-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   Color Saturation (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/79922-color-saturation.html)
Monte Raynor November 18th, 2006 08:38 AM
Color Saturation
The colors on my A1 seem a little bland to me. I am unsure which control to adjust to punch up the saturation a little. The posts I see with this camera do not look like the colors I am getting. Thanks for any help......
Newbie
Monte Raynor November 18th, 2006 08:57 AM
Disregard..... I RTFM and found what I was looking for...but any experience with changing these settings is still welcome.
Barlow Elton November 19th, 2006 12:19 PM
Try changing the gamma to Cine2 and up the color gain to +10 or +20, and make sure the color matrix is set to Cine2. Try setting the knee (highlight compression) to low and put Black to middle or press. Maybe turn sharpness down to -3 too. Sometimes dropping the master ped to -3 or -4 can look nice if you like a more contrasty look.
Just a few tweaks for a generally pleasing picture in most situations.
Eric Dyer November 20th, 2006 03:36 AM
Color Gain
Just did a nature shoot. Turned up the color gain on the reds, and greens. Shot with the blacks on Press. Looks really nice, a lot better than out of the box IMO.
would love to show you guys some footage, I plan on capturing it by Tuesday.
*e
Bill Doyle November 20th, 2006 06:35 AM
As a newcomer to all these adjustments (I had a GL-1 for over 5 years), I would welcome opinions on settings and a little real-world thoughts on what they do. I've read the manual and looked at Canon's Image Adjustment section on the website, but it's more technical than practical.
Jason Strongfield November 20th, 2006 08:51 AM
depending on wht type of filming you do, but in narrative, it is easier to CC clips that are a little flat in colors.
Alex Leith November 20th, 2006 09:50 AM
I'd agree with Jason about shooting flat. I shot 4 DVDs over the summer (with DVX100s). Two I tried to create the look in camera, and two I shot fairly "neutral" and pepped up in post.
With the first DVD I'd gone a little overboard with the crushed blacks. Initially I wanted to create a very contrasty look - but by the end I felt a much softer look was more appropriate.
However, you get much better results crushing blacks in post than you do stretching them, so I had to choose between an image that was either more contrasty that I wanted; or rather noisy in the shadows.
Personally, wherever you're going to do CC, I'd go for capturing the widest dynamic range possible - low knee, stretched blacks - and tweak it out in post.
Tom Roper November 20th, 2006 10:16 AM
*e
Be careful with simple RGB gains/cuts. They affect the white balance. Check your shots of cloud whites and gray areas of the clouds, they may be tinged.
Sometimes it's more appropriate to tweak the kelvin settings in the white balance to achieve the warmth you are after.
Mark Fry November 20th, 2006 11:14 AM
I've seen comments elsewhere that the higher degree of compression used for HDV (compared with DV, for example) means that one should try a little harder to avoid post-production processing. If you know the "look" you want, and you can get it in the camera, then that will save time and picture quality further down the line. Does this sound sensible?
Peter Ferling November 20th, 2006 12:40 PM
True words Mark. It's best to dial the look in when you setup the shoot. Post is usually meant to "fix" things. However, it's really hard (when dealing with 8bit compressed media) to get a computer to see what the camera couldn't put on the tape in the first place.
Peter Ferling November 20th, 2006 12:46 PM
Let's put it another way. When dialing in a look within a camera, you working from a 4:2:2 10,12, or 14 bit master (depending on the internal A/D) and then laying that to tape. After which it's now an 8bit compressed copy. Which master would yield a better result? From which process do you have the advantage?
Eric Dyer November 20th, 2006 12:47 PM
Didn't boost the gain too much, I mostly shot tight shots of flowers/plants, animals, and a waterfall. However one shot of the sky appears natural looking, thanks for your input.
*e
Alex Leith November 20th, 2006 02:49 PM
Yes of course... My point simply was that it's easier to give it a particular look in post than it is to "undo" a look that you've created in camera (but of course moderation is the key when it comes to post processing highly compressed formats).
Philip Williams November 20th, 2006 03:03 PM
For what its worth I've pulled 24F footage from Kaku into After Effects and performed some pretty severe color corrections on it - far more than you'd ever want to on a real project. And I was shocked at how well the stuff worked. I think that's what actually pushed me over the edge to get the XH A1 rather than wait another eternity saving up for an HVX.
Peter Ferling November 20th, 2006 03:45 PM
You have to be abosolutely certain of accepting the look that you dial in (or paint) during the shoot. The same issue that limits your adjustments in post, will also hurt you if you wish to go back.
Which is why some crews find it an absolute must to hire an extra hand just to tote the broadcast monitor around for mobile shoots. (Never trusting the LCD or viewfinder beyond framing and focus). So if your not using a quality monitor to for a good approximation, then shooting flat is your best bet.
Another issue is being both camera man and editor. If you know a filter will aide or avoid some post issues, then it's a no-brainer.
Larry Huntington November 20th, 2006 06:23 PM
I slightly drop the blacks in post in FCP and raise the saturation a bit-not too much. Not every shot needs this, but even with a customized preset in-camera, the post effects noted above seem to give the images more dimension. This is my experience mostly with Canon, not Panasonic. Panasonic presets seem already on the borderline of too much color. Personally I would rather shoot a flatter image and bump it in post. It gives you more creative options on the timeline.
I'm getting nice results when displaying on a 100" Sony Pearl Projector and the XH-A1 via component out and SD-DVD fom an HDV timeline in Final Cut.
Kholi Hicks November 25th, 2006 02:41 AM
I've been debating this over at DVXuser.com in regards to CCing A1 footage and HVX footage. It seems that the A1 footage holds up SO MUCH BETTER than the HVX footage, regardless of the 4:2:0 compression.
I'm glad I'm not the only one seeing this!
Kholi Hicks November 25th, 2006 02:43 AM
Agreed on both points. The DVX100's color-rendition was great. The HVX200 seems to shove everything a bit over-board. I am trying to find out how you back away from all the ultra-saturated colors.
