Yes, Kevin is right, there is no real difference in sensors or image quality etc between the FX1 and Z1 cameras (just the better handling and settings options of the Z1 body).
Stu's right - the FX1 and Z1 are identical (barring production tolerances) in the low light stakes. But the Z1 has the option of the 'hyper gain' (fun to play with, almost useless because of the grain) and black stretch.
Black Stretch adds noise, and therefore uses some of the low-light sensitivity, i.e. reduces the photographic "speed" of the camera. The usual solution is to reduce the bandwidth of the front end near black, this lowers the noise level a little. Most of the small cameras don't follow the normal gamma rules anyway, they often use modified curves that have a built-in knee to cope with overloads, my old MX300 does this very nicely. tom. |
In hindsight it would probably have been better to leave both cameras on 'normal' instead of trying to match in-camera by using separate Presets, as this would have made it easier to match in post. The problem is that I love the end results that the XL2 Presets provide and don't think that it can be quite matched by using computer software adjustments during the editing stages. Obviously footage from the XL2/G1/A1/H1 group of cameras would be a lot easier to match each other. |
The brownish cast implies to me that the white balance of the Z1 was screwed up. I've seen lots of footage shot with the Z1, as well as the XL2 and have used both myself. Both cameras give excellent color.
I've seen awesome footage from his Z1, so I'm not saying that it is not a superb camera, but more that the XL2 produces footage closer to my personal taste - and that trying to match the two is not easy for certain subjects. |
Hi Guys
I too had a hard job matching the footage from the two cameras, so it comes as no surprise that Tony found the same... to me the XL2 footage was too greeny/blue... Quality and sharpness were about the same but colours were way off...and correction in PPro was not easy... for my DVD and webvideos it scraped through ok... but I took three or four goes before I was satrisfied.... I also actually found my Z1 too red/brown... (just out of the box, since my FX1 got stolen, so perhaps this was what Tony was seeing..).. this has since been toned down for better results.... I've also been downrezzing my footage from HDV.. is this a good move? or would my shots have been better on native Dvcam??? .... Naturally the HDV rez is far higher than the XL2 but am I crippling this by using the in cam down-rez...???? I 've not got the PC power to downrez after acqisition...so a new PC is on the cards as soon as funds allow... Anyway I now continue shooting in HDV, to future proof good sequences, and outputting, DVD and Webvideo material.. so the camera is paying its way.... Hope to hook up with Tony soon for more fun fishing... Regards Gareth |
Maybe if you're considering intercutting Z1 and XL footage again, it may be better to switch the Z1 to its DVCAM mode. That way you avoid the down-rezzing and shooting native DV may be a better match.
tom. |
| All times are GMT -6. The time now is 06:02 PM. |
