Canon XH A1 Useful Accessories?
My XH A1 arrives Dec.27th. Yahoo!! What usefull accessories do others have and recommend for this camcorder for general use? I have the uv filter. What about the Canon VL-10Li II video light?? Canon SBR-1000 shoulder brace? Is an external mic necessary or does the internal mike give good pickup? Thanks in advance.
The 2 things I picked up for the XH-A1 were the BP-970 mammoth battery and a J-Rod.
The J-Rod will allow me to mount my Rode VideoMic + Sony Video light + my potential Seinnheiser wireless reciever on the camera cleanly. Will post a few pix in a day or 2! |
Michael,
What's a J-Rod? Couldn't find it at B&H, who makes it & where did you get it? |
Found it: http://www.thej-rod.com/
(have also a look at: http://www.dvinfo.net/conf/showthread.php?p=595710 where Vito DePhilippo used a broom stick to the same effect...) |
I've attached some pix of my full XH-A1 setup to illustrate the J-Rod in action.
http://www.dvinfo.net/conf/showthrea...862#post596862 |
Would it be possible to attach and use the Sony Video Light (HVL-20DW2) to the A1 without using the J-Rod? |
^^ yup just attach the light to the hot shoe on the front of the cam.
Depending on what kind of work you do, You can get much much better result with a shotgun mic.
100% agreed, I purchased the Rode VM for my HC1 and would rather invest in a seinnhesser wireless lav system before upgrading to a shotgun mic, altho the Rode NTG-2 is tempting. For now the Rode VM will suffice.
Anybody try using the Canon VFL-1 video light on a Canon XH-A1?
The XH camcorders do not have an Advanced Accessory Shoe which is necessary for powering a VFL-1 or VL-3 video light. The shoe on an XH camcorder is "cold," or unpowered, although it will communicate with an EOS Speedlite photo flash.
None of the AAS devices (such as the VFL-1 or VL-3 video lights, the DM-50 microphone, or the MA-300 XLR audio input block) will work with the A1 or G1. |
John,
It depends on what your going to shoot with the cam. If your doing pro work, a good mic is pretty essential. (I've been very happy with the Senn ME66 - Very light, tough, & good sound) Though an on camera light has it's uses for sure, it can not replace "good" lighting, & that includes making the best of what light is available. Even with still photography, an on camera light is rarely the lighting of choice in pro applications, unless of course your doing a wedding or such. |
Thanks for all the feedback from everyone. Will start by researching a good microphone.
The Firestore FS4 HD's and Pros work flawlessly with the A1's in case you want to go tapeless (or taped backup)....you might consider it as an "accessory" for the A1's!
With all the possible accessories that we could add, I always let my current project dictate any new equipment.
For instance, I just finished a project on insects, for that it was a no brainer, I needed close-up lenses, before that I did a project with a lot of interviews, so I invested in some lighting & a wireless mic etc... If your getting a mic and getting one that isn't stereo, you might want to pick up a Y cable for it so you wont have to cut & paste all the the audio into both tracts. |
John,
Congratulations ! Michael is right about the shotgun being a great addition. We use the Senn ME66/K6 combo, but it is pricy. Many others use the Rode Videomic and like it and it's a lot more friendly in terms of price. And if you do go with a shotgun please take a look at the J-Rod as Michael pointed out. I am not sure about the lens, but with the Z1's our first addition was a wide lens. We got the Sony, and then another wide from Century Optics. The quality is equal, but the Century mounts with a bayonette twist, and the Sony is a screw mount. I like the bayonette better. Best of luck ! |
buy it right the first time and save money.
AT4073a outdoors AT4053a indoors |
"I am not sure about the lens, but with the Z1's our first addition was a wide lens. We got the Sony, and then another wide from Century Optics. The quality is equal, but the Century mounts with a bayonette twist, and the Sony is a screw mount. I like the bayonette better. "
Shouldn't need a wide adapter unless you need to get super wide. The Sonys 20x lens (v1 at least) starts with a 35mm equivalent of about 40mm +-, where the A1 is about 28mm so they added the extra zoom on the wide end, which is great... This is really a do all lens, with just a few exceptions. PS- How do you get the blue boxes around quotes? |
Ancient Chinese Secret. :-) Just hit the "Quote" button instead of "Reply" and it will put the last post in a box. You can edit what appears in the box, but leave the html stuff. Glad to hear it's a wider lens than the Sony. I am liking the sound of the A1 more and more. That extra lens makes the camera very front heavy. Happy New Year ! |
I believe the stock Canon A1 lens equates to about 32mm in 35mm comparative terms. With the .8 wide angle, it then goes down to about 25.6 mm equalivalent. I enjoy working with wides, anbd really like the fact that the A1 is lilely the only cam in its class that can go that wide with such a high quality result. Canon likely beats out most after-market lenses in terms of quality build and photographic result.
The Canon .8 wide angle also allows me to use my A1 in my daily workout routine. No more long hours at the gym! I can now do arm curls with the A1, and get quite a good workout. Feel the burn! (Just kidding 'bout that--it's a great lens, but it is HUGE). |
Happy New Year ![/QUOTE]
Thanks! Yes my mistake, it is about 32mm, but that is a big difference to the 39-42mm equivalent that is more the norm. I agree about the wide angle & like to use something in the 24mm range, but the .8 on the 16X lens, brought it down to about 32mm which was wide enough for most shots. |
Accessories for outdoor use?
Hi Everyone,
I just ordered a Canon XH A1 last night. I currently have a Canon XL-2. I found that the XL-2 is too cumbersome for my needs. I've been leaving the lens off because the manual says a shock could cause the heavy lens to break off. I haul the camera around on the trails with me. The A1 is smaller, a little lighter and has a lens that stays attached. I thought it would be a better fit. I'm going to sell my XL-2. I have a few questions. 1) Does the A1 work well for shooting fast (45 mph) objects? Maybe another way to ask that question is, does it shoot fast moving objects any worse than the Xl2? The XL2 worked well. 2) How good is the built-in microphone? I have wireless mics. But once in awhile I will have to shoot someone standing 10 feet away (outside) with some background wind. Should be considering a shotgun Mic (or another style) with a windscreen? Using a boom is not an option. I would need an on-camera mic in this situation. 3) The camera will be exposed to a lot of dust. The only protective cover I have found for the A1 is this portabrace. It doesn't look like a great design to me. Has anyone found anything better for dust protection? 4) I have an Azden wireless mic transmitter. What would be a good bracket/means of mounting it to the A1 that would work well both on a tripod and handheld? Thanks for any suggestions and recommendations you can offer! |
70 views and not one response? Nobody has an opinon or suggestion????
im sure the portabrace has good dust protection otherwise they would not mention it on their website. the front section has a rubber band material that hugs the lens hood. Combine that with a 72mm filter and you're set for the front protection. as far as the sides? you may have to use the viewfinder instead of the lcd. |
Hi Doug
Hope this helps! |
| All times are GMT -6. The time now is 06:59 PM. |
