-   Canon XL and GL Series DV Camcorders (https://www.dvinfo.net/forum/canon-xl-gl-series-dv-camcorders/)
-   -   XLH-1 Lens on XL2 (https://www.dvinfo.net/forum/canon-xl-gl-series-dv-camcorders/76646-xlh-1-lens-xl2.html)
Tony Davies-Patrick October 4th, 2006 10:03 AM
Yes, I'm sorry Jarrod, you are of course correct. I always use 16:9 with the XL2 and expect the same problem would apply when in 4:3 mode - I know that I also used to sometimes have similar problems with the XL1s (4:3).
16:9 shouldn't make any difference, although it does add vignette problems when using some add-ons (compared to 4:3).
The IS ‘drag’ of the 20X can also sometimes cause a slight momentary vignette at the edges when combined with a wide converter during movement or a slow sideways pan.
