-   Canon XL and GL Series DV Camcorders (https://www.dvinfo.net/forum/canon-xl-gl-series-dv-camcorders/)
-   -   16x Manual lens breathes-Waah! (https://www.dvinfo.net/forum/canon-xl-gl-series-dv-camcorders/36504-16x-manual-lens-breathes-waah.html)
Mark Sasahara January 21st, 2005 02:04 AM
Oops, you were talking about the older 16x auto lens.
You could probably stick a gear on that too. It's just that with the auto lenses, they are electro focus, so if you power down the camera all your marks are worthless. The 20x auto and 16x auto lenses may both be the same circumference.
Richard Hunter January 21st, 2005 09:07 AM
Mark, you got me confused now. Does the follow focus work repeatably with the 20x lens or not? Losing the settings on power down is not really an issue for me, just whether it hits the marks or not.
Richard
Daniel Kohl January 21st, 2005 10:17 AM
I made a new thread because I think that this has gotten off topic.
"Follow-Focus for 20x servo lens works how?"
I'm going to put my reply there.
Cheers
Mark Sasahara January 21st, 2005 01:59 PM
Richard, yes follow focus works semi-reliably with the 20x.
I am focused on the screen in my window approx. six feet away and the bricks of a building about one hundred feet away. The far mark, on the building seems to drift a bit, but the near mark is pretty consistent. I am at a telephoto focal length and my f/stop is f/2.0 with the full ND in the lens being used. There is some play in the Cine Tech follow focus. I'm trying to get as shallow a depth of field as possible. The marks are pretty good for the 20x.
I am trying closer points. My near point is 11' 5.5". Far point is 27' 11". I am using a Stanley 100' steel tape and anchoring off the metal block that holds the rods on my Chrosziel matte box bracket. This approximates where I imagine the CCD block to be, but I have no idea. My marks are high contrast: black tape against a white wall (near) and backlit frosted glass (far). Illumination gets me f/2.0. I'm at approximately the same focal length as the manual 16x lens which was 48mm.
I notice that if you only shift between the near and far marks, the focus is consistent. If you go way past the marks and then go back, they are oblitereated and you have to set new marks. But if you keep with the two marks, they appear to be consistent.
Also I have to take into account the play in the follow focus, I'll see if I can tighten it up a bit. This seems to affect the results. There is some backlash which results in the mark shifting when you let go of the knob. This may be because the mechanism has a belt to drive the gear.
I did the same distances with the 16x manual lens and it is more consistent
Actually, I wasn't paying attention and the battery died. So I shut off the camera, switched out batteries, and my marks were the same. I tried it again by turning off the camera, waiting about thrithy seconds, then turning it back on and they remained consistent.
Daniel Kohl January 21st, 2005 03:21 PM
Hi Mark,
I guess my attempts to move this thread out of the subject of breathing lenses is not going to work, so I'll fall into line.
I'm very interested in wether this follow focus works like I wish it would. And since you are kindly trying it out for us. If you would tell me how this goes with your set up, I would be most grateful:
If using the same situation that you had set up in your last entry; you snap the focus from the far point to the near point really fast, are the marks still accurate?
Do this again with a really slow rack, as slow as you can go, and tell us if the marks are still good.
Thanks.
Mark Sasahara January 21st, 2005 04:54 PM
You're right Daniel. We probably ought to go over to the new thread that you started. I will play around with the lens when I get a chance later today, or tomorrow.
I'll post on the new thread you started.
Daniel Kohl January 21st, 2005 04:58 PM
Thanks a lot Mark!
I really do appreciate you trying this out for me ... uh us.
Till then,
DK
A. J. deLange January 21st, 2005 06:23 PM
The way these servos most likely work is that the processor, in auto focus mode, sends pulses to the actuators commanding moves with a second signal telling the actuator which direction to move in. The manual rings mimic the processor in that they too send pulses to the actuators with a direction signal. Thus as long as you never send enough pulses to get the actuator at either end of its range the ring settings should be repeatable. If, however, you turn the ring to the point where the actuator is at he limit and then turn it half a rotation past that the actuator will ignore the command pulses but when you come back will respond immediately to the pulses to go in the other direction. The ring markings would be off by 180° in such a case. It's probably not a big deal to change the firmware to use the pulse counts to keep track of where the ring actually is to prevent sending pulses to the actuator until the ring is where it is supposed to be. This could simulate the action of a mechanical control.
Daniel Kohl January 21st, 2005 06:34 PM
The problem is that there seems to be processor which responds to the frequency of the pulses, and changes the degree of change in focus according to this frequency. The result is that turning the focus ring quickly (higher pulse frequency) causes a larger change in focus across a given pull, than a slow turn (lower pulse freq.) does.
In order to hit marks consistently, one would have to pull focus at the same speed every time. This is the bigger problem with the lens, than the 180 deg. problem.
At least that is how I understand it.
Richard Hunter January 21st, 2005 08:05 PM
It's quite common in control systems to have a rate sensitive design like the one that might or might not be on the XL2. (I believe XL2 is rate sensitive but others seem to disagree so I'll try to keep an open mind for now.)
The advantage of this system is that it lets the operator make large movements quickly while also allowing for fine adjustment. It also means that the rotational position sensor does not have to be an expensive one because the operator is always in the loop to provide calibration on the fly.
Alternatively, if the system were designed to interpret the input pulses simply as position, there would either be lack of precision in the focussing, or it would take many turns of the focus ring to go from close to far focus settings. Using a more expensive encoder would help, but some mechanical gearing might still be required for fine control.
Anyway, a big thanks to Mark for carrying out these tests and reporting the results on the forum. It is very much appreciated.
Richard
Mark Sasahara January 22nd, 2005 04:20 PM
Here are the results of my research on follow focus with the 20x auto lens.
I made a new post, "Canon 20x auto lens follow focus accuracy"
http://www.dvinfo.net/conf/showthrea...threadid=38166
Charles Papert January 22nd, 2005 05:16 PM
Read your test findings Mark, good job.
Sounds to me like breathing or not, that 16x manual is looking more attractive now...?
Mark Sasahara January 22nd, 2005 05:55 PM
Thanks Charles and you are right. After using both lenses I prefer the manual. The 20x has a longer reach, but I'm pretty much sticking with the 16x manual.
Charles Papert January 23rd, 2005 12:11 AM
I'm a 14x manual guy myself. I like having the iris ring where it should be, and I rarely seem to need more on the long end.
Mark Sasahara January 23rd, 2005 03:06 AM
Ya! What the heck was I thinkin', eh?
