-   Canon XL and GL Series DV Camcorders (https://www.dvinfo.net/forum/canon-xl-gl-series-dv-camcorders/)
-   -   Brush fire test (https://www.dvinfo.net/forum/canon-xl-gl-series-dv-camcorders/69985-brush-fire-test.html)
Ralph Roberts June 21st, 2006 04:01 PM
Brush fire test
We had a small brush fire next door last night ... so I got to try out my new XL2 in dark conditions.
http://ralphwroberts.com/fire.html
I'm not sure I could have got better lighting (the footage I show on manual with the gain up and aperture wider were awfully grainy.
But... any suggestions for shooting in these type conditions in the future would be appreciate.
At least, enjoy the video.
--Ralph
Jarrod Whaley June 21st, 2006 04:14 PM
I'd suggest pressing the blacks, raising the master pedestal, and giving setup level a bump or two. The footage will look really foggy and low contrast in the camera, but that'll give you more detail in the dark areas. Then you can tweak the contrast in post.
Ralph Roberts June 21st, 2006 04:16 PM
Thanks, Jarrod! I'll experiment with that technique.
--Ralph
Ash Greyson June 21st, 2006 09:33 PM
I thought it looked pretty good for night stuff... pressing the blacks and then raising the MP and setup doesnt make a lot of sense, they would be fighting against one another and just make for milky blacks void of all detail.
I would just use your gain in this situation, then turn up the coring, turn down the sharpness and turn on NR. Depending on how much detail you wanted to pull from the dark areas, you could either stretch (to get more detail) or press (to make all the dark area go black)... When you get your gain at +6dB you will need a notch boost in color saturation... when you get to +12dB you will need a two notch boost.
ash =o)
Jarrod Whaley June 21st, 2006 09:53 PM
Listen to Ash. I haven't shot much of anything with this kind of contrast ratio, and was just guessing.
Ralph Roberts June 23rd, 2006 05:54 AM
ash =o)
Thanks, Ash!
--Ralph
Tony Davies-Patrick June 23rd, 2006 03:39 PM
The biggest problem in my view is not the exposure, but the constant in-out zooming, and very shaky/wobbly footage.
Try to edit out most of the zooms and it will look a lot better. The XL2 can look very steady if you stand still with a comfortable balance of the camera on your shoulder, and use IS if filming at the telephoto end.
Instead of zooming in, try a quick steady shot of the scene, stop filming, walk in closer, then take some tight shots with a wider angle (I know that it can be dangerous to get too close, but the tighter you are to the action, the more light – and firelight - will be hitting the XL2 sensor).
In situations when you must stay far away, try to use a tripod, monopod, or brace yourself against a post or lean on something solid.
Try not to pan when you are not on a tripod; or if you need to when handholding, just stand side-on to the action and twist very slowly while doing a slow pan with no zoom. Turn off the IS when panning.
I hope some of this helps.
