Using Premier Pro to edit 24p
I use my XL2 to capture footage using 24p frame rate setting and then edit it with Premier Pro 2.0 (DV-24p editing setting). I only use this setting(DV-24p) if the footages were captured in 24p. I never had any difficulty capturing the footages into P Pro 2.0 or editing it. You did mentioned the word IMPORT. What do you mean? This is how I do it. Make sure the entire footage was shot in 24p (using your XL2's 24p). From your PC start Premier Pro 2.0. then choose <NEW PROJECT>. From the New Project's dialogue box, choose <DV - 24P> preset folder. Expand the folder by clicking on the <+> Tap if its not expanded. You will have 4 options. Make sure you select the correct setting. The next thing is to specify a folder and a name for your Project. Then click <OK> To open Premier Pro 2.0. Once Premier Pro 2.0 has loaded, you must use it(PPro) to capture your 24p footages. To do this, hit F5 on your keyboad to open the capture window. and then you can start capturing your 24p footages. This is the way I have been doing it. I hope this help. Other PPro users can also weigh in. |
Hope this helps, -gb- |
Ed:
Thanks for running me through. The only reason I wasn't sure about using the 24P project settings is really two fold: 1. When you shoot normal 24P in the XL2 I shoot at the 2:3 pulldown. But if you look at the PPro 2.0 24P capture settings it shows 2:3:3:2, which is 24P Advanced. So that confused me. 2. If I capture and edit in a 24P project, I am not able to export back out to tape for submission to TV stations which require a normal NTSC 29.97 project. Thoughts? |
Premiere Pro 1.5 had a serious bug that mishandles 24p normal footage. Premiere Pro 2.0 will handle it just fine. The problem must be with your set-up. If you want to edit in 24P native you can set PP 2 to rebuild the C frame. Set your output settings to repeat frame (not 2:3:3:2) for output to DV tape or whatever media you are sending to a broadcaster. I prefer to edit in 29.97 timelines and shoot in camera 24P with 3:2 pull-up, in that workflow, there should never be any issues... All that being said, FCP is a MUCH MUCH better program for handling different formats/frame rates and many people swear by Vegas.
ash =o) PS. for low light you can also switch your Gamma to Video which has less noise |
24p in P Pro 2.0
Answer to Q1 To set 24P playback options 1. Choose Project > Project Settings > General. 2. Click the Playback Settings button. 3. In the 24p Conversion Method pane, select one of the following options: Repeat Frame (ABBCD) Duplicates frames where necessary to maintain 29.97 fps playback. This option uses fewer CPU resources. 4. Interlaced Frame (2:3:3:2) Combines the frames in a telecine-like scheme to maintain 29.97 fps playback. This option produces smooth playback but uses more CPU resources. Click OK in the Playback Settings dialog box, and click OK in the Project Settings dialog box. (Note - I have always use the (2:3:3:2 option in PPro2.0) because of one reason, smooth playback) Answer to Q2 Ash is right If you are submitting to a TV station, you can shoot in 24p w/XL2, then edit it in 29.97 Timeline and then export it to NTSC 29.97. In a 29.97 Timeline, you can import clips which were shot in 60i, 29.97 and 23.97. (Note - PPro 2.0 will change the 24p footage(s) to 29.97. during importation) Devon 24p is very nice an artistic. However if you are doing alot of middium pan and fast camera movements, then 30p should be the choice(Just my opion). Hope this help. |
Ash and Ed, thanks a bunch for the input. I will work some more with the suggested changes. I have had just enough problems in the past that I've become comfortable with 30p. That being said, I like the look of 24p and want to keep the option open. Thanks again.
Devon |
| All times are GMT -6. The time now is 07:34 AM. |
