Using consumer Mini DV to play XL2 tapes
Hey guys, I recently just purchased a XL2 and heard it was bad to play, rewind nad fast forward all the tapes in it. Which makes sense and would be really hard on the heads. So I bought a Panasonic PV-GS34PKG, just wondering if this will work and is any quality lost using a consumer camera as a deck?
How would you lose any quality on your tapes besides normal wear and tear from another machine.......better to do that with your cheaper camera as a deck than with your XL2.......!!
The main issue with using a consumer camcorder for playback would be the slight possibility of different tracking - not likely to be an issue at SP speed, only LP speed.
The second issue is that a cheap consumer camcorder might not give as good output if you are using it to provide analog output. For firewire output this should not be an issue. As second camcorder for playback also has some potential benefit of providing a backup camcorder, at least for some situations. |
What is the difference between analog and firewire? How do you connect with firewire?
By now you should have read the owners manual. If you don't have an owners manual, you can download it from this site or from canon.com. The owners manual give you the description of firewire and the location of each connectors. |
I did read through it but must have missed that part. Guess I will just look it up.
Firewire
I capture with firewire. You must have a firewire port on your PC if you plan on using it. It is easy for me. There are arguments as to which is faster. Google it!
5000 files (300 MB total) FireWire was 16% faster than USB 2.0; 160 files (650MB total) FireWire was 48% faster than USB 2.0 ... www.usb-ware.com/firewire-vs-usb.htm - 17k - Cached - Similar pages FireWire vs. USB 2.0 - Speed Comparison Question: USB 2.0 is faster than FireWire...right? ... 5000 files (300 MB total) FireWire was 33% faster than USB 2.0; 160 files (650MB total) FireWire was ... Marc |
If transferring via the standard camcorder digital output, all you are doing is transferring 0's and 1's (digital data) that is on the tape into your NLE (non-linear editor), and as such, there will be no loss of quality if using a lower end cam to do the capture - so long as the heads are properly aligned. I would say your choice to use a cheaper Panasonic camcorder to function as your capture deck is a sensible one. Quote:
The analogue signals are non-digital. The XL2 hosts a number of different analogue connectivity options which are useful for a variety of situations, however, capturing the video content into your computer based NLE is not one of them. If you expect to transfer your content into iMovie, Final Cut Express, Final Cut Pro, Premiere Pro, Sony Vegas, Windows Movie Maker, and a host of other various such applications, then you will generally be using the firewire port to do this. This is also referred to by some as the DV port, and its connectivity spec may be referred to as firewire, iLink, or iEEE1394. Although kind of an aside, your line of questioning makes me curious as to your intended uses of the XL2, and why did you choose it as your entry unit into the world of digital video? Quote:
It is moot here, however as the XL2 does not offer any form of USB 2.0 connectivity. -Jon |
Well thanks for the help..I guess.
Not sure what this is suppose to mean though... "Although kind of an aside, your line of questioning makes me curious as to your intended uses of the XL2, and why did you choose it as your entry unit into the world of digital video?" I will be using the XL2 for hunting and hunting DVD purposes. And I guess the only way to learn is to ask questions so I am just asking them and even it may be the obvious thing to some to others it is not. I have done a lot of reasearch and already know a lot about how to run the camera and what not I just never knew anything about transferring it to the computer, I thought it was pretty much plug and go. As for choosing it, well why not go with the best instead of something lower and and then upgrading to something a little better in a couple years, doesn't make sense IMO. Everyone has to start somewhere and I am sure everyone has questions. |
I have a Panasonic GS180 as a "disposable" camcorder for those shots where I don't want to risk the XL2 (like clamping it to a high-power rocket launch rail). I also use it to download tapes into the computer. Simple matter of economy. Why wear out a $3K+ camcorder when I have a $300 camcorder that will do the same job? I only shoot SP, and DV is DV.
Martin |
I asked about your purposes because you questions made me wonder if you were involving the XL2 in your work because of its various analogue connectivity options, such as working with theatrical or event live feeds, and integration into other studio applications or legacy systems. In those cases, then the info I was posting might not have been pertinent to your intended uses and I wanted my input to be potentially applicable to your needs. Cheers, -Jon |
BTW, Russell,
I forgot to mention, welcome to the forums. Its always great to have new XL2 users on board. I'm sure you will find a great deal of helpful information on this site. Enjoy. -Jon |
What about 24p footage? Can I capture that correctly using a cheaper non-progressive camcorder?
Thanks Jon, and I do look forward to all the info that is provided by you and others here at the watchdog.
Most of what I shoot is 24fps, works great! Welcome to the fun Russell. Terry |
Blah - Use the XL2 as a VCR
I've been using the XL2 regularly for almost two years.
I've shot 4 short films and a feature without anything major. In fact, we just finished transferring 29 tapes from the XL2 to my MacBook Pro without any problems whatsoever. "Hard on the Heads" seems like a problem of yesteryear. I've never seen this to be true on a camera with this type of build quality. The feature would be disabled if it would harm the camera or the heads for that matter. Mechanically, I've only had a couple of issues with my rigorous usage. 1) The viewfinder support has cracked, causing the viewfinder to slant. (dropped on set) 2) The tape eject button sticks and must be held down to eject tape. (over usage) 3) Moisture caused the camera to shut off twice. (left outside in camera bag) Otherwise, flawless operation. My vote is – use it as a VCR and don’t waste money. Spend that extra dough on a 35mm adaptor. |
Well I guess in my opinion it would prolong the life of the camera and heads and be less hard on them. If I am going to spend $4000 on a XL2 why not spend the extra $125 for a consumer vid. camera to save a little wear on the XL2.
But the post that talks about the XL2 being robust enough to take it is probably right. When we were at the Canon seminiar, that's exactly what the rep said. The camera transport controls will out last the usefulness of the camera, according to him. |
| All times are GMT -6. The time now is 09:41 AM. |
