-   Canon XL and GL Series DV Camcorders (https://www.dvinfo.net/forum/canon-xl-gl-series-dv-camcorders/)
-   -   Anyway to do snap zooms? (https://www.dvinfo.net/forum/canon-xl-gl-series-dv-camcorders/36761-anyway-do-snap-zooms.html)
Mike Minor December 22nd, 2004 01:07 PM
I've tried by speeding up the zoom speed, but even the fastest isn't fast enough :( Anyway to trick it into going faster?
Jimmy McKenzie December 22nd, 2004 01:32 PM
Either the 14x (older model) or the 16x (not the white16x) manual lens will give you blast zoom ability. There's a really awful cooking show called "red hot and ready" that uses this technique and it is the pinnacle of unviewable content. But, for a music video or similar requirement it would work well.
Brent Ray December 22nd, 2004 06:35 PM
The manual lens idea is much better, but you could consider just zooming normally, then speeding up the footage in post. It's a cheap and easy solution, although the quality won't be the best.
James Emory December 22nd, 2004 09:15 PM
Aren't servo lenses fun? The problem with speeding up the zoom is that the content will speed up as well, although this would only take just a second or two depending on how fast you want the zoom. A manual lens is definitely the way to go.
