-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   Capturing in 24f the audio is out of sync (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/236467-capturing-24f-audio-out-sync.html)
Michael Thames May 31st, 2009 04:42 PM
Is there some kind of quick fix for this?
Michael
Bill Pryor May 31st, 2009 06:35 PM
Is the audio out of sync when you play it back in camera or after you capture it in your NLE? If it records out of sync, then there's something wrong with the camera and it should be sent to Canon.
If if goes out of sync upon capture, then there are two possibilities I know of--one is that your capture settings aren't right, and the second is that your computer doesn't have a processor capable of playing back HDV properly. When I first got my XH A1 it was on a weekend, so I captured some test footage into my old 12" iBook. I had installed FCP just so I could do that. Everything played back out of sync. But when I transferred the original files to my editing computer at work, they were in perfect sync.
There might be one more possibility...if the mic was really far back from the action, like at the back of an auditorium when shooting a performance on a stage. You might could be a frame out that way simply because of the distance the sound has to travel.
The fix is to determine in your timeline how far out you are by shifting the audio track or tracks back and forth a frame at a time. Slide the track one way by a frame and if the sync is worse, slide it the other way by 2 frames (one to make up for the first shift), and do that until you get it.
Jeff Lower June 1st, 2009 07:48 AM
I've just noticed a similar problem with my video. I've captured in PP CS4 and every so often it drops frames and inserts red frames in its place. Does the same thing with PP CS3 as well.
Been searching around a bit for a way to fix this. Any help would be appreciated.
What NLE are you using?
John Stakes June 1st, 2009 08:11 AM
A temporary solution is to capture using MPEG-Streamclip.
JS
Bill Pryor June 1st, 2009 08:15 AM
I use FCP, no problems.
Michael Thames June 1st, 2009 09:09 AM
Hum...... I thought this was a well known issue.
When I first got my A1, I captured some footage with 24f in Imovie, and it was out of sink with audio. I called a fellow named Mike on a Canon hot-line given to me by the regional Canon dealer. Mike said, if I use 24f the audio will be out of sink. Now, I don't recall if it was an issue with Apple, as when I just play back 24f on my camera everything is fine, it's only when I capture it.
I have FCP now and completely forgot about this problem until this weekend when I switched over to 24f.
I'm capturing a concert I shot last night in 30f. So I'll wait and see how this turns out in about a half hour.
Bill Pryor June 1st, 2009 12:04 PM
It's not an issue. One of the major reasons people buy the XH A1 is to shoot 24F. I've never seen out of sync audio and I've worked with 4 XH A1 cameras other than mine. You have to edit in a 23.98 timeline for 24F.
Michael Thames June 1st, 2009 02:23 PM
Final Cut Pro converts the capture to whatever the time line is set to automatically, so I don't think that's the problem. After posting this question I recall the problem is with Apple software. Last time I had this problem was on Imovie, so maybe FCP has resolved this problem?
Are there any Mac users out there that know what I'm talking about?
Dany Badaoui June 1st, 2009 03:23 PM
try capturing with HDVSplit, it solved everybody elses problems with audio being out of sync including mine.
Michael Thames June 2nd, 2009 06:52 AM
Pardon my ignorance but what is HDV split? Is it a setting in Final cut?
Michael
Dany Badaoui June 2nd, 2009 07:00 AM
im not sure if it works on mac but its a capturing program. google it all the info should be there
Bill Pryor June 2nd, 2009 09:53 AM
I also captured in iMovie as a test one time, and there were no sync problems. And in my older version of FCP, the 5.x, I didn't have any sync issues either. I don't see how it can be anything other than a capture setting, mic placement, or something in the camera that needs service. Again, have you played back in camera and watched in the viewfinder, out to a monitor to see if the original tape is in sync?
Michael Thames June 2nd, 2009 10:36 AM
Thanks Bill. Yes, it plays in sink on the camera in the the viewfinder, but once I download it into final cut it is out of sink. Yesterday, I downloaded some video I took of a concert, but I recorded it in 30f, and it captured fine. All the other footage I did in 60f works too. I only have the problem in 24f.
I think I'll give the Canon guy a call today. He told me a couple of years ago when I got my XH-A1 that it wouldn't sink with the audio in Imove. Maybe he can update me on this. I'll get back to you once I speak with him.
Michael
Bill Pryor June 2nd, 2009 04:03 PM
I may have to backtrack here about iMovie. FCP does my 24F fine, but I'm thinking about the time I was messing around with iMovie, mainly using it as a monitor, which works better than FCP for that purpose and the live thing was in sync (although with a delay of a couple of seconds from the live action). I'm not sure that when I did an actual capture in iMovie that it was 24f. It's more likely it was not and that iMovie does not do 24f. I think I was confusing iMovie with my earlier FCP system on a different computer. In fact, I believe I have read that iMovie will not do 24p of any sort.
But you said you're using FCP and it's out of sync, and then you mention iMovie. Are you bouncing back and forth between the two? If you're having a sync problem in FCP, that is a problem and it's got to be either in capture settings or a slow processor, since you said the footage plays back OK in camera. If you're trying to do 24f in iMovie, check your iMovie documentation...I think it does not do 24F.
Michael Thames June 3rd, 2009 06:54 AM
No I haven't used IMovie since I got Final Cut Pro a year and a half ago. I just remembered after recently capturing 24f in FCP and having the audio sink problem, that I also had this in IMovie.
But yes, it's as you describe, the Audio is about 2 or 3 three seconds delayed in FCP. I called the Canon guy Mike yesterday and left a message, but he hasn't called back yet.
I don't think my computer is a problem it's an IMac 24 inch, I just got it last year.
Bill Pryor June 3rd, 2009 10:07 AM
And you've checked that the audio is in sync when played back in the camera. That means it has to be a capture problem of some sort. That iMac is fine for editing HDV; I have a friend with a year old iMac 24" and he shoots nothing but 24F. Are you capturing 1080p24, and then editing in a 23.98 timeline?
Josh Glowicki June 5th, 2009 04:43 PM
i just had the same issue a few days ago. i was freaked out b/c i didnt know if i had just recorded the whole thing wrong when i shot it. when i captured in imovie my audio was off but once i got into fcp 6.02 it was perfect.
if your using fcp make sure your settings are for 24p!!!!!
Michael Thames June 6th, 2009 09:51 AM
Thanks Bill and Josh, I was waiting around for days for Canon to call me back but no luck. I then set the settings to 24p as you guys suggest, and that solved the problem. For some reason I was confused thinking that whatever settings of the clip one imports, FCP automatically will adjust the settings to accommodate the timeline, and I was still spooked by my experience in Imovie.
Thanks for helping, I'm happy to know I can utilize 24f again with no problems.
Michael
Bill Pryor June 6th, 2009 03:15 PM
Glad it's solved.
