-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   What capture card is good for A1 HDV footage? (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/93502-what-capture-card-good-a1-hdv-footage.html)
John Lewis May 8th, 2007 06:35 AM
I am upgrading to the A1 at the moment, and up until now I have used my reliable old Pinnacle DV500 capture card to grab footage from my SD cameras.
I am guessing that setup won't work with the A1, as the Pinnacle is an SD only setup.
What sort of card should I be getting to capture the HDV footage?
Khoi Pham May 8th, 2007 06:53 AM
Take a look at Edius NX for HDV, I am very happy with it, CPU dependant so the faster your computer the more layers and effects you can stack on it for realtime performance.
Eric Weiss May 8th, 2007 12:38 PM
Does the Edius NX work with Vegas?
David W. Jones May 8th, 2007 04:36 PM
If you are working native then you do not need a capture card for HDV.
Firewire plug and play.
Andrew McDowell May 8th, 2007 06:40 PM
what are capture cards used for then?
Michael Foo May 9th, 2007 07:03 AM
My understanding is that they are also used for realtime rendering and encoding. Does anyone have any suggestions for a Mac solution?
Richard Hunter May 9th, 2007 12:57 PM
Hi Eric. No, the Edius hardware comes with Edius NLE software. I don't think there is any hardware acceleration solution for Vegas, except for the Magic Bullet plugin which uses the GPU.
Richard
