-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   Shock Mount (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/87210-shock-mount.html)
Martin Saxer February 22nd, 2007 02:26 AM
Shock Mount
Dear A1/G1 owners,
I have a simple question about the microphone mount:
How is it fixed to the handle? Scews? Is it detachable?
Martin
Bill Busby February 22nd, 2007 04:04 AM
The 2 small screws on the right side of the body.
Bill
Robert Garvey February 22nd, 2007 05:48 AM
Yes, detachable.
I took mine off.
Chris Hurd February 22nd, 2007 07:41 AM
It is not a "shock" mic mount. It's just a mic mount.
(If it was a shock mount, it wouldn't break off so easily... but it can and will break off if you're not careful).
Screws, etc. in pic at http://www.dvinfo.net/conf/attachmen...4&d=1159810999
Bill Ball February 22nd, 2007 08:28 AM
I took mine off first thing. Be sure to use a good quality precision screwdriver that fits the heads. Those little screws are in there pretty tight and you dont want to strip the heads.
Barry Richard February 22nd, 2007 07:58 PM
BAD design !!
they should have used a screw that would have made it easy to swap off/on according to need (not something that requires a jeweler to remove.)
This is beyond not constructing it so that its a true shock mount
As it is, it would be better to have a second or third cold shoe (for a mic, light, wireless)
Bryan Suthard February 23rd, 2007 08:31 AM
I took off mine and I second that those screws are SUPER tight. I suggest a really good carbon tipped screwdriver. Not one of those cheap jeweler kits.
Chris Hurd February 23rd, 2007 09:05 AM
I suggest that once you take the mount off, put the screws back in those holes and cinch 'em down (not too tight though). This way you won't lose the screws, and you'll keep dirt and dust out of the holes.
