shooting planes
Anyone have advice shooting fast airplanes?
Will be shooting with XL2 & 24p (maybe 30p?); but don't know yet if it's best to shoot with the 20x or 3x. With the 20x I could zoom in close(er) to the action; with the 3x I could get the whole action scene; I guess I could also just change lenses in between races. Which settings should I use---24p at faster than 1/48th (1/75?) speed? The Red Bull Air Race is in Monument Valley, Utah this week; they'll will be doing several trial runs before the actual race (weather permiting); so I should be able to use different settings, and set-ups and see which ones work best. --JA |
I don't have a ton of experience, but from everything I know you should definitely shoot in 30P. I'm guessing with fast moving planes, you will be doing a lot of quick pans, which can be very jittery in 24p.
Thanks Paul. I thought 30p was the way to go as well, to reduce the "judders" of shooting fast motion.
--JA |
keep a steady hand... just kidding...
I shoot billfish greyhounding and jumping across the water with an XL2... I have experience taking stills at airshows as well... I shoot with my camera on my shoulder from the boat... and I would say the best thing you can do, besides practicing your swing through with the aircraft, is to tuck your elbows in to your body and sort of become a tight single unit with your camera. This has worked well for me, and it's as steady as can be. You will find a position with your hands and elbows that will feel secure and easy to swing. Do you have any shooting experience with shotguns or rifles? It's the same kind of feeling shooting moving subjects with a camera. Hope that helps a little...??? |
Thanks Matthew; good advice about the shotgun/rifle, as the XL2 can feel somewhat like a loaded "canon" sometimes (pun intended :)
Shot some planes taking off the runway yesterday, but we were right behind the fence that we felt like an outsider; but it did give it sort of a doc feel. (Actually, me and my wife felt like paparazzi, as she was shooting stills, and me shooting video through the fence!) Word of common sense advice--don't stand behind a small plane when it's ready to take off! And if you do, hold on tight to your gear!!! We'll be shooting more planes today, as they go through their time trials; this time, hopefully, no fence will be blocking our shots! --JA |
For the best results, follow Matthew's suggestions and imagine you are shooting with a gun, rather than a cam. For anything with speed, you must lead your target. With guns, it's because the bullet takes time to get to the target, but with film or video, it's because your moving target needs "face space," to show an image of where the target is going, rather than where it's been.
If it is a one-off, then why not add an extra camera. I occaisionaly attach a small JVC handicam to the top handle of my bigger cameras, and leave it on wide, recording. That way even if the fast moving plane gets a bit out of frame, you still have something. I don't normally do planes, but fast racing speedboats.
Thanks Jack and Paul R for the replies and advice!
Alas, the Red Bull Air Race in Monument Valley has come and gone. Don't know if it was a success for Red Bull (don't think they sold all the tickets they needed to sell), but it was certainly fun watching and capturing those planes flying over 250mph! Whew! Anyway, I shot in 24p but in faster shutter modes. It seemed to work fine and the images looked good. As far as following the planes, it was tough work. With the 20x, I really couldn't zoom in as close as I wanted as it got too shaky. Pulling back the zoom, I captured the action a bit better. I think I captured enough variety of the action, close and far. Hopefully, I can post some samples. But for now check out their website: www.redbullairrace.com --JA |
Be aware that if you post any clips on Youtube and claim copyright on your own origination, a complaint may be made against you, your clip will be shut down and the placard will remain on the website even if you remove your membership, not good if you identify your own production entity.
I set up two cams on one tripod, one with a long zoom, the other with standard zoom. I use the long zoom to get what close-up shots I can and boresight to follow for the wider camera which means smoother follows. For the wides you have to make up your mind whether the frame stays static and you let the planes do the moving because follwouing a small object gets very boring very quickly. I also use an old heavy Miller fluid head tripod. Try to find a position where combined vertical and horizontal movements are (EDIT-->>) NOT needed of the tripod head for your follows. These are harder to co-ordinate. |
Bob - I don't understand the thing about youtube and copyright? What would make them remove the clip on material you shoot yourself? (or have I got the wrong end of the stick)
One thing I have found very useful for the small amount of aircraft stuff I do is a post head! The normal style heads offer limited performance when tilted up at extreme angles. I'm a great fan of old Vinten broadcast kit, and I've got one of the cygnet heads and these can go up to vertical (and even over the top if you want them to). There's a small picture of it here http://www.earsmedia.co.uk/_wp_gener...e52ddcf_0f.jpg They are also good for drop shots from a jib. |
I made an error in my post above regarding combined movments and it is corrected. Agreed the traditional tripod is very limiting in following overflying aircraft and birds.
I have thought about making one of those side heads but have not got around to it yet. One of those radar controlled gymbal things the US Navy uses in their Phalanx missile defence system would be just the ticket. As for copyright, this address is where my clip used to be. In Perth WA there was no pay to see, it was in the public view. http://www.youtube.com/watch?v=RnfnlMt_7FE I thought the clip was fairly harmless. My mistake it seems was claiming copyright on my own origination. As IMG apparently has broadcast rights and posting on Youtube is pitched as "broadcasting yourself" the dots are not so hard to connect. IMG put a lot of resources into getting video coverage of it themselves so their jealous guarding of it is to be expected. I wouldn't object to 5 minutes in that big blue camera helicopter and that can not be cheap to run. However the placard remains on Youtube to declare to those who know me and have the link in their computer still, that I am an alleged copyright infringer. I was fairly irate at the time but have simmered down since. |
I think you should shoot 24P or 60i. You are better shoting 60i.... cause you can always convert 60i to 30P or 24P. You may have issues converting 30P to 24P. Another question you may ask are you ever going to convert to film..... if yes ... once again shoot 24P or 60i. There is a great book written by Pete Shaner called 24P I recommend you read it.... explains the intricacies of shooting 24P vs 30P vs 60i.... |
30p has much of the film-like qualities of 24p, but it is smoother. And it looks great when watched from a DVD on your TV. |
you can always get 30P from 60i, but you can not go backward. if you take 30P to be converted to film they will not take your footage. So if you are looking for a movie like quality 24P is the way to go. If you are looking for versatility the 60i is the way to go. 30P would lock you in since not all basic software con covert 30P to 24P. Hence..... if your PURPOSE is compatibility then 60i (cause 60i can be 60i or 30P and even 24P with proper software) beats 30P (can only be 30P), if your purpose is the film look, then 24P is the way to go..... When I say there is no purpose to shoot 30P , i mean that thats the least useful standard and therefore I do not recommend it. |
If you mount a sighting device on your camera it's easier to track a moving object and you'll lessen the risk of losing it at high zoom.
Shooting fast airplanes? Try to get the sun behind you and locate yourself next to a public address speaker for running commentary and set your record level; pray for a cloudy day add a neutral density filter and don't frame in too close, you'll just lose 'em.
Stay back enough to be able to track 'em smoothly and yet see what plane it is. Even get back far enough to see the crowds turning heads every now and then. I use a Mighty Wondercam shoulder mount and it works very well, forget using a tripod, too clumsy. Every now and then let the plane fly outa the frame to be able to cut to a later sequence. Conversly let the plane fly into the frame occasionally. Make sure the audio is top notch, under record if you have to, get bad distortion, it's all over. HTH. |
| All times are GMT -6. The time now is 06:55 AM. |
