XH A1s, Me, and Tornadic Supercells . . . Perfect Together?
Hi.
I hope this isn't one of those hackneyed posts that veteran members of the site/accomplished users of the XH A1 tend to loathe. I apologize in advance if I fall into that category. Thing is, I have no real world experience with the camera and I’m seriously contemplating pulling the trigger on one. Within the context of the intended use, it's possible my interest in the camera borders on delusional and I will patently offend some folks merely by considering ownership. In the spirit of avoiding that, I was hoping to provide a little information about the application and receive some feedback from XH A1 gurus as to whether or not the camera is a good fit. First, I am far from a professional. In fact, the camera will see only minimal use outside the one month out of each year that it will be wielded in excess. From mid May through mid June, I wander the Great Plains with the goal of witnessing and documenting severe storms and tornadoes. For many years now I’ve relied on the ever proficient Sony PD170, which has always served me well in the varying, and often low, light conditions that typify the immediate storm environment. This spring I’d like to graduate from SD to HD. After doing a ton of research, I’ve settled on the XH A1s. The primary impetus for this is the .04 Lux rating that can be accomplished by dialing in the appropriate setting(s). Consider that: - I am reasonably practiced in the basics of photography/videography, but I am not exceptionally savvy in the more intricate nuances of the art, nor am I very skilled at solving complicated settings. Overall, my photographer’s/videographer’s IQ is much closer to the basement than the attic. - I have a little under three weeks before I leave on my annual chasing trip. Given the steep learning curve that I’ve read is inherent to the XH A1s, is three weeks, or under, enough time to learn what I need to about the camera to use it effectively in the field? - I need a camera that will perform well in varying conditions of low light. Does anyone have any experience shooting in or near the immediate storm environment or in a setting of similar ambient light? - I'm sure I'll need to seek suggestions in respect to tweaking the settings to their optimal levels for my application. I see that there is a Custom Preset Library on this site. Does anybody have any specific recommendations for custom presets that would be conducive to the environment in which I’ll be shooting (such as gain, white balance, frame rate, etc.)? How involved (complicated) is it to install these presets on the XH A1s once you download them from the library? - The camera will do a lot of hibernating between chase trips. That begs the question: Too much to pay—too much camera—for such comparatively little use? In the end, I'm just trying to gauge whether or not the XH A1s is a logical choice for someone of my ability (or lack thereof) and for the intended application? Input is greatly appreciated. Thanks a lot, -- David |
The XH A1s has more selectable options, but you can select from dead simple Auto which leaves everything up to the camera, to full on manual where the decisions are yours. You can pick from an virtually infinite combination of things you want to control and leave the rest up to the camera. Remember too, that you'll learn a lot while you're out shooting on the Plains, and it's always best to more control than you need rather than less. Quote:
If you wanted to drop down in price, you might consider the HV30/40 for a lot less money. It will not do as well in low light but it does have some decent controls and can produce stunning footage. I have an HV30 and it matches very well with my XH A1. Quote:
BTW... If you do get one, you'll want a rain cover unless you're always shooting from inside a vehicle, and you might even want one then. It's protection for your purchase. |
Hi guys..........
It might be a little more pallatable to the wallet to buy an XH A1 second hand instead of going for the "S".
Same brilliant performance but a few less bells and whistles that I really don't think you'd miss. There's one for sale through the "Private Classifieds" here on DVinfo (which you probably can't see as your post count is so low) for $2500. Haven't really needed to compare US/ Canadian prices so don't know if that's good, bad or indifferent. A good condition s/h A1 has gotta save you some pretty big bucks over a brand new A1s. CS |
Go for it... the camera is pretty straightforward. If you want to save some dough go for a straight A1, or as mentioned in previous post go 2nd hand.
If you want good low light capability and don't require XLR I would go for a Sony FX1000, it is much better then a xh-a1 in low light. I own a xh-a1 and have compared my camera with a fx1000 and the biggest difference between the 2 is that the Sony handles gain way better then the canon.
The canon will allow only 6db and after that things start to look real ugly quick while the Sony can go up to 18db gain and still doesn't look worse then the canon at 6db gain. Also the second big difference between the 2 is the lcd viewfinder which is way better on the fx1000, much bigger and more resolution which will make it easier to focus. It is also cheaper then the xh-a1s. That doesn't mean a xh-a1s would be a bad choice because I really like working with mine but when things get dark I often wished it would be like my old Sony vx2100. A lot of times I have to film at 1/25th shutter and 6db gain to get the most out of it at poorly lit receptions, pushing it further to 12db gain results in real ugly grain. regarding the presets that you can use with a xh-a1, if you are filming in dark situations, never use them, it's much better filming as flat as possible and correct later in post. In that way you can be sure you get all the detail the camera can handle from the start and correct later if necessary. All presets will do that correction during recording and that could result in loss of detail, colors that don't look right of ghosting. That is, if you choose the wrong preset, once it has been recorded with a wrong preset there is almost no way to correct it afterwards. |
If you want to go for a prosumer camera then you should get the Sony FX1000 or a second hand FX1 or FX7. One of these would be alot cheaper and the menu system and controls are just like the PD170 so you wont have to relearn them.
Otherwise go for a Canon HV30/40 as they are alot cheaper. If it was me then I wouldn't bother spending all the money on an A1 if your only going to use it once a year. |
Thanks a lot
Thanks very much for all the informative responses. It was advertised to me that there is a ton of knowledge on this site and I see for myself now that it’s true. The advice is greatly appreciated.
Thing is, the SW end of a supercell, where you typically find the embedded circulation (mesocyclone) that sometimes results in a tornado, is also often the most electrically charged region of the storm. It’s not uncommon to experience constant cloud-to-ground strokes and brilliant inter-cloud flashes around a tornadic circulation, which damages (distorts, blurs, etc.) the footage of the tornado you’re attempting to shoot. For instance, my PD170 (with its three 1/3 CCD) chips keeps the tornado in crisp focus (when set to Infinity) and at the same time captures the strikes/flashes with no noticeable distortion. If my chase partner, with his Sony HVR-Z5U, is shooting the same tornado from the same perspective, every discharge completely washes out the field of view. For as long as an individual discharges lasts, it’s akin to pressing your eye right up against a flash and pressing the shutter. It’s not something that he’s been able to correct in post, either. If he were the only one experiencing this effect, I’d say it was him, his camera, or both. But many chasers have voiced the same experiences with CMOS sensors. This was a big motivating push toward the XH A1 for me. You get the 20X glass of the FX1000 and the like, but with the trusted and proven CCD chips. If anyone who uses the FX1000/HV40 has had an antithetical experience shooting lightning, I’d be interested to hear about it. I’m doing my best to open my mind to these two alternative before I make a final decision. Quote:
This sentiment: Quote:
It was plain eerie. We were literally glowing. One of the weirdest refractions of light I’ve ever seen. Perhaps such an example of ambient light is one of the reasons the XH A1 works better in low light outdoors than in? Quote:
BTW, B&H has the XH A1 for $2999. Doesn’t seem too shabby for a brand new model, does it? Quote:
Again, I am very grateful to all of you for the valuable input. It’s definitely a huge help in making the right decision. Thanks for taking the time. Anxiously awaiting further insight . . . --David |
I'll just add one comment to Presets. There is a preset called PFVISION that performs extremely well in lowlight situations without having to kick the gain up real high (although you can do that as well). I used it recently and was pleasantly surprised by how well it worked. In fact it is brighter than the factory default preset. I can't comment on how it will work with lightning, however.
I'd say the XH A1 is your best deal because of the lens. If money is tight, you might see if B&H still has the XH A1 models in stock. They're about $800 cheaper than the new S model and you'll get the same quality.
While the old PD150 is probably about 1/2 stop better under low light than the Canon, with HDV the resolution is high enough that you can boost gain a little if necessary. I normally shoot under good light and use the -3db setting. My first "high gain" setting is zero db, and the next is +3. You can change those in the menu. For example you might want a +3 and a +6 on the external switch so you could change quickly, although I wouldn't recommend shooting at anything beyond a +6. Of course the more you zoom in, the more the lens stops down. Still, I've been around tornadoes a lot for years and it doesn't get all that dark unless they happen at night. Normal settings should be OK in most cases. While $4K may be expensive for the amount of work you do with the camera, I don't think you'll find anything comparable for that price. The equivalent Sony (the Z5 or Z7) is more expensive. Also, you want a good, reliable camera for that kind of shooting. The PD150 was a great choice in its time. |
David... Your level of consideration of your purchase is approaching mine. (grin)
As to the two low light statements, my racing venue at night has more light than most indoor environments. I'm going to assume that the other poster shoots weddings which are notorious for being light-free environments. Having lived on the plains and been in tornado weather, it's still lighter outdoors in those conditions than it is under indoor lighting. No... I've not measured the light levels. It's just what I remember and the Alzheimer's isn't too bad tonight. With the Canon, you might want to set the gain to 0, +3 and +6db. It's what most people use from what I've heard/read, and you can count me amongst those "most people". You are also dead right on the CMOS sensors. I forgot to consider lightning, so anything using them is right out. US$3k for the original XH A1 is a good price, I don't think you'll miss the upgrades the A1s has. You might want to check B&H's used gear. You could save a few hundred if that's important in your decision making. Right here, right now, debt for me is bad so I try to avoid all I can. But that's just me. |
Regarding presets, the ones that I have used that are specifically made for dark circumstances all produced ghosting in the image. That is ok if you are working on a tripod and if there is not much moving in your image but i guess you guys are doing a lot of handheld filming? About the 20x zoom the fx1000 and the xh-a1 has, the 20x zoom of the canon zooms in further then the Sony, I have seen the difference, it's not much but there is a difference . |
Don't get me wrong, I"m not making fun of you. I only wished I possessed the same kind of writing flair you have. |
Your statement about tornadoes is dependent on the angle/direction from which you are viewing the storm. If, for instance, you're looking W at a storm whose motion is true W to E, your field of view will, in fact, be exceedingly dark as the full precipitation core will be between you and the primary source of intervening ambient light (the sun!). Of course, core density varies greatly. Let's assume, for argument's sake, though, that we're talking a 65+ dbz core (which is hopelessly dense). Very little, if any, light is going to penetrate that degree of density. If a storm is expansive enough—such as the Kress/Turkey, TX supercell of May 29, 2001 that spanned the entire breadth of a large county—it can actually preclude all ambient light and cast the sky in a deep murk that mirrors the darkness of full night, especially if you’re also standing beneath the downwind anvil shadow. With virtually no light refracting through the storm, many cameras are known to struggle with pulling contrast, even when the settings are optimally adjusted for those conditions. Then there are the many tornadoes that wrap almost completely in rain, but whose outlines are discernible if the camera is able enough in low light. In the case of a tornado that is well displaced from the precipitation core, spawned by a discrete cell that is otherwise surrounded by sunny conditions, sure, the immediate proximity of the tornado isn't that dark. But that's most definitely the exception, which is why I'm seeking an HDV camera that is adept at handling low light. Quote:
David... No actual Alzheimer's yet. Just perceived.
If you search the XH series list you'll find a comprehensive list of the differences between the A1 and the A1s. From what I recollect, I don't think there are any "gotta haves" with the A1s given your needs. Here's what I remember that is improved on the A1s... - Can zoom and focus manually (probably the biggest deal) - OIS on/off programmable to a custom button - Can take mic input on one XLR input and line input on the other - No standby switch (not a biggie) There's no difference between the two models when it comes to the optics, which is the biggest thing based upon what I understand about your situation. Too bad you missed at B&H. Their offer on the A1s is pretty good. If you can't find an A1, I'd pull the trigger on it. BTW... Noa's right. You can turn a phrase with the best of them. Me... I write like English is my second language and I was born in the US! Maybe it is setting in for real. (grin) |
Just to add to Tripp's note on differences - not only are the optics the same, but the CCD/image processor setup is the same.
Think I'm going to lock into an A1s from B&H. They're now down to $3399, which seems pretty reasonable. With the savings from the previous quote they gave me, I'll pick up a Tiffen UV/Polarizer Twin Pack. Quote:
Another thing about the manual focus of the xh-a1; I also own a dvx100b and that one is way better on precise manual focusing. The xh-a1 is quite difficult to get the focus right, especially if you are working with the lcd screen which is also much too small. |
Be careful this. With HD, focus is more critical than SD and if you focus all the way out you'll want to be shooting the moon or something that distant. Presetting to what the camera will indicate as "infinity+" will likely be too far away unless you are 1/2 mile away from the storm. Infinity is probably a better choice. You'll know what I mean when you get the camera. Quote:
| All times are GMT -6. The time now is 05:28 PM. |
