR Camera, Digital SLR Camera
(Note: Video - including HD models; Scanners - only dedicated 35mm Slide Film Scanners {2700F, FS2710 & the FS4000 models})
Unit 130 Centennial Park
Centennial Avenue
Elstree Hill South
Borehamwood
Elstree
Hertfordshire
WD6 3SE
Tel: 0844 369 0100
Fax: 0844 892 0849
Web: Canon UK - Home
Any help?
CS
Vincent Oliver January 31st, 2009 02:48 AM
Thank you, I will get in touch with Canon
Ian Wright January 31st, 2009 04:36 AM
bear in mind that you can pickup a used ntsc A1 for approx £1400.
Ian
Festival Video and Audio Previews - Festival Previews Ltd
Vincent Oliver January 31st, 2009 05:07 AM
Thanks Ian,
The reason I posted this question is because I was in the middle of an NTSC shoot (using my Sony PMW EX3) and the tripod collapsed. The camera hit the deck and lens is a total write off. I need to get the NTSC DVD project completed asap. The Canon will be away for about 10 days, which is too long for me, and I also want to continue shooting tapeless.
I have purchased a new lens for the Sony (£1050) and should be able to continue shooting on Wednesday. I will save the Canon for other PAL work
Thanks for your help
Jonathan Shaw February 1st, 2009 02:55 PM
They charge $600 AUD for the conversion here in Oz...
Pretty steep for a software upgrade I reckon
J
